Frustrations with Campagnolo
True, you make wonderfully designed and solidly performing parts but sometimes you frustrate me so much, Campagnolo.
Case in point:
As I was about to finish my very first Italian build, I notice that one of these guides are missing. They're not secured to the levers and just sit there until one day they just fall out and become lost forever. Either this project is cursed or I've had some bad karma since this bike is now on indefinite hold.
*Sigh* I guess I just needed to vent....
Case in point:
Bikes: Tommasini Super Prestige, Kamra Triathlee, Nishiki Tri-A equipe', Sakai 2000
Are you just missing one? I'm pretty sure there's a single one of these living at my local co-op. They're only open weekends but I'm always looking for an excuse to stop by there . I could grab it for you pretty cheap I'm sure...
-Andy
-Andy
Sorry, pretty sure it was just a single one I saw out there. I'll ask though...
Bikes: Colnago (82, 85, 89, 90, 91, 96, 03), 85 Cinelli, 90 Rossin, 83 Alan, 82 Bianchi, 78 Fountain, 2 x Pinarello, Malvern Star (37), Hillman (70's), 80's Beretto Lo-Pro Track, 80's Kenevans Lo-Pro, Columbus Max (95), DeGrandi (80's) Track.
Quoted: 179 Post(s)
Liked 198 Times
I just bought a pair on ebay (abt. 6 weeks ago). There was another pair for sale at the same time but they were quite a bit more expensive that the pair I bought. I wonder if they turn up on ebay regularly?
I love Campagnolo but those little guides are very easy to loose - silly design.
Quoted: 378 Post(s)
Liked 1,409 Times
Yes, Campagnolo, you tend to shoot yourself in the foot sometimes.
Your Power Torque crankset looks nice and works. Installation requires two tools: external bb wrench and a 14mm hex key. However, removal requires 2 more: the proper Campy insert and a 3-prong gear puller with prongs slim enough to fit between the crank arm and the external BB.
And your 10-sp chain tool: works great for selling Connex-Wipperman chains, 3 of which are cheaper than your tool.
Quoted: 4722 Post(s)
Liked 3,036 Times
Then there's C-Record with the odd size Allen key for the Delta cable fixing bolt, the left hand threaded crank extractor and the dedicated dust cap removers for the hubs and don't ever get me started on Syncro...
Bikes: 1949 'Italian' , 1950 San Giusto, 1897 Union, and a number of "projects"... 198? Grandis, a couple of Mixte's...
Campagnolo !! To get the flow of good karma while working on such things, and in addition to the correct tools, it helps if you are listening to either Luciano Pavarotti, Mario Lanza, or at the very least some Frank Sinatra. A break taken for some good pasta, bread and wine will enhance things as well. Be sure to light a candle in your small St.Ghisallo shrine too. If the frustration level gets too high, put down the bike tools and go take a spin on your well tuned Colnago or other fine Italian Bicicletta !
It's akin to eating bangers&mash, listening to the Beattles and downing a pint or three, then spinning spanners on your Raleigh Lenton or Carlton....just a bit more refined ! God Save the Queen !
Joe
Joe
Quoted: 3464 Post(s)
Liked 2,829 Times
While Tullio was not perfect, he did have a good sense of what worked.
I avoided the first generation aero levers as you had to cut that mouse hole for the cable (unless you drilled the bars) and the mechanical advantage went south. If the client really really wanted aero levers we sold him on Dia Compe's, almost all like the shape better too.
Quoted: 821 Post(s)
Liked 255 Times
I've sold off most of my DA equipped bicycles at this point.
Why?
Nine and ten speed Chorus gruppos.
Various eight speed Campy combos as well.
Other than being gouged on chain tools, zero complaints.
Bulletproof for me.
Why?
Bulletproof for me.
Good news - They just gave it to me since I'm the only one they know who even knew what it is! And, it even comes in a fancy little bag
Bad(?) news - Looks a little different than your pic. Is it the same part? Will it work? What's the deal here, experts?
-Andy
-Andy
I may or may not have the LH extractor as well Found a NOS one at a price I couldn't pass up. I haven't used it yet, but my love for 80s campy cranks will eventually warrant it.
Quoted: 1858 Post(s)
Liked 664 Times
Case in point:
Case in point:
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
I never understood that either because you can run the non aero with or without this thing installed. You could do aero without it but it is real muushy.
Sugar "Kane" Kowalczyk
Liked 664 Times
No law says you have to use the Campy chain tool. You guys are just looking for reasons to gripe. I asked my LBS (the good one) if they use it. They said they have one, but most of the techs use a $40 Park. I bought one, and even I can install chains with it. It works the same as any other chain tool, they said.
Liked 2,829 Times
Liked 664 Times
Bikes: 1970 Holdsworth Mistral, Vitus 979, Colnago Primavera, Corratec Hydracarbon, Massi MegaTeam, 1935 Claud Butler Super Velo, Carrera Virtuoso, Viner, 1953 Claud Butler Silver Jubilee, 1954 Holdsworth Typhoon, 1966 Claud Butler Olympic Road, 1982 Claud
Quoted: 10 Post(s)
Liked 11 Times
I've got those in my levers - without them you can still use the same levers, but as non-aero. There are tiny little round plugs at the top that plug the top entry cable holes when you've got them set up as aero. So, a dual-purpose lever, can be used for top entry or aero cable routing. A transition part in the evolution of bicycles?
Quoted: 821 Post(s)
Liked 255 Times
Note that I said zero complaints.
I rarely buy bicycle tools. If I need one, I stop by the shop.
Once I get my workshop rebuilt after the remodel here, it will have about 80% of the same tools the lbs has for their customers.
The Campy tool is expensive and one can't have everything.
Our shop uses the Campy tool btw.
Quoted: 140 Post(s)
Liked 162 Times
SRAM 10-speed connector links work fine on Campy 10-speed chains. I don't know what works with eleven speed. And FWIW, KMC 10-speed connector links work fine on Shimano 10 speed chains.
