How foolish would this be?
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Unrelated (mostly) to my other effort to replace the spring in a LePree derailleur, and inspired by previous efforts by The Golden Boy (here) and coolkat (here), I've been trying to transplant a 3 pulley cage onto a SunTour Superbe Pro rear derailleur. The Superbe Pro uses the same pulley cage spring mechanism as their 3 pulley derailleurs, so I thought it might work. It bolts on easily enough, but there's a problem. The pivot stop on the body of the Superbe Pro derailleur is about 90 degrees rotated from the stop on the 3 pulley derailleurs, so it stops here (see pivot stop pin in the red circle):
The result is that it doesn't give me the extra chain wrap I need to use a triple crankset.
So, I was thinking about how I could solve this problem. My first idea was to tap another hole in the cage and move the stop pin right next to where it says "3 pulley system". I think that would work, but it would require me to figure out the threading of the stop pin, buy a tap, drill a hole, etc.
Then a second idea came to me. What if I just removed the stop pin. The chain will stop the pulley from folding back too far as long as the chain is engaged. Bad things could happen if I dropped the chain, but possibly(?) not too bad. So I tried it out.
It looks (!) like it's going to work. What could possibly go wrong?
What do you think?
What do you think?
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 4511 Post(s)
Liked 6,378 Times
I think you need to dial it in and go for a test ride, cautiously.
Likes For merziac:
Quoted: 472 Post(s)
Liked 1,028 Times
IIRC the stop pins/screws are a convenience vs a necessity. Convenient for the original assembler and for the owner while maintaining the bike. During operation it does nothing so, as you know about RD rotation and can accommodate that while removing and installing the wheel and while changing the chain, then you should be fine. "Weight reduction". However check to be sure nothing is damaged if the cage ever pops back (broken chain, fumble fingers while out on the bench, etc). Does the cage hit some other part of the RD hard and damage it or does it catch a finger and damage that? If so, think on that one a bit.
On the RDs I've worked on or overhauled, some cages relax gently after that pin is removed. Others have much stronger torsion springs and can snap back quite smartly. Could even pinch a finger badly in a scissor action. I don't recall one that would "wap" the RD body and damage it. It also depends on how the high limit screw is set.
Likes For Prowler:
Quoted: 3810 Post(s)
Liked 6,690 Times
I had a Shimano Deerhead RD in use some time back in which the stop pin had gone missing. As you note, it was all fine as long as I didn’t have to remove the rear wheel, say like when on a long ride and I got a flatted rear tire and putting it all back together was an origami experiment that failed. So, yeah.
Likes For nlerner:
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
Yeah, rear flats are enough of a problem without compounding it.
Bikes: Yes
Liked 3,868 Times
It turns out that if I use the chain hanger braze-on, the cage stays put pretty well even with the wheel off.
My Bikes
My Bikes
Likes For Andy_K:
Friendship is Magic
Bikes: old ones
Quoted: 26411 Post(s)
Liked 10,377 Times
...they laughed at Galileo, too. Well, actually they stopped laughing after a time and sent him before the Inquisition. YMMV
Likes For 3alarmer:
Quoted: 1163 Post(s)
Liked 442 Times
Is it possible to wind the spring another (almost) full turn and use the existing stop screw in order to get the chain wrap you need for your triple? Or is the spring too stiff?
Bikes: Yes
Liked 3,868 Times
No, the problem isn't spring tension. The problem is that the pin stops the derailleur where it's shown in my first picture regardless of spring tension. You can't even manually move it past that point.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
Spaghetti Legs sent me this picture when I told him what I was doing.
Totally accurate, right down to me beating on this when it wouldn't work and then later hearing grumbling coming from the garage. (OK, that last part isn't entirely true.)
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 887 Post(s)
Liked 335 Times
It doesn't need to be true, it only needs to be repeated over and over and over, and then it'll be enough true.
Likes For dweenk:
Bikes: Yes
Liked 3,868 Times
It provides extra chain wrap. When the derailleur cage is forward, the third pulley isn't engaged and it acts like a short cage 2 pulley derailleur. When the cage swings back, the third pulley engages to force the chain to cover more distance. A longer cage accomplishes basically the same thing, but this is weirder.
My Bikes
My Bikes
Likes For Andy_K:
Liked 6,690 Times
Three pulleys is 1/3 cooler than two.
Likes For nlerner:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
Grant Petersen would say it's 0.333 cooler, because metric.
Liked 6,690 Times
Liked 5,795 Times
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,095 Times
Its actually 150% cooler. That’s OK though, I know you’re an English major.
Likes For Spaghetti Legs:
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
But that's assuming that a derailleur's coolness is directly proportional to the number of pulleys. I submit that though those three-pulley derailleur's are pretty cool, the S-1 (with only two pulleys) is cooler still.
Well, at least it's weirder.
Likes For rhm:
Quoted: 500 Post(s)
Liked 466 Times
I think it’s extremely cool and a worthy quarantine project.
Bikes: Yes
Liked 3,868 Times
Bikes: Yes
Liked 3,868 Times
Bikes: Yes
Liked 3,868 Times
Yeah, that's some next level stuff right there.
My Bikes
My Bikes
Likes For Andy_K:
