Ted Williams Tote Cycle
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 697 Times
Came across this interesting “take apart” bike on Craigslist nearby.
https://annarbor.craigslist.org/bik/...860313285.html
looks quite interesting
Bad example
Quoted: 825 Post(s)
Liked 209 Times
A friend of mine (and a one-time poster here @Peg ) has one, which her dad bought years ago. It is a heavy bike but quite cool. It works about as you would expect a heavy steel-wheel bike to work, so good for short flat trips when it is dry.
Schwinnasaur
Quoted: 380 Post(s)
Liked 106 Times
I have 3 Tote Cycles. The were made roughly from 1965 to 1975 plus or minus a year. Early ones were made in Austria and the last ones were made by Huffy. Black ones were coaster brake single speeds and the gold or brown ones were 3 speed coaster brakes. Heavy good riding bikes that are unique but are not really folding bikes. They can be split in half to be put into a car. These are 2 of mine. Roger
ToteCycle Rider
Refurbishing
Bought one a few months ago.
LOVE IT, but I want to change a few things.
Currently, there are two different tires: 20x2.25 and 20x 1.95.
Which is the best/ correct size for riding around on sidewalks and in bike lanes?
It looks like you have a different seat post. I want mine higher as well. What size seat post do you have?
Thanks
Thanks
Quoted: 380 Post(s)
Liked 106 Times
Tire quality is more important than size. Higher pressure tires will ride easier. Avoid knobby tires. That is the factory seat post on my bike in the pictures. Many seat post sizes are available and so need to measure the diameter of yours and order the length you want/need. Roger
PS The reason you need to measure your bike for seat post size is the earlt bike were made in Austria (metric sized)) and the later bikes were made by Huffy (English sized). Roger
ToteCycle Rider
Sears Tote Cycle
Had my seat post measured : 24.8 diameter. I was told it would be no use trying to find one that is longer. Most standard ones are 25.4 or larger in diameter. But I see in your pictures, you have a higher post... where did you get it?
My bike looks exactly like yours as far as the frame and color.
It’s a 3 speed (Sturmey Archer S3C 1972 28 hole hub + coaster brake l), but the shift indicator broke off. Now I need to have the indicator replaced or have the whole hub rebuilt (quoted $150!!!). It’s really gunky, too and need cleaning.
I need to polish the front carriage and brake as well, plus replace the brake pads.
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
While no civilized man would say this, the hubs some times respond to soaking and lube through the shifter, though there are vids on taking them down to do it right.
Seat post may adapt with using an extension.
See the Brompton option to see an example. There are also taller seats and a suspension mount that might work
I ended up using 3 colors of chain and a pink shift cable. I stick welded a little piece of 1/2" pipe to mount the stik shifter.
