Home made head set tools * PHASE 2
Old 11-11-12, 03:57 PM
rootboy
rootboy's Avatar
Quoted: 550 Post(s)
Liked 115 Times in 67 Posts
Thanks to Otis for the nudge. I decided to crank up the metal lathe and make some head set installation tools. I initially thought the idea a bit silly since I'm not likely to use such tools very often but figured I didn't want to take a chance on a set of wooden blocks and a mallet. Out in the garage I found a chunk of naval bronze about four inches long with a 1 inch bore through it, and a length of heavy wall, one inch aluminum pipe, so ...why not? I also had a huge, one inch diameter threaded "bolt", a piece of utility pole hardware, with big nuts and washers. These fittings are designed to use on that. I'd like to have thrust bearings in between the big galvanized washers and these bronze tools but I didn't have any. I may still turn some big PTFE washers to act as bearings. These were turned to fit Campagnolo Record head set cups.
rootboy is offline
Old 11-11-12, 04:00 PM
rootboy
rootboy's Avatar
Quoted: 550 Post(s)
And here's the crown race installation tool. The yellow brass striking head is a bit overkill, but that piece of 1 1/4 inch hex stock is all I could find handy. I made the brass pieces a press fit on the aluminum pipe and pressed them on using my hydraulic press.
The crown race removal tool will be a bit more involved. Have to hook up the little bench top milling machine.
rootboy is offline
Old 11-11-12, 04:11 PM
Orrery
Orrery's Avatar
Bikes: 1983 Trek 600, 1973 Mercian
Wow. Glad I clicked on this thread. I love when the machining threads pop up on this forum. Nice looking tools!
Orrery is offline
Old 11-11-12, 04:28 PM
rootboy
rootboy's Avatar
Quoted: 550 Post(s)
Thanks Orrery. Hope they work!
rootboy is offline
Old 11-11-12, 06:49 PM
ColonelJLloyd
ColonelJLloyd's Avatar
Quoted: 109 Post(s)
Liked 6 Times in 5 Posts
Damn. That's fancy!
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
ColonelJLloyd is offline
Old 11-11-12, 06:56 PM
rootboy
rootboy's Avatar
Quoted: 550 Post(s)
A bit too fancy, Colonel. Just can't help myself. I was putting the finish on them and stopped myself. We're not making jewelry here, I told myself. Still, it's fun to try to turn out a nice tool. These are overkill to be sure.
I've got at least one more piece to turn. When pulling in the bottom cup, I'll use a 1/2 thick bushing of PTFE teflon cut to exactly register on the top head lug to keep the back end of the rod centered. The fit between the threaded rod and the bronze dies is a nice slide fit so though there is a bit of play between the rod and the head tube, it ought to center well. When pulling in the top cup the bottom cup die will register the rod. The die are machined to fit the flats in the cups precisely so I'm hoping there's very little slop. We'll see.
rootboy is offline
Old 11-11-12, 07:06 PM
southpawboston
southpawboston's Avatar
Quoted: 71 Post(s)
Liked 140 Times in 65 Posts
Beautiful work! I'm jealous, I want a lathe now!
southpawboston is offline
Old 11-11-12, 07:24 PM
sloar
Bikes: they change so much I'm tired of updating this
Quoted: 976 Post(s)
Liked 412 Times in 180 Posts
So, you just happen to have a big chunk of bronze in your garage,who has that just laying around?
Semper fi
sloar is offline
Old 11-11-12, 08:33 PM
busdriver1959
Quoted: 53 Post(s)
Liked 7 Times in 3 Posts
Very nice work!
busdriver1959 is offline
Old 11-11-12, 08:41 PM
Chris W.
Chris W.'s Avatar
Bikes: 76' Centrurion Pro-Tour, 86' Specialized Rock Hopper, 88' Centurion Iron Man, 89' Bruce Gordon "Hikari", 95' Rock Hopper Ultra.
Quoted: 14 Post(s)
Liked 3 Times in 3 Posts
Wow!!! Just wow....(freaking beautiful!)
Cheers,
Chris
Chris W. is offline
Old 11-11-12, 09:03 PM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 1495 Post(s)
Liked 1,722 Times in 997 Posts
That's not a crown race installer, that's jewelery. Beyond beautiful.
-Kurt
cudak888 is offline
Old 11-11-12, 09:15 PM
KvltBryce
- Bikes Not Bombs -
KvltBryce's Avatar
Bikes: 1986 LOOK KG86, 19XX Les Ephgrave?, 1983 Nishiki Royal, 199X Nukeproof MTB, 1974 Raleigh Grand Prix
Brass silly, Brass.
KvltBryce is offline
Old 11-11-12, 09:20 PM
sloar
Quoted: 976 Post(s)
Ok, naval bronze=brass, yep I should've known that.
Semper fi
sloar is offline
Old 11-11-12, 09:28 PM
Michael Angelo
Michael Angelo's Avatar
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 73 Post(s)
Liked 13 Times in 11 Posts
I really like metal turning. That is some nice work.
Michael Angelo is offline
Old 11-11-12, 10:02 PM
jeirvine
jeirvine's Avatar
Bikes: '72 Moto Grand Record, '72 Gitane tandem, '72 Raleigh Super Course, '73 Raleigh Gran Sport, '73 and '76 Colnagos Super, '76 Fiorelli Coppi, '78 Raleigh SBDU Team Pro, '78 Trek 930, '81 Holdsworth Special 650B, '86 Masi GC, '87 Panasonic DX5000
Quoted: 661 Post(s)
Liked 263 Times in 156 Posts
Nice work. Needs drillium.
jeirvine is offline
Old 11-11-12, 11:20 PM
cudak888
cudak888's Avatar
Call the Styleman.
-Kurt
cudak888 is offline
Old 11-11-12, 11:45 PM
Andycapp
Andycapp's Avatar
Bikes: Tommasini Super Prestige, Kamra Triathlee, Nishiki Tri-A equipe', Sakai 2000
We need a "show me your lathe/bridgeport" thread
Andycapp is offline
Old 11-12-12, 03:15 AM
ftwelder
ftwelder's Avatar
Bikes: Many
Quoted: 5 Post(s)
Liked 4 Times in 4 Posts
Awesome parts! It's good to hear that some chips hitting the garage floor again!
ftwelder is offline
Old 11-12-12, 03:30 AM
puchfinnland
MIKE is my name!
puchfinnland's Avatar
Bikes: hans lutz, , puch mistral ultima,2x Austro Daimler Smoked chrome Ultima,Austro Daimler Mixte,Austro Daimler 531 mixte, flying arrow,F Moser,
Why did you not make it in the method of pulling them in rather then beating them in?
far more refined.
Bronze...I got scraps of that are too good to use for things like that!
Its a shame, basement is full of valuable scraps !
puchfinnland is offline
Old 11-12-12, 06:20 AM
rootboy
rootboy's Avatar
Quoted: 550 Post(s)
Thanks everyone. A couple of comments. "Pulling them in", Puch? I'm not sure I follow you. I guess I'll need to post a pic of those fittings mounted on the threaded bar. My basement is full of valuable scraps too. I figured, why not use some of them. That crown race installer will probably fit under the anvil of my hydraulic press with the fork straddling a chunk of wood. I can just press it down as opposed to whack it. The thought may occur to some....if you have a hydraulic press, why not just use that? Occurred to me too but the fixtures that would have been needed for that to work would be many times more involved than these.
"naval bronze=brass" Actually, bronze, not brass, which is a different alloy. Bronze is slightly easier machining due to its tin content. Brass is copper and zinc. This piece was 1 3/4 diameter with a one inch bore through it. I've got odd chunks of stuff like that around. I got most of it when I was into making high end custom hardwood and metal lamps. I also have pieces of nickel silver around, another copper alloy. The head of that crown race installer is brass, however.
In short, if I hadn't had that piece of bronze pipe and that section of aluminum around, I never would have started this project. The bore in the bronze pipe fit the 15/16 threaded rod with a nice slide fit. As anyone knows who has thought about it...which I was forced to do... the critical aspect of pressing in any race or bearing is keeping the tool in exact alignment with the axis of the head tube. There is a bit of play between the threaded rod and the head tube so I'll need a "locating fixture" on the back end of the rod as I pull in the opposite cup. To keep the rod centered in the head tube. As I said, I machined these fittings so that their drive surfaces register very precisely against the flats on the cups, with no side to side play. They sit just outside of and register against the races, but not on them. I'll machine the piece of Teflon or maybe Delrin today and post a pic of the whole tool when I get it done. The big, galvanized threaded rod is a bit crude but I had it so figured I'd try to use it.
Thanks all.
rootboy is offline
Old 11-12-12, 06:57 AM
noglider
noglider's Avatar
Quoted: 6880 Post(s)
Liked 1,515 Times in 958 Posts
I want to be a machinist when I grow up.
noglider is offline
Old 11-12-12, 07:01 AM
rootboy
rootboy's Avatar
Quoted: 550 Post(s)
Me too Noglider. I'm purely amateur. WAY amateur. One reason I resisted trying this is that it takes me a long time and I make lots of mistakes. A real machinist could have whipped these parts out in a couple of hours. Probably less. This took me nearly two days. But it is fun.
Nothing like turning copper alloys on a metal lathe. Steel? that's another story.
rootboy is offline
Old 11-12-12, 07:08 AM
rootboy
rootboy's Avatar
Quoted: 550 Post(s)
A materials hoarder, that's who. I've got lots of weird materials laying around, Sloar. From brass and bronze to ebony and Brazilian rosewood, old bits of ivory, sterling silver, phenolics and plastics ....even a full turtle shell, painted with brown enamel, I picked up at a yard sale 35 years ago,...quite a sad artifact.... as well as all manner of strange tools...you name it. All fodder for tinkering with the hands.
rootboy is offline
Old 11-12-12, 07:32 AM
puchfinnland
MIKE is my name!
Hmmm, just remember, I inhereted a sweet lathe last year- thing is its stateside and inches(yuk)!
I have not seen it for 30 years.
I think I got a small milling machine also waiting!
more reason to move back.
rootboy-I did not see the threaded rod to pull in the races.
but that is the way they should be.
mike
Old 11-12-12, 08:00 AM
rootboy
rootboy's Avatar
Quoted: 550 Post(s)
I'll post a pic of the whole contraption, Mike.
Inherited a lathe and mill? Great. What kind are they, do you know?
rootboy is offline
