700 x 19 or 20 Tires
Quoted: 235 Post(s)
Liked 351 Times
Wider tires seem to be the train everyone is jumping on. Is there anyone out there, like me, who used to use 19c or 20c clinchers and never had a problem?
I have searched, but is anyone making a 19 or 20c skinwall-type tire anymore? I think I had Trek and Panaracers "back in the day". It seems "the man" is forcing everyone into blackwall wide tires!
Likes For Bianchi84:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
You skinny-tire diehards are coming out of the woodwork lately.
The Duro company still makes a 700x20C, not sure about availability: https://www.duro.com.tw/en/product/b...8ac0f67bb13a8/
Are you up for tubulars? There are a lot more options for ~20mm tires in that format. Maybe you could hit up Catnap for the wheels.
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
Quoted: 3515 Post(s)
Liked 2,928 Times
Quoted: 235 Post(s)
Liked 351 Times
Quoted: 235 Post(s)
Liked 351 Times
I know, right? I couldn't have written this better myself! I used to ride 700 x 20 Continentals back in the day. I was always curious to try the 19s, but never did. I'm riding 700 x 23 Veloflex Master skinwalls, and was happy to find those (they measure slightly narrower than 23 mm on my bike). I decided to buy a second pair while I could based on the market moving away from narrow, high pressure tires. Folks here seem more interested in "comfort" than the road feel of a nice high-pressure narrow clincher. Finding anything narrower in skinwall/gumwall has been difficult, although I do recall prior posts where some have been recommended. Good luck, and keep the faith!
Liked 2,928 Times
Yep. Same here.
Likes For smd4:
Quoted: 1873 Post(s)
Liked 692 Times
yawn
Vittoria makes several versions of their tire lineup in 23c and tanwall. 23c isn't much wider than 20.
https://www.biketiresdirect.com/prod...kaAkWUEALw_wcB
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Quoted: 581 Post(s)
Liked 921 Times
The other advantage of wider tires is suitability of the tires on rougher road surfaces - unless you are riding on a track or live in a wealthy area where the road gets repaved every time a pothole appears, you will be more comfortable on wider tires with a bit less pressure. You also get a second speed advantage on a rough road because if your tire provides more 'suspension' (absorb road irregularities better) then you don't have as much 'suspension losses' (bike and rider being pushed vertically by bumps which costs forward momentum).
The only advantage of super narrow tires is a bit of an aerodynamic benefit - especially if the tire width closely matches the rim width, and especially especially at higher speeds when riding alone. If riding in a group or at moderate speeds, wider tires are likely going to be faster, all other things being equal.
Likes For ClydeClydeson:
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
Bikes: Road: 1972 Raleigh Competition,1989 Marinoni, 1990 Limongi. MTN: 1990 GT Team Avalanche, 1991 Rocky Mountain Blizzard, GT Team RTS , Rocky Mountain MSL 50 Element, CCM fat bike
Quoted: 35 Post(s)
Liked 81 Times
Likes For Paul Waque:
feros ferio
Quoted: 1393 Post(s)
Liked 1,331 Times
I prefer 28mm or wider, although I have to limit the Bianchi to about 26mm (28mm callout size Continentals).
Liked 2,928 Times
Are you really trying to tell me my 23 mm Veloflexes at 140 psi “deflect” more than a 38 mm tire at 80 psi? If so, the “prevailing wisdom” doesn’t seem too wise to me.
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
i've noticed that nice 23 road tires are often heavily discounted because no one wants them
same as gravel tires in cx widths like 30-33
Liked 2,928 Times
Quoted: 275 Post(s)
Liked 417 Times
Check out Soma too, they have/had some big discounts on their 23s because it's an abhorent size to their target market.
Quoted: 3464 Post(s)
Liked 2,831 Times
Michelin Elan
i even have a 27" version!?!
also likes the Avocet tire too, long gone now.
Quoted: 878 Post(s)
Liked 2,296 Times
I have bikes that are running different tire widths and I ride each of them according to my mood or type of ride I am planning. My Raleigh Competition GS has 700 x 23 tires and I always love riding that bike , I just make sure I have at least 100lbs in the tires before taking off on a ride. I have much wider tires on my Mondia , it came with 27” wheels so the 1 1/4’ wide tires I put on it measure 1.390” when inflated to 80lbs. If I plan on any sandy or gravely roads for long distances , I take that bike. The rest are either 25 or 28 wide 700’s or 27 x 1 . I am older now so it doesn’t matter to me too much, when I was younger I wouldn’t ride anything wider than 23’s. I always thought it was faster.
Quoted: 399 Post(s)
Liked 274 Times
Heya - would the group mind an attempt at some horse trading in the subject of this thread?
I was (and at heart still am) a skinnies-only kind of guy until age & infirmity moved me into today's "the bigger the rubber the better" mentality so I find myself left with several of what I think are really nice 23mm clinchers that I'd love to turn into some equally good 28 &/or 33/35c tires.
If such an inquiry is not permissible here I apologize and mods/admins please feel free to remove. If it is ok - thanks & let me know - I'm in the US...
Quoted: 767 Post(s)
Liked 1,898 Times
I went and did some sleuthing just for grins, and discovered...
...Excel Sports has Vittoria Corsa G 2.0 two-packs on sale for $99.99. New tan-wall 23s coming my way!
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
However, 35mm tire at 80 psi will likely be as fast or faster than any 140psi tire on any non-smooth surface, all other things being equal (ie similar tire construction). Super hard tires roll fast over smooth surfaces, but are a liability on rough 'real world' surfaces due to 'suspension losses'. Yes, they 'feel' fast, but the perception doesn't generally match reality.
Liked 2,928 Times
Pretty much the effect I'm looking for. It's called "responsiveness."
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 642 Times
It seems that 19's or 20's might give a "if you don't look too close" way to emulate the appearance of tubulars, without actually converting; perhaps for an infrequently ridden bike.
Maybe someone with more grounding in math than me could calculate the # of air molecules in each at those pressures... it would be interesting to know. It seems that would have to have an impact on deflection.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Liked 2,928 Times
And I'm sure fooling people into believing their tires were sewups was exactly the reason why companies manufactured them. How clever!
You don't need math for this one. Common sense will do.
Quoted: 987 Post(s)
Liked 642 Times
Not sure one must rely on that. Anyway, every time I read "fat tires are better", I keep thinking about the movie "Sleeper" where Woody Allen's character wakes up in the future and is told "Smoke this cigarette, we've found they are good for you"
Anyway, I presume someone knows how to calculate the volume of the two toroidal shapes in question -- but it won't be me!
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
And you may be confusing 'responsiveness' for 'harshness'.
edit:
looking at the Veloflex website right now and there is a 'suggested pressure calculator'. I selected 23mm tire and 95kg rider weight (highest value in drop down list) and the reccomended pressure is 8.1 bar (117 psi). The only tire on their website with higher suggested pressure is stated in bold as being specifically for 'time trial or track racing'. 23mm is also the narrowrst tire they sell as far as I can tell.
But you know better than the manufacturer, I am sure.
