Homemade derailleur displays
Old 11-17-12, 09:24 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 192 Post(s)
Liked 169 Times in 82 Posts
I thought I had a great idea on how I was going to display some of my extra rear derailleurs. After a trip to the hardware store today, it looks like i'm back to the drawing board.
The original idea:
Buy a bunch of long M10 x 1. pitch bolts (same threading as a rear derailleur hanger). Stick the bolts through a chunk of wood, add some spacers and a coupling nut to thread the derailleurs into. Minimal, elegant-ish, strong and easy to make. One problem. M10 x 1. pitch bolts are not the most common... and when you do find them, they are about 2 dollars each. It would cost around 40-60 dollars to make. This is not a ton of money, but I definitely want to keep this project on a very small budget.
Now I am back to the drawing board:
- Maybe some hanging hooks, like a pegboard (not very refined)
- Maybe some sort of "U" shaped bracket?
Any ideas, photos or creative genius would be lovely.
mkeller234 is offline
Old 11-17-12, 09:50 PM
jeffpepperdine
jeffpepperdine's Avatar
Bikes: 1987 Cyclops / Ken Legge Custom. 1987 Battaglin. 1970's Carlton Corsair. Late 80's Masi Gran Corsa. 79 Witcomb.
Why not skip the bolts and just find a way to secure some nuts to the board (glue?). Is is a display after all, and most derailleurs don't weigh that much.
jeffpepperdine is offline
Old 11-17-12, 09:51 PM
Andycapp
Andycapp's Avatar
Bikes: Tommasini Super Prestige, Kamra Triathlee, Nishiki Tri-A equipe', Sakai 2000
While they are out there m10 x 1 isn't the "standard", so they'll be pricey and selection kinda sucks. How about just buying a 9mm drill and a m10 x 1 tap? I'm picturing a piece of aluminium (you could get fancy and frame it in a nice hardwood). Then lay-out you holes and mount the derailleurs. Sounds like a cool idea, can't wait to see what you come up with...
https://www1.mscdirect.com/eCommerce/...roductsContent
Andycapp is offline
Old 11-17-12, 09:53 PM
Michael Angelo
Michael Angelo's Avatar
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 69 Post(s)
Liked 8 Times in 7 Posts
You could mount a piece of Aluminum (strip)in your display case, drill and tap M10X1. holes for as many Derailluers you want to hang. You can even use some of that plastic mirror stuff as background. That way you can see the back sides of them.
Michael Angelo is offline
Michael Angelo
Quoted: 69 Post(s)
Great minds think alike.
Old 11-17-12, 09:59 PM
Andycapp
Andycapp's Avatar
^ I like the mirror idea!
Andycapp is offline
Old 11-17-12, 10:01 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 192 Post(s)
I like the aluminum + tap idea. I'll seriously have to investigate that one. Still, it seems like it wouldn't be any less expensive. Though, maybe more elegant than the bolts.
Old 11-17-12, 10:06 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 192 Post(s)
Here is a very rough mock up of my initial plan. I used a rear axle, so it's obviously longer than intended. Maybe if I get a handful of junk rear axles, cut them down and cover them with spacers?
DSC01146 by mkeller234, on Flickr
DSC01145 by mkeller234, on Flickr
Old 11-17-12, 10:08 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 192 Post(s)
I suppose I could get a block of wood, similar to the one in the photo, and just drill and set some M10 bolts in it.
Where exactly does one find chunks of aluminum (cheaply)?
Old 11-17-12, 10:17 PM
Lenton58
Lenton58's Avatar
Location: Sendai, Japan: Tohoku region (Northern Honshu))
Bikes: Vitus 979, Simplon 4-Star (Romani), Woodrup Giro, Gazelle AB, Dawes Atlantis
Quoted: 24 Post(s)
Liked 8 Times in 4 Posts
I have a couple of old fountain pens — the original Parkers. I mounted one in a deep picture frame and used thin, solid, one-strand copper wire. I'll bet that a larger version of this would work really nicely for your collection. But you would have to make ... or have one made for you ... a large, deep picture frame that uses a thin plywood back. If it is it not worked and fatigued, copper wire has excellent strength for static stuff, and is very malleable and easy to manage. Just an idea that I have kept in my head for some other display stuff I want to do.
Vitus 979, Simplon 4 Star, Gazelle Champion Mondial, Woodrup Giro, Dawes Atlantis
Lenton58 is offline
Old 11-17-12, 10:27 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 192 Post(s)
That does sound nice Lenton58, but I am also looking for something that I can remove, rearrange and add to with relative ease. Sort of a living display, I suppose.
I check out McMaster-Carr, I can get 3/8 x 3/8 x 6ft aluminum for about 11 dollars. That doesn't seem too bad, and it might have a more refined appearance. My Dad has the tools that I should need, so I suppose I should consult him next.
Old 11-17-12, 10:28 PM
Andycapp
Andycapp's Avatar
Love me some McMaster-Carr https://www.mcmaster.com/#standard-al...sheets/=k7mfon
Andycapp is offline
Old 11-17-12, 10:31 PM
Andycapp
Andycapp's Avatar
^ there's that "great minds" thing again
Andycapp is offline
Old 11-18-12, 12:16 AM
16Victor
Lanterne rouge
16Victor's Avatar
Bikes: 1974 Schwinn Paramount, 1980 Raleigh Competition GS, 1986 Vitus 979, 1988 Trek 360, 1991 Trek 7000 MTB, 1999 Burley Rumba tandem
Quoted: 94 Post(s)
I like the axle mounting...keeps with the theme. Leave the threads visible and keep the cones as trim pieces. Maybe secure your wood or aluminum display bar to a picture frame with some QR nuts or skewers.
Ron
Any problem can be solved with the proper application of force, heat, chemicals, or money.
16Victor is offline
Old 11-18-12, 12:25 AM
Drillium Dude
NNNN
Drillium Dude's Avatar
Quoted: 1543 Post(s)
Liked 810 Times in 423 Posts
Poprad made a beautiful derailleur display - and I'm not bringing this up because it features one of my commission works, either. It's the coolest component-display I've ever seen.
Mark, you should share it with this crowd
DD
Drillium Dude is offline
Old 11-18-12, 01:12 AM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 192 Post(s)
DD
Yes, please!
Old 11-18-12, 01:19 AM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 192 Post(s)
Until then, I am still farting around with that rear axle idea. I cut one down with a hacksaw, leaving two fully threaded and even pieces. I might stop by the LBS tomorrow and see if they have about 4 of 6 junk rear axles that they would sell cheap. If they all match and look decent... maybe i'd leave the threads exposed. If not, i'll buy some spacers and just cover them all the way up.
The nice thing is I can use the cutting table at work to route perfect sized holes in the wood so that a hex nut can be secured tightly.
DSC01147 by mkeller234, on Flickr
Old 11-18-12, 01:27 AM
poprad
poprad's Avatar
Bikes: 07 Vanilla, 98 IRD road frame built up with 25th Ann DA, Surly cross check with 105 comp, 78 Raleigh Comp GS, 85 Centurionelli
Quoted: 11 Post(s)
Liked 5 Times in 5 Posts
Here it is guys, just an uber-deep frame shadowbox type framing and monofilament line for attaching (not easy to remove):
[IMG][/IMG]
DD's work is what makes it gorgeous
poprad is offline
Old 11-18-12, 05:55 AM
rootboy
rootboy's Avatar
Quoted: 542 Post(s)
Liked 94 Times in 51 Posts
I've got lots of aluminum Mkeller. Let me peruse the stash and see what I've got. Brass bar might look cool too. Got that too.
What size would be optimal?
rootboy is offline
Old 11-21-12, 01:42 PM
tiger1964
tiger1964's Avatar
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon
Quoted: 246 Post(s)
Liked 38 Times in 29 Posts
Wire? How about a mobile made out of derailleurs? Save that Gran Turismo in case you need a counterweight.
Larry:1958 Drysdale (Grey Ghost?), 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974ish Falcon as Grocery bike. Susan: 1976 Windsor Profesional.
tiger1964 is offline
Old 11-21-12, 02:00 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 192 Post(s)
Well, just an update. I've just sent some 5/8in aluminum to rootboy who graciously offered to help me out. I think this is going to turn out pretty nice!
Old 11-21-12, 02:13 PM
JPZ66
JPZ66's Avatar
Bikes: 1949 'Italian' , 1950 San Giusto, 1897 Union, and a number of "projects"... 198? Grandis, a couple of Mixte's...
The original idea:
What about ordering your hardware from someboby like McMaster Carr ? https://www.mcmaster.com/#
Always cheaper than the local store...
Joe
JPZ66 is offline
Old 11-21-12, 02:19 PM
JPZ66
JPZ66's Avatar
Oh my !! My computer at work didn't even show the previous posts until now...I see it was already suggested......
Cheers,
Joe
JPZ66 is offline
Old 11-21-12, 05:37 PM
Oldairhead
Oldairhead's Avatar
Quoted: 70 Post(s)
Liked 30 Times in 16 Posts
Okay, here's mine. Made from a toothbrush stand, top removed, post radius'ed to seat the unit and then zip tied to the stand.
File Type: jpg
Oldairhead is offline
Old 11-21-12, 07:21 PM
thinktubes
weapons-grade bolognium
thinktubes's Avatar
Quoted: 596 Post(s)
Liked 418 Times in 232 Posts
Early onset cabin fever?
thinktubes is offline
