Coolest Bottom Bracket ever
Keener splendor
That's cool. I'd paint it red and white before I would install it..
likes to ride an old bike
OK, I'm not convinced that it's any better than a regular BB, but my jaw hurts from dropping so hard. IT'S SO PRETTY.
One of these in your favorite nice-day-only bike with a huge BB cutout would be the bee's knees.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
See, I tell my son all the time; spin, spin, spin....mashing is hard on the drivetrain.
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
With a few mods one could make sausage while riding.
That spindle is super cool looking.
Quoted: 3464 Post(s)
Liked 2,831 Times
Increasing the effective outside diameter of the BB spindle should counter the flex of a ti unit to a point.
Way back in an old article of Bicycling Magazine, like early 70's, there was a design of a spindle a guy machined with a big increase in diameter, in that design the spindle was made from two halves and silver soldiered together then finish machined. supposedly no heavier but stiffer. No one had come up with the oversized diameter outboard bearing idea yet.
As a kid I was drawing up a super wide BB shell, 80 mm, but planned on using a special Phil Wood bottom bracket, just moving the bearings outboard and maintaing the standard overall length. Phil said he would make it, the up charge was $100! Quite a bit in 1974, so the idea never went anywhere.
K2ProFlex baby!
Location: My response would have been something along the lines of: "Does your bike have computer controlled suspension? Then shut your piehole, this baby is from the future!"
Bikes: to many to list
Quoted: 16 Post(s)
Liked 56 Times
You see, their morals, their code...it's a bad joke, dropped at the first sign of trouble. They're only as good as the world allows them to be. I'll show you. When the chips are down, these...These "civilized" people...they'll eat each other. See, I'm not a monster. I'm just ahead of the curve
Liked 2,831 Times
Can you say 5 axis machining center? pretty nice.
Just a thought but that twisted shape may be a result of work hardening the axle by deforming it in torsion. In other words, start with a square section and then by twisting it until it yields there will be an increase in strength. Not sure if I'd use this technique but it's an interesting one to consider.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Rather a waste to have that hidden inside the BB shell.
Pedalin' Erry Day
I kinda had a similar thought,....but more like it was an "accident".
It started life as a square spindle, but Lance got a bit more juice than usual and spun one side just a "wee" bit too hard.
Bikes: 1985 Eddy Merckx Corsa Extra, 1978 Schwinn Super Letour 12.2, Schwinn Paramount PDG 50, 1992 Schwinn Paramount PDG 3, Sears ToteCycle in the works
Bikes: Tommasini Super Prestige, Kamra Triathlee, Nishiki Tri-A equipe', Sakai 2000
This could be done with "just" a fourth axis. Or a CNC lathe with live tooling, but that's just a 4-axis in a different configuration. It's hard to tell at the angles pictured, but I'm not sure even that would be needed. I almost think the curve of the flute is an illusion caused by the shape of the center. An indexing head set at an angle to the X-axis may be sufficient if the flutes are actually a strait cut with a ball-nose.
Pretty cool looking piece to be sure. It would almost be a shame to hide in a BB shell with out a big cut out and even then you'd have to flip the bike upside down to admire it! I'd love to see more pics of his crank and chain-rings.
Keener splendor
This is a spindle that could be used with a doped bike via the seat tube.
Bikes: 07 Vanilla, 98 IRD road frame built up with 25th Ann DA, Surly cross check with 105 comp, 78 Raleigh Comp GS, 85 Centurionelli
Quoted: 87 Post(s)
Liked 923 Times
Just imagine what Drillium Dude would do with that....
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
All my bikes have those. The cottered version is especially hard to find.
(actually, I have no idea what you guys are talking about. The auction is over and the pictures are gone).
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
Too bad, cuz it was just the coolest thing ever!
