Modern RD on Old Bike with Friction Shifters.
Quoted: 5 Post(s)
Hello,
I have searched for answers to this but cannot find one definitively. I have a 1985 Schwinn Worldsport roadbike which has a Shimano Light Action groupset. It has stem mounted friction shifters that click but are not indexed. The freewheel is 7 cogs and the crankset has 2. My rear derailleur broke and I need to replace it. I am a little hard up for cash as I was recently laidoff due to Covid 19. I am trying to keep this beast running til I am gainfully employed again; it is my outlet for health and sanity right now!
I went to the LBS and they told me I need to replace the RD and shifters. Which means upgrading to indexing. I "think" this is not quite true. That all I need to do is replace the RD. My understanding is that friction shifters are pretty forgiving and RD's don't care how many gears you have? What I'd like to do is use a modern RD since they don't make mine any more. Can I use a something like a Shimano Claris 8 speed or Sora 9 speed RD with a 7 speed freewheel and friction shifter? Please let me know and thank you for the help.
Really Old Senior Member
You DO NOT need to replace the shifters.
Anything from a low cost Shimano Tourney will work.
Do go too far up the food chain. As the number of speeds increases, the cage gets narrower.
Yes, friction shifters whatever brand work with whatever brand RD. Don't go higher than a 9 speed RD or you won't be able to set the stops right and your chain might slip off the cogs.
Quoted: 5 Post(s)
Thank you for the swift replies Bill and Dwillems! So I should try to get a 7 speed RD for the best match? I ask because it looks like that is the Tourney one and it looks like it is made of plastic. I want to make sure I don't get something too cheap that is prone to failure in a short period of time.
Friction shifters on a mid-80s road bike? Basically any lower-end RD will likely work. You probably want to avoid 10/11/12-speed stuff because the cage might be too narrow for the chain. If you're unsure, the safe bet is an entry-level MTB derailleur like an Altus M310 or Acera M360; they'll work great with almost any friction drivetrain from that era.
Quoted: 1819 Post(s)
Liked 1,693 Times
A Claris rear derailleur would be ideal for this application. Designed for 8 speeds, it can easily handle the width of chain you need. Good quality, it would last for years. No need for an indexed shifter
Likes For alcjphil:
Longer-cage derailleurs have more wrap than shorter-cage derailleurs.
Quoted: 2338 Post(s)
Liked 2,822 Times
IIRC the light action (which was underated) was short chage...... so almost anything will work..... and if $$ are tight you might see if there is a bike coop close or a different LBS that deals with older bikes... you might be able to get a used one really cheap
Likes For squirtdad:
Quoted: 5 Post(s)
Okay, so the Crankset is 52/40 and the freewheel is 28-11. So, based upon the formula above, the slack would need to be 29. So, it looks like a Shimano Claris shortcage would work since the total capacity is 37 teeth. Thank you folks for all the help. Also, will check out a coop as it would be cool to just replace it with another light action rd.
Quoted: 2952 Post(s)
Liked 3,106 Times
Once you get 10 posts, could you post a picture of your bike? An ice blue 85 WS was my parents' HS graduation gift to me and I rode that bike through college, law school, and commuted to my first job on it. I wish I still had it.
Quoted: 1324 Post(s)
Liked 927 Times
I can send you a rear derailleur. Whereabouts are you located?
Cheers
Cheers
Quoted: 5 Post(s)
Wow! Thanks Miele Man. I am in Arizona USA. It looks like you pm'd me but I need 10 posts to see it. I will get there. I suppose I'll start an introduction thread to hit the needed post count.Thank you for your kind offer!
Liked 927 Times
Good luck and cheers
Likes For Miele Man:
Yes, shimano Claris is their entry budget grade. I have it on my bike and love it.
Length depends on your gears. The bigger the difference in your gears the bigger the cage. So if you have 3 gears up front get a long cage. 1 gear up front you might be ok with a short cage. please don't take my weird though since I'm not that experienced with this part. Please wait for someone to comment or do a search. Park tool and shimano's website has good info on it.
Quoted: 5 Post(s)
Quoted: 5 Post(s)
Worldsport
Likes For prighello:
Liked 927 Times
Can you post another image but from the drive side?
Cheers
Cheers
Liked 927 Times
Okay and thanks. I'm pretty sure I have a Light Action rear derailleur in my rear derailleurs box. I'll get it into the post for you tomorrow.
Cheers
Edit. I looked through m y spare parts and I do have a Light Action rear derailleur. I'll send it out tomorrow.
Cheers
Cheers
Cheers
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
1) If you haven't changed the gearing, get one similar in length to the original unit.
2) When in doubt, go longer. There is no penalty besides a few grams extra weight in having a longer cage than is necessary. But too short a cage can mean either not being able to tension the chain properly over the full range of gears, or damaging the derailleur by exceeding its range.
