Bikesdirect Mini Velo upgrade thread
#926
My mini velo currently snoozes in the closet of my new loft apt. Waiting for the sunshine.
So much more room even has the Dahon Boardwalk in there.
#927
Quoted: 5 Post(s)
Liked 8 Times
I've made a number of "upgrades" to my bike the last week. It's turning into a real money pit!
So far, I've removed the two front chainrings and replaced it with one narrow wide 50 tooth chainring (Qik brand from Amazon) and removed the front derailleur. I attached the new chainring to the inside position. I think I read on the thread that a 54 tooth chain ring could fit attached to the inside position, though even with the 50t, it seemed close enough to the chainstay.
For a few days I tested out a $10 45 tooth chain ring (Meijun brand from Amazon) that attached to the outside position. The chainring was cnc'd to be offset so when it's bolted to the outside position, it actually centers the teeth between the outside and inside positions. Unfortunately, anytime I shifted to the largest rear cog, the chain would drop off the chainring. With the 50 tooth narrow wide and attached to the inside position, I did not have the chain drop problem. Two other observations: I discovered that the stock chainring bolts work with a single thicker narrow wide chainring. Second, with the Meijun chainring (maybe with the stock chainrings) I noticed that when the bike was on the largest rear cog and I back pedal, the chain would drop from the largest rear cog to the next gear down. With the inside positioned narrow wide, I don't have this problem. I guess the inside position of the chainring is the natural optimal chainline on that Nano.
I changed the cassette to a sunrace 11-32t. Another couple of observation: There seems to be enough grease on the rear hub. Grease was spilling out from inside the spindle. And the old cassette was not very tightly installed. The 50t and 11-32t cassette seems like a good combination for me. I'm just riding around for fun and not trying to keep up with road bikes.
I installed SKS 20 inch B53 fenders. It fits perfectly. The fork's fender mounts was crookedly tapped on one side. Or maybe I just cross-threaded and inadvertently retapped. It was hard to screw in in the first place because of the threads were painted.
I also rigged a Wald 137 basket to the front of my bike with some Tubus rack mount parts and hardware from McMaster Carr.
Unfortunately, the first upgrade I planned on making I'm still waiting for which was Dimensions Urban cruiser handlebars. That should be arriving tomorrow.
I also should be getting a Sunrace M96 8 speed indexed thumb shifter soon. I just can't do the downtube shifters. I feel like I'll crash into a parked car.
I'll try to post some pictures after I complete this first round of upgrades.
Likes For cadeluxe:
#928
cadeluxe
Please do add pics when you can. I want to see the fenders attached! What size tires are you running? As luck would have it I have so many parts saved up I really did not have to spend bucks for my upgrading. The stem was one exception.
Rain went away finally so with the weekend free from messenger duty it was time to mini velo play! The Mercier in front of one of the theater shows I caught when I was racing in Germany.
Likes For 3speedslow:
#929
Quoted: 5 Post(s)
Liked 8 Times
Regarding maximum tire sizes, where is it on the bike that the clearances will be tight when we go near 1.75 inches and above?
Top of the fork, brake calipers, chainstay, chain, some other area I'm not considering? From what I can tell, there is at least an extra 1/2 - 3/4 an inch of clearance on each side with my stock 1.5inch Kendas.
Thank you!
Thank you!
#930
Quoted: 5 Post(s)
Liked 8 Times
Here's the bike after a few but time consuming updates.
My Nano.
In summary my upgrades are:
50 tooth narrow wide chainring from Amazon (Qik brand? The chainring has no writing at all on it.) Removed front derailleur.
11-32t sunrace cassette.
Dimension Urban Cruiser 70mm rise 50 degree sweep.
Wald 137 basket attached with Tubus (320mm) rack hardware and p-clamps, spacers and hex bolts from McMaster Carr. And T bracket from home depot to mount to the fork brake crown.
Sun race 8 speed indexed thumb shifter. The 1x and thumb shifter is a total game changer.
Tektro FL750 brake levers
Random budget brake and shifter cable sets from Amazon
Shimano downtube shifter stop converters
SKS 20 inch bluemels 53 fenders
I just received a Selle Royal Ondina saddle which I installed after I took the picture of the bike.
I'm expecting to receive a pair of Tioga Powerblock 1.6 inch tires soon.
I'm considering a new stem because I'd like to get my handlebars a little higher. It looks like the Nitto Technomic is the goto option. Does it get higher than the stock stem? I also saw a "hiland" brand stem that goes pretty high. Are there any opinions on that one? $12.99 is pretty tempting.
https://smile.amazon.com/Hiland-Bicy.../dp/B082HP2SKD
My Nano.
#931
cadeluxe
The Technomic is a great choice. The one I went with on mine. I could have stuck with the original but wanted the option the Nitto gave to lower or raise the stem as I wanted for fast or tour riding.
Nice bike work on your mini velo! How does the basket ride on that? Is it low enough to not cause a load weight problem?
#932
Quoted: 5 Post(s)
Liked 8 Times
cadeluxe
The basket rides pretty well. I had the same basket installed to a front rack on my Trek FX. When I carried stuff in it, the steering definitely felt sluggish, floppy and heavy. With the basket loaded and installed low on the Nano, the steering feels like the trek fx without load on the front. I can see why many cargo bikes use a 20 inch wheel in the front with the rack mounted low. As far as installation, originally I mounted the daruma brackets closer to the front of the basket, but that made the rear corners of the basket super flexy because it was only being supported by the center T bracket bolted at the brake. I moved the daruma brackets closer to the middle and that distributed the entire weight of the basket and contents over to the two aluminum stays. There is still some flex, but it's more of a springy flex instead of the flex where it feels like it will permanently deform the metal.
The Tioga Powerblock 1.6 inch tires are super light compared to the stock Kendas. There's still a little bit more space on the sides of the tires. Maybe 1/2 inch from the chainstays. I'm not sure how close it is to the top of the fender though.
I finally was able to build up the courage to take apart the wheel hubs and check the grease. The hubs was slightly tight so it was nice to be able to adjust that. The rear freehub had grease spilling out, but when I actually looked inside there really wasn't much grease inside like everyone else has mentioned.
Next things I have to build up more courage to do is greasing bottom bracket threads and greasing headset.
This has been an overall pretty fun learning experience. One day I might be confident enough to rebuild a steel thrift store bike!
#933
Long day out with the Mercier. Left the loft at 9am, back 8 ish. Everywhere.
Pedals are platform cause I want street shoes when I use this mode of transportation.
#935
Thanks! I used the OEM components for awhile but always like to change out my bikes how I like them. Most everything I had already except the Nitto Technomic stem so it was a cheap upgrade.
The lock is an Arbus, great lock that I have used for years both casual and for messenger work. My area is more of a “snatch and ride off” criminal mode. I recently bought a new one, the same model and found out they beefed it up by another pound. 3 pounds lock and heavy Chrome bag has me sweating bullets in the heat!
#937
Just found out those Evo stands which slip over the nondrive side rear does NOT allow the wheel to rest on the floor. Might have to do modification work!
#938
And the Mercier Mini Velo has SOLD OUT at BD.com!
Hopefully Mike has plans for another batch.
#940
Quoted: 7359 Post(s)
Liked 2,502 Times
Abus, not Arbus.
#941
Changed the saddle from a B17 narrow to a B17 standard. Another good Brooks for the slight drop from saddle to bar. Green also goes well with the black. Also installed black half cages to help hold my shoes to the MKS G-9.
For a overnight out of town visit I packed everything I needed into my longflap Carradice saddlebag. Nice to keep a bag off my back when I am not working!
Kept the bag stable with the rack carradice sells.
#943
Liked 2,502 Times
That's really nice, @3speedslow.
#944
Bikes: Vilano Urbana, DownTube FS9, Montaque paratrooper, Nano mini-velo, Motobecane CX, Raleigh 20, MIFA folder, ROG Pony, Iverson Grand Touring folder, Exclusiv German folder
Quoted: 168 Post(s)
Liked 192 Times
Latest edition, DollarTree flowers. Took it to the Safeway today.
Dollartree flowers to brighten your day.
#945
Probably best to contact BD directly and ask.
#947
I am so ready to change out the price point headset on my Mercier. It just does not stay tight. When the time comes I will go from the 30.0 to 30.2 and open up the choices. A nice silver Tange...
#948
i think there will be another order from Mike. Every time he has brought them to this shore they have sold out. When... I do not know. This Covid mess is screwing the whole order-timetable up. Last batch which mine came from was delayed.
#949
Another long weekend to enjoy the Nano. Long solo ride followed by a coffee shop. Short grocery run till I get my BOB trailer up and running, then home.
This shows the stairs I climb hefting the Mercier, no problem here. Only change lately is attaching another Carradice saddlebag to the bike, a Junior.
#950
Noticed a lot of brake dust on the rear wheel so I thought it was time to upgrade to some Jagwire. OEM ones did okay but sure noticed the weight saving when I hefted the new and old.
