Drillium Dude Wannabe
Old 01-07-13, 07:52 AM
Zieleman
Zieleman's Avatar
Bikes: Enough for now
Liked 4 Times in 4 Posts
Being inspired by the beautiful work by DD and the presence of a lend Dremel a some time on my hands, I thought I'd give it shot.
Some left-over campy dt-shifters:
They're definitely not perfect, but I forgot to follow DD's posted instructions step-by-step.
Zieleman is offline
Old 01-07-13, 08:09 AM
Ex Pres
Ex Pres's Avatar
Quoted: 396 Post(s)
Liked 44 Times in 32 Posts
What do they look like on the "right" side?
A good first go, but IMO you need to get rid of the P's (probably easier at the beginning)
Ex Pres is offline
Old 01-07-13, 09:02 AM
Cache
Cache's Avatar
Bikes: 1982 Torker BMX, 1990 Cannondale Black Lightning, 1996 Cannondale F400
A for effort, but don't quit your day job yet.
Cache is offline
Old 01-07-13, 09:08 AM
randyjawa
randyjawa's Avatar
Bikes: 1958 Rabeneick 120D, 1968 Legnano Gran Premio, Rocky Mountain Cardiac, 196? Torpado Professional
Quoted: 812 Post(s)
Liked 335 Times in 234 Posts
Don't give up your day job.
Sorry to be negative, but the result of your work looks amateurish, poorly planned and unfinished. That said, no one expects perfection from a novice. If it is in you to keep at it, do so and your skill level will increase. Be prepared to make a mistake or two, as you learn. My guess is that Drillium Dude did not get it perfect, the first time out of the gate, either.
I have built lots of bikes, and not all of them turned out perfect. Even today, after hundreds of builds, I still goof, now and again.
randyjawa is offline
Old 01-07-13, 09:13 AM
Pars
Pars's Avatar
Bikes: '73 Raleigh RRA, 1986 Trek 500 commuter
Quoted: 42 Post(s)
Liked 10 Times in 7 Posts
Not bad for a first try. I'd probably practice on less valuable parts than Campy however
Pars is offline
Old 01-07-13, 09:25 AM
jbchybridrider
jbchybridrider's Avatar
Quoted: 215 Post(s)
Liked 305 Times in 129 Posts
I just see the main excavation work done. Go at them with a small round and flat file and a little patience and they'll come up a treat.
jbchybridrider is offline
Old 01-07-13, 09:33 AM
puchfinnland
MIKE is my name!
puchfinnland's Avatar
Bikes: hans lutz, , puch mistral ultima,2x Austro Daimler Smoked chrome Ultima,Austro Daimler Mixte,Austro Daimler 531 mixte, flying arrow,F Moser,
When you guys have done this work yourself then give the guy comment,
It's not that difficult but it's not that easy either!
it looks pretty good to me, I might not have gone so thin on the top but that is taste.
i did one seat post and it was a lot of work to make it look good.
puchfinnland is offline
Old 01-07-13, 10:43 AM
Andycapp
Andycapp's Avatar
Bikes: Tommasini Super Prestige, Kamra Triathlee, Nishiki Tri-A equipe', Sakai 2000
+1 They don't look too bad, just not quite finished Get your self a set of jewelers files to smooth out the insides. Depending on the bits you have for your Dremel you could maybe get a bit closer with that before going to the file work, let the cutter do it's job- don't push too hard or let it chatter. Slow and steady wins the race here, if get in a hurry you risk removing too much.
-Andy
Andycapp is offline
Old 01-07-13, 10:51 AM
JPZ66
JPZ66's Avatar
Bikes: 1949 'Italian' , 1950 San Giusto, 1897 Union, and a number of "projects"... 198? Grandis, a couple of Mixte's...
Being at work, I can't see the photos, but just a general comment about cutting aluminum with files, burrs and bits...keep the cutting surfaces lubed with WD-40 so the alloy does not clog them.
Joe
JPZ66 is offline
Old 01-07-13, 10:55 AM
Italuminium
Cisalpinist
Italuminium's Avatar
Bikes: blue ones.
He, those lil' triangles at the base of the teardrop shape are a beehutch to get rid of. As others suggested, remove the P's, polish and fill in the filed area's with some model paint. I'll post some images of my own try (and subsequent failure) once I unearth them - it's a bit of a mess in casa Italuminium at the moment due to my move
Italuminium is offline
Old 01-07-13, 12:53 PM
Chombi
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 142 Post(s)
Liked 5 Times in 5 Posts
I'm not sure, but you might be able to just get rid of the center web on those levers. Simplex had been making levers with what seems to be much less material on it without problems.
Although these are retrofrictions (which might lessen some of the stress on the levers),
IIRC, they also had a version with similar minimalist design that was just plain friction style.
Chombi
Chombi is offline
Old 01-07-13, 12:57 PM
shoota
shoota's Avatar
Quoted: 1281 Post(s)
Liked 156 Times in 121 Posts
I'm not gonna lie it hurts me a little to see those chopped up. What's the purpose of this again?
shoota is offline
Old 01-07-13, 01:05 PM
rootboy
rootboy's Avatar
Quoted: 542 Post(s)
Liked 94 Times in 51 Posts
Joe
Good advice Joe. Especially with fine little Swiss jeweler's files. And ESPECIALLY with aluminum. But you know what I use? Chalk. Stick is about an inch in diameter and four inches long. Meant for filling the teeth in files so they don't load up. Works great.
As for the OP's efforts here, I agree, this is one tough crowd. A little more work cleaning up and these will be nice, Zieleman.
rootboy is offline
Old 01-07-13, 01:08 PM
rootboy
rootboy's Avatar
Quoted: 542 Post(s)
Me too, a bit. I'm very ambivalent about altering Nuovo Record parts. But you should see the key fobs I'm going to do!
Well, at least the OP used the later style levers.
rootboy is offline
Old 01-07-13, 01:51 PM
JPZ66
JPZ66's Avatar
Is this some specific type of chalk ? Hadn't heard of this and would like to know more. I'd much rather have a dry 'lubricant' for these ops.
Joe
JPZ66 is offline
Old 01-07-13, 01:54 PM
Catnap
zungguzungguguzungguzeng
Catnap's Avatar
Bikes: Zunow, Jo Routens, Bridgestone, Mercier, Cannondale
Liked 5 Times in 3 Posts
i think it's a great start, but not quite finished. get those little jeweler's hand files and go to town.
Catnap is offline
Old 01-07-13, 02:05 PM
shoota
shoota's Avatar
I can't wait to see them, I've always wanted one just don't know how to go about doing it.
shoota is offline
Old 01-07-13, 02:23 PM
rootboy
rootboy's Avatar
Quoted: 542 Post(s)
I'll try to remember to let you know when pics available. I'm going to use levers, since I have some old ones Not sure if you saw Drillium Dude's nifto derailleur plate version. Worth another look here. Might try one of these too.
rootboy is offline
Old 01-07-13, 02:24 PM
rootboy
rootboy's Avatar
Quoted: 542 Post(s)
Joe
PM sent Joe. I'll send you a hunk.
rootboy is offline
Old 01-07-13, 02:27 PM
Drillium Dude
NNNN
Drillium Dude's Avatar
Quoted: 1543 Post(s)
Liked 809 Times in 423 Posts
This exactly - great job on the main drilling portion! Proportions look good, so a little file-work will finish them off very nicely. I'm looking forward to another pic of the final result
BTW, keep the webs! Although these are the thicker later models, they still flex too much and can break if they're completely hollowed out. Don't ask me how I know
DD
Drillium Dude is offline
Drillium Dude
NNNN
Cool-points
DD
Old 01-07-13, 02:32 PM
Zieleman
Zieleman's Avatar
Thanks for the feedback y'all! They are indeed not quite finished... I tried to do some finishing touches with sandpaper and a dremel touch-up bit and removed the p's, but will probably need the above mentioned juwelers-files to make it look better.
This one is meant to be a learning project before i start to drill on other stuff (though I already had a NR RD in mind...) and all your comments are very helpful when it comes to critics and ideas on shape, tools and standards. I'll post some more pics of the progress when able.
Cheers!
Zieleman is offline
Old 01-07-13, 02:33 PM
rootboy
rootboy's Avatar
Quoted: 542 Post(s)
DD
Important info D.D. I like the center web too, for aesthetic reasons. Just needs to dress it a bit and remove the P's and they'll look great.
rootboy is offline
Old 01-07-13, 02:35 PM
shoota
shoota's Avatar
Very cool!
Cool-points
DD
Good enough for me
shoota is offline
Old 01-07-13, 03:15 PM
Italuminium
Cisalpinist
Bikes: blue ones.
DD
Oh bollocks, I think I went to far with my shifters then. Ah well, they're meant for the ALAN, which is a suicide bike anyway. YOLO. Campanyolo.
