Identifying unknown frame
Hello everyone,
Recently came in possesion of a frame which i cant identify and the owner has no idea either, would be grateful is maybe somebody recognises at least what the manufacturer is
Here is what pieces of information i do have
-Likely italian frame
-Italian thread BB
-Gipiemme dropouts
-Unknown lugs
-26.2 or 26.6 seat tube
-2.189kg frame, allegedly its columbus aelle
-inside of headtube is red, so im thinking it could have been painted red previously
For some reason forum wont let me upload so i put the full image set on imgur
imgur . com/a/ovOI7gU
Thank you, regards
-Italian thread BB
-Gipiemme dropouts
-Unknown lugs
Thank you, regards
Quoted: 702 Post(s)
Liked 672 Times
async , you'll need 10 posts before you can post photos.
Do you intend to build it up and ride it, or sell it?
Im building it up with the 600 tricolor groupset, just put a coat of primer today, will finish up the paint soon, wanted to also post that here but guess my plan is foiled now!
If i were to sell it, i dont even know how to appraise it (i didnt ask for appraisal on purpose, because then it'd be in the wrong forum section).
Time to post more on the forums i guess.
I just wanted to know what frame it is (or hell, even the lugs), just to know about the history of what im sitting on and what i have. Im tired already of people asking me "cool, what frame is it?" and me replying "dont know, guy selling also didnt know".
There's some knowledgable folks here so i wouldnt be surprised if someone figures it our by some detail by some off-chance.
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,469 Times
Likes For obrentharris:
Quoted: 4722 Post(s)
Liked 3,036 Times
It looks pretty generic and early 1980s. A 26.6mm post would be one size too small even got Aelle, though it would be appropriate for Zeta. 26.2mm was common for a lot of Italian light weight hi-tensile steels. However, I typically wouldn't expect frames with these tubesets to have investment cast fittings and reinforcing tangs.
Originally Posted by [color=#222222
T-Mar]It looks pretty generic and early 1980s. A 26.6mm post would be one size too small even got Aelle, though it would be appropriate for Zeta. 26.2mm was common for a lot of Italian light weight hi-tensile steels. However, I typically wouldn't expect frames with these tubesets to have investment cast fittings and reinforcing tangs.
Quoted: 790 Post(s)
Liked 1,760 Times
Thank you Brent!
Interesting, that's already telling information! My vernier says its 26.2, but when i put a 26.2 seat its not like its loose, but it takes a bit too much travel to clamp down for my taste, so im thinking it might be even 26.4 or 26.6 (but 26.4 isnt that common, is it?)
imgur.com/UWCPXVs.jpg
I have a 6401 crankset and some other bits and pieces in the box behind as well
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
the builder was trying to be clever with the upper headlug cut like DeRosa
and the lower one cut like Masi. the under BB cable routing tells us it is 78 or later (usually)
Stop reading my posts!
Quoted: 1442 Post(s)
Liked 1,059 Times
All those GPM bits (DOs, stay bridges) and the slotted BB shell plus the BB threading certainly says "Italian" but if your seatpost size can be confirmed with a better tool than calipers (which unfortunately are not the best for such an internal tube that can become distorted) POSSIBLE this is an oddball that used METRIC tubing. Very rare for an Italian builder but not unknown and would explain if this is actually 26.4 or 26.6.The stay caps ring a faint bell and may be a distinctive clue, can you add some close-ups to your "album"?
I experimented a bit with seatpost and beer can shims. I think its probably not 26.6, I could fit 26.4 there but it was a bit tight, 26.2 also worked, and 26.0 was a bit loose. I think im going with 26.2 just because its the more common of the two between, i think (26.4 and 26.2).
I'm not sure what to infer from that but im kind of pissed everyone decided to make seatposts in steps of 0.2mm, just enough to make things fit poorly, not enough to make any functional difference
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
Welcome to the "Looks nice but I have no idea club"
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Liked 1,059 Times
And still no idea but doesn't look like the slot in the seat lug is TOO distorted so maybe the apparently too-small seat posts are not that far off, but I have no better idea from seeing these except would have a trusted shop with a sizing tool check the seat tube out (IF that was possible in the current lockdown in my town) and notice that the stays appear to be small diameter at th top("pencil stays" or are they "double tapered"?) which are a bit unusual for the apparent era, plus the "ears" have been filled which is a good touch and again something more seen on higher-end frames then ones built from lower grade/price tubing. One more thing (that would have been best to check when the tubes were not painted) but what are the Outer Diameters of all 3 main tubes, best to use a digital caliper or a dial caliper that shows metric fractions?
here's the shots for others to judge
Likes For unworthy1:
Likes For armaan:
I measured out the tubes and they seem to be of the following outer dimensions
Headtube 31.5mm
Downtube 29mm
Seattube 29mm
Top tube: 25.4mm
seatstay double tapered 10.4>>14>>10.8
