Suntour Barcons: maintenance and adjustment
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 643 Times
But really, most any wide-blade screwdriver can work. If the shaft of the bolt intrudes, preventing the screwdriver from staying seated in the slot, you can make a custom tool by filing or grinding a slight recess in the center of the blade, leaving just enough unmolested on either side of the recess.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
Here's a somewhat cartoonish and technically incorrect drawing, advertising some brand I never heard of, but I think it gets the idea across.
You can buy them already hollow-ground, but I just grind my own, on a bench grinder or on the contact wheels of the belt-sander. Don't heat-blue them — grind lightly with frequent dunks in water. Usually takes under a minute.
Likes For bulgie:
Quoted: 2364 Post(s)
Liked 1,751 Times
I haven't seen any YT ads since I started using Brave as my browser. It's based on Chromium, which is open-source I believe? So it's similar to Chrome, but not made by Google. Its main claim to fame is that it's more security- and privacy-oriented, they don't sell your eyeballs like Google does.
I don't know how it blocks YT ads, they don't seem to advertize that as a feature, but it's a nice bonus. YT has not retaliated against me in any way. Maybe they'll find a way around the ad blocking, but so far so nice.
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
Looks like you had all the YouTube’s and diagrams available, but a trick I picked up was phone pictures.
take off a part, snap a picture, repeat.
then you have a photographic record of all your steps.
sometimes, If I’m really nervous I take two pictures per step, with the part on the assembly, and then again off the assembly.
it’s worked great for motorcycle carburetors.
