Looking for mirror
Bikes: 2018 Trek Domane SL5
Quoted: 81 Post(s)
Liked 5 Times
Looking for mirror
I have a Trek 850 Antelope that I am starting to ride a little bit more on roads. I was thinking about a mirror so I can see behind me. I kind of like those mirrors you wear on your arm. I don't want something that has to be cut into the handle bar or grips. I have seen some that attach with a strap, but little worried about those sliding around.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
Bikes: (2) 1994 Cannondale R900, red, Silver Trek hybrid
Quoted: 69 Post(s)
I recommend a mirror on your helmet. You can scan and see all around behind you. No shaking over rough surfaces. 3rd eye helmet mirror is what I use.
Likes For jack002:
Quite a lot of options from the big brands.
Mirrors - ZEFAL
https://www.topeak.com/global/en/products/mirror
Product categories | CATEYE
https://www.bumm.de/en/products/ruckspiegel.html
So you din't find anything related on the previous threads?
bikeforums.net/electronics-lighting-gadgets/1126363-mirror-suggestions-bar-end-shifter-bike.html
bikeforums.net/electronics-lighting-gadgets/1123569-mirrors.html
bikeforums.net/electronics-lighting-gadgets/949020-cat-s-eye-rearview-mirror-ergon-gp2-grip-bar-ends.html
bikeforums.net/electronics-lighting-gadgets/985146-problems-my-take-look-mirror.html
bikeforums.net/electronics-lighting-gadgets/970552-rear-view-mirror-recs.html
bikeforums.net/electronics-lighting-gadgets/955786-helmet-mirror-worth-suggestions.html
bikeforums.net/electronics-lighting-gadgets/452194-recycled-helmet-mounted-mirror.html
bikeforums.net/electronics-lighting-gadgets/917708-show-us-your-mirrors.html
bikeforums.net/electronics-lighting-gadgets/903560-mirrors.html
bikeforums.net/electronics-lighting-gadgets/841237-70-helmet-mirror.html
bikeforums.net/electronics-lighting-gadgets/822744-headworn-mike-fitted-rear-view-mirror.html
bikeforums.net/electronics-lighting-gadgets/783072-mirrors.html
bikeforums.net/electronics-lighting-gadgets/755534-diy-bar-end-mirror.html
bikeforums.net/electronics-lighting-gadgets/755372-mirror.html
bikeforums.net/electronics-lighting-gadgets/676606-bike-mirrors-glasses.html
bikeforums.net/electronics-lighting-gadgets/590401-mirror-hybrid-bike.html
bikeforums.net/electronics-lighting-gadgets/586962-best-mirror-handlebar-division.html
bikeforums.net/electronics-lighting-gadgets/569006-mirror-help-mtn-biker-riding-road.html
bikeforums.net/electronics-lighting-gadgets/522341-helmet-mirror-needs-frequent-adjustment.html
bikeforums.net/electronics-lighting-gadgets/513130-mirrors-blinkers.html
bikeforums.net/electronics-lighting-gadgets/498873-rear-view-mirrors-periscope-method-possible.html
bikeforums.net/electronics-lighting-gadgets/472505-mirrors-review.html
bikeforums.net/electronics-lighting-gadgets/416975-beer-cap-mirror.html
bikeforums.net/electronics-lighting-gadgets/347323-mirrors.html
Mirrors - ZEFAL
Yes, a Third Eye helmet mirror worked fine for me on my prior helmet.
Now that I am using the Bell Z20 helmet my Third Eye helmet mirror (03) mirror didn't fit, so I have switched to the EVT Safe Zone helmet mirror.
This is a sturdy and large mirror. The usage is easy and intuitive.
Quoted: 7351 Post(s)
Liked 2,478 Times
I like my Take-A-Look mirror so much, I carry it with me when I'm not riding. I might jump on a Citi Bike unexpectedly or something like that. I attach it to my glasses, but you can attach it to a helmet, too.
Quoted: 3462 Post(s)
Liked 1,468 Times
I use a Third Eye mirror that has a threaded clamp, the thread tightens the clamp. It clamps onto my visor on my helmet very well. With the clamp designed that way I can unthread it to loosen and remove the clamp for when I travel by train or plane, I can pack my mirror separately where it is less likely to be broken.
Third Eye® Hard Shell Helmet Mirror
It goes on the left side of my helmet.
You'll wind up fooling around with everything until you finally settle on the Take A Look mirrors that you clip on your glasses or can be mounted to your helmet. There's two versions, pick the one you like.
J.
J.
Bikes: Paketa V2R tandem, Granite Tandem Design TI travel tandem, Lynskey R265, Specialized Diverge, and of course a unicycle
Quoted: 11 Post(s)
I have tried all types of mirrors and then saw a rider with a Rearviz. It straps onto your wrists, and flips open. It is very intuitive to use and I think is the most stable and versatile mirror. We have bought three via Amazon. It is an Australian company. They offer some size and color options.
EB
EB
I am beyond satisfied with my Safe Zone mirror. This is a mirror that attaches securely to your helmet and puts a perfectly sized mirror out in the upper corner of your field of view. The mirror is big enough to see--with only a movement of your eyes--the entire quadrant behind you (mine's on the left, so I can see all oncoming traffic). And with a slight--just a few degrees of motion--you can see behind you and on the other side as well. It's easily adjustable in a millisecond while riding: it's fully articulable so that if you're in the down position you can adjust for that; if your hood on your winter jacket is causing obstructions you can adjust for that; if the sun's reflecting in your eyes, you can adjust for that.
The amazing thing is the company. I broke mine by dropping my helmet right on the mirror. The company sent me a replacement with no questions asked. There's only one other company I know that does that (Otterbox). It's amazing in this day and age. They've got a customer for life!
Liked 1,468 Times
Three year old thread.
But, to be productive with some new info, in post number six above, I mentioned the mirror I use. I can now add a photo of it from last summer.
The rain cover on the helmet obscures it a bit, the mirror clamps to the visor. Can be removed and re-installed. Before I get on an airplane and fly somewhere, I like to remove the mirror so it does not get damaged.
Bikes: Diamondback "parkway" Spec. "expedition
Quoted: 48 Post(s)
Liked 42 Times
Try this site. https://www.hafnycomponents.com/bike-mirrors
Bikes: 2021 Litespeed T5 105, 1990 Gios Compact Pro 105
Quoted: 167 Post(s)
Liked 325 Times
I forgot my water bottle for my 60 minute ride yesterday. Not turning around for that. I've gone without gloves and bare handed it and not turned back. If I forgot my take-a-look mirror on my glasses (prescription), I would definitely turn back and get them.
Likes For gios:
H
At Walmart Sold out though, last time I checked
The strap situation is not as bad as you’ve been led to believe. Someone threaded it backwards, and gave it s negative review.
it goes out-in-out, and they had it in-out-in.
There are only two ways to thread the strap through the slots.
With a rear-view mirror, cycling will be a lot easier on your nerves.
