What are the Do's and Don'ts of tubeless tyres?
Bikes: 2019 Giant Defy Advanced 2
Quoted: 11 Post(s)
Hi everyone,
Just wanted to ask what are the do's and don'ts of tubeless tyres? How do you maintain your tubeless setup besides topping up sealant?
Im asking these question at the back of an experience I had recently. I have a set of the new Schwalbe Pro Ones recently installed together with Stan's sealant. After 2 months of not cycling due to the current situation, i took my bike out for a ride. After about 150-160km clocked on this set of tyres, i found a cut on the rear tyre which the sealant wasnt able to seal properly. Brought the bike to my LBS and was told if not cycling frequently, would at least need to spin the wheels to allow the sealant to coat the tyres again and also so that the sealant doesnt 'hardened'.
Is this a common practice if not cycling for awhile?
Quoted: 3949 Post(s)
Liked 7,295 Times
Quoted: 6193 Post(s)
Liked 4,809 Times
I don't do tubeless..... yet. But I'd think that irregular use of a bicycle and long periods between rides will greatly detract from the ability of sealant to work properly. I just wouldn't be tubeless on a bike that's going to sit for two weeks much less two months.
Likes For Iride01:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Check and top off the sealant every month or two. Or if time has passed since the last ride, check before heading out. The bike can sit without sealant forever; the tires will stay put even when fully deflated (at least mine do). The sealant is your spare tube, only it's carried inside the tires instead of in a pocket or bag - don't leave home without it.
Likes For sfrider:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 585 Times
Hi everyone,
It's clearly a good thing to spin the wheel from time to time when not using it, but as long as you maintain the setup properly, you should be fine. Some people measure the amount of sealant remaining inside the tire using syringes, others will simply unmount it after a while, clean it, reinstall it and put some fresh sealant after.
If you don't cycle much, I'd stay with tubes to avoid the extra hassle. If your bike came factory with TL tires, you could always wait until having to change your tires and switch to tubes.
Quoted: 20810 Post(s)
Liked 9,456 Times
A) Stan's sucks for road bikes
B) I'd agree that tubeless might not be for you if you're not going to be riding very regularly
C) this is the thread with the most comprehensive collection of tubeless best practices thus far - https://www.bikeforums.net/road-cycl...eless-not.html
Quoted: 11 Post(s)
Quoted: 11 Post(s)
Thanks everyone for the comments so far..
I prob still want to continue trying tubeless since this has only happened once so far..but trust me if this happens again, I would think going with tubes would be the best for me..
However, i have another question about tubeless..is it normal to lose pressure over a few days? I usually pump my tires at 90psi rear and 85psi front on the pro ones since im quite a heavy rider..about 4 days later, i find it drops to about 60psi..is this normal?
Likes For noodle soup:
I use Orange Seal in my Schwalbe Pro One road tires. IME Stan’s is good up to about 40 psi, Orange does better with higher pressures.
Likes For jimincalif:
Quoted: 11 Post(s)
Quoted: 1743 Post(s)
Liked 1,281 Times
My "do" is buy the Mavic system. I did and I'm not going back...ever.
Quoted: 11 Post(s)
https://www.youtube.com/watch?v=ALVtgcY1YeM&t=83s
Liked 1,281 Times
Quoted: 11 Post(s)
Quoted: 4717 Post(s)
Liked 1,882 Times
One question I've been thinking about a lot when I ride is, what's the better pressure to prevent the smaller punctures, if that even comes into play.
