Sidi Genius 2 Adapter Plates
Old 11-23-12, 02:49 PM
thesandypants
I recently came across a great deal on a pair of early-mid 90's Genius 2s that were in "newish" condition, so I couldn't pass the deal. The shoes came with what I believe are Time(?) adapter plates (correct me if I'm wrong):
I have Look Keo 2 Max pedals on my bike, and after a couple google/ebay searches to find the proper Look Keo adapter plate for my shoes, I only came across the ones that says they are compatible with the Millennium soles that have four screw holes, like this:
The soles of the Genius 2s do not have 4th screw hole on the bottom. Will these adapter plates still work without any potential problem, or do I need to find the proper adapter plate? If so, where can I find the proper one for my specific model shoe? I've tried emailing Sidi and have not gotten a response yet. Also, if the adapter plate does work, will I need longer bolts to be able to tighten the cleat>adapter>sole?
Thanks in advance for any help!
File Type: jpg
thesandypants is offline
Old 11-23-12, 02:56 PM
bikepro
Bikes: Look 585
Quoted: 24 Post(s)
It looks like these shoes have the standard 3 bolt attachment. I'm sure the Look Keo's use three bolts. If you remove the adapter plates currently on the shoes, the Keo cleats should bolt directly to the shoes -- no adapter needed.
bikepro is offline
Old 11-23-12, 03:31 PM
thesandypants
Thanks for the response. I've tried that. It doesn't work because there is a gap between the sole and the cleat, as there is a slot space indented made for an adapter plate. Not sure if I described it clear enough, but I hope you get what I'm saying.
Old 11-23-12, 07:31 PM
David Broon
Sqrl
It looks like that's a spacer. If yo take it off, your cleats should mount just fine.
Originally Posted by carleton View Post
Doing one-legged squats while holding chickens in each hand will make someone strong...that doesn't mean it's the best way to train for track racing.
Originally Posted by Nagrom_ View Post
That would be spectacular. A trail of blood and sealant.
David Broon is offline
Old 11-23-12, 07:58 PM
StanSeven
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 859 Post(s)
Liked 757 Times in 550 Posts
I know what the OP is saying and I think he needs an adapter plate for Look. Otherwise the cleat will be sitting inside the slot for the sole. My guess he either won't be able to cleat/uncleat or at least have problems.
StanSeven is offline
Old 11-24-12, 12:21 AM
thesandypants
Correct. I know I need an adapter plate for Look Keo compatible, but my main concern is if the ones I mentioned above will work with my shoes.
I just took a couple more pictures of the sole without the Time(?) adapter plate and with the Look cleats to show that it will not work as there is a big gap between the cleat and indented slot for an adapter plate.
Any other help would be very much appreciated! Thanks guys.
Old 11-24-12, 12:58 AM
ultraman6970
THats the time plate but you still can use it. Just put the cleats over that place, You might need longer bolts maybe.
ultraman6970 is offline
Old 11-26-12, 08:28 PM
thesandypants
The Look cleats do not rest flush with the Time plate.
Old 11-27-12, 10:47 AM
Andycapp
Andycapp's Avatar
Bikes: Tommasini Super Prestige, Kamra Triathlee, Nishiki Tri-A equipe', Sakai 2000
Liked 3 Times in 3 Posts
You're in luck! If you search "Sidi plate" a couple pop up, there's some SPD ones too.
https://www.ebay.com/itm/Sidi-Look-Sy...item4abee979be
Nice shoes by the way, love mine. Wish they looked as fresh as yours
-Andy
Andycapp is offline
Old 11-27-12, 07:37 PM
thesandypants
-Andy
Thanks Andy. I saw that yesterday too and is currently on my Watch list.
Are the longer screws usually included with the plates, or are those also sold separately?
Old 12-01-12, 07:28 PM
fraserdave45
Your really in luck! I just happen to be throwing away this exact pair of shoes. I have posted a picture of the adapter plates that I believe you are looking for. If you PM me a shipping address, I would be more than willing to throw them in an envelope and send them to you for free. I do not have the bolts as I had to use them on another pair of shoes. Home Depot and Lowe's has all the metric cap head screws you will need for a buck or two.
File Type: jpg
fraserdave45 is offline
Old 12-02-12, 03:24 PM
thesandypants
Oh man, that's awesome! Thanks. However, I just won that ebay auction from the link above and paid $20+ for it! Bad timing... Haha.
Old 12-02-12, 03:55 PM
ultraman6970
two thumbs up for fraser.
Old 12-02-12, 08:22 PM
fraserdave45
Darn, that stinks. I found this forum a while ago and I signed up right away so I could respond to your post, but it took the moderator 5 or 5 days to activate my account so I could post. I guess I will hang on to them for awhile in case someone else needs them, but I SERIOUSLY doubt that there are many pairs of these shoes still left out there. They are great shoes but mine just disintegrated. I picked up the Genius Pro 5 Carbons, and I couldn't be happier.
Old 05-08-17, 11:32 AM
tmac_in_sf
Sidi adapter plates for Look Keo 2
Hi All,
I have the same issue as the original poster. I have some old sidi shoes that require a different adapter plate than what is currently on the shoe. I want to convert from Time pedals to Look Keo 2's. Does anyone know where I can find find the adapter plate for Look pedals?
Thanks!
Todd
tmac_in_sf is offline
TallRider
Bicycle Mechanics
4
01-09-17 09:23 AM
pedong
Road Cycling
2
12-15-14 12:34 AM
rkelley23
Road Cycling
23
10-04-11 07:05 PM
samtitzer
Bicycle Mechanics
0
11-02-10 06:20 PM
sykerocker
Classic & Vintage
2
06-21-10 11:32 PM
