How do YOU remedy the "frame is too small" problem?
Bikes: '02 Litespeed, '99 Bianchi Alfana. '91 Fuji Saratoga, '84 Peugeot Canyon Express, '82 Moto GR, '81 Fuji America, '81 Fuji Royale; '78 Bridgestone Diamond Touring, '76 Fuji America, plus many more!
Quoted: 181 Post(s)
Liked 224 Times
The photo of the 23" frame taken in June 2009. The photo of the 25" frame was taken in June 2020. Through feeding it fresh oil, axle grease and WD40 the frame was able to grow a couple of inches over an 11 year period. Read about it in a book on metallurgy.
Actually, I was able to stumble on the same bike in the correct size. Not bad considering it was a color offered for just one model year.
Likes For cycleheimer:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Trading up is probably best. In the meantime, I install a long seatpost and lower the stem.
This frame is a 55cm, about a half inch smaller than I normally ride. I also use a little wider bar (40cm) than most of my others (38). I could probably stand to add 5-10mm to the 90mm stem. That way, I could raise it a little bit more. For now, I'm pretty satisfied. I spend a lot of time in the drops on this one.
Likes For SurferRosa:
Quoted: 634 Post(s)
Liked 444 Times
This frame is a 55cm, at least a half inch smaller than I normally ride. I also use a little wider bar (40cm) than most of my others (38). I could probably stand to add 5-10mm to the 90mm stem. That way, I could raise it a little bit more. For now, I'm more than satisfied. I spend a lot of time in the drops on this one.
edit: what crank is that? I like.
señor miembro
Liked 6,491 Times
It depends. For me, stem height is mostly a function of stem length, top tube length, and head tube height. This top tube is so short for me, I had to lower the stem so I didn't feel cramped. It's very comfortable now, but I still have a nagging feeling I should add a longer stem so i could raise it a bit.
Triomphe!
What crank is that? I like.
Quoted: 634 Post(s)
Liked 444 Times
I like it! It has shades of Ofmega Mistral.
Likes For tricky:
Albatross bars are cool!!
Bikes: 1984 Cannondale ST; 1975 Raleigh Grand Prix; mystery Nashbar tandem MTB; 1991 Paramount Series 20 PDG (in bits); 1984 Raleigh Record (in smaller bits, needs dropout repair); 1985 Raleigh Alyeska (wrecked, needs downtube repair)
Quoted: 11 Post(s)
Liked 11 Times
Bars up for us with short arms! Looks like you're not riser bar types, so .....
1" Threaded: Nitto Tallux stem.
Threadless: Delta Stem Raiser Pro. Looks idiotic, but works great.
Likes For tricky:
Quoted: 2339 Post(s)
Liked 2,832 Times
n+1
Likes For squirtdad:
I bought a 1988 Trek 1200 around my 16th birthday in 1997. I grew about 6" that year and the 54" 1200 ended up way too small. I bought a longer seat post, slammed the quill stem as much as I could and rode that thing hard. The steering was frighteningly twitchy but 17-year-old me didn't care. I sold that bike a few years ago for $300, the same price I paid in 1997.
If I could find a 1988 1200 in Denim Blue with Yellow decals in a 58cm, I'd seriously consider it. I'm probably too out of shape now to ride it like I did 20 years ago but I'd have fun trying.
Quoted: 11 Post(s)
Liked 11 Times
Supposed to be stronger, mainly. IIRC, regular Technomic is cast and tall, Tech Deluxe is forged and shorter. Tallux is supposed to be the same height as the regular Technomic, only forged. Not to say the regular Technomic is in any way bad, but the Tallux is the only one I have, and it's really nice.
Quoted: 634 Post(s)
Liked 444 Times
Quoted: 939 Post(s)
Liked 2,957 Times
All of the above, also have installed longer crank arms and used setback seat posts.
Likes For hermanchauw:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 939 Post(s)
Liked 2,957 Times
TBH it wasn't intentional. I inherited a much too small PX10 and while I was poking around for parts I happened across a set of Stronglight arms in 180 so I figured it couldn't hurt, and the seller was glad to be rid of them. I have a 35-inch inseam and usually ride 175s. The bike had 170s. Can't say I can feel a difference in terms of cranking, but a cm is a cm.
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,380 Times
Sold it.
Even with a 130 srem and setback post, it was still a hack. Fun to ride, but not the same experience as correct fit.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
yeah, i would imagine a whole cm would. when i'd referenced leonard zinn's crank arm calculator for leg length, i came up with 175 as ideal for me. all mine are 170 and would be costly to switch. plus, it would mean ditching all my original vintage parts. so, i scrapped the idea in terms of trying to get the saddle down closer to bar height for a good fit on "too small" frames. i say too small, but really the reach on mine are fine. that leg length, though! i just couldn't see 5mm making any difference, either
Quoted: 939 Post(s)
Liked 2,957 Times
thanks for replying!
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
btw, your green one is still my favorite
Quoted: 939 Post(s)
Liked 2,957 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
señor miembro
Liked 6,491 Times
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,872 Times
Yep. You can make the fit work on a really wide range of sizes, but there comes a day when you look at the bike and say to yourself, "Who am I kidding?"
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 1609 Post(s)
Liked 2,216 Times
Andy_K Beautiful Pinny!
This is one of the reasons the Colnago is hanging on the wall. If I could trade for a 60 in equal or better condition of the same year or one year older......
The only way I can ride this is with the Campy post with the line showing in the saddle of the seat lug and a Brooks Pro on top. Even then it is a bit short but still very ridable. Brooks Pro's have a greater rail to saddle dimension then some other saddles.
CS7210, on Flickr
Bennoto relaced splash
CS7210, on Flickr
Quoted: 939 Post(s)
Liked 2,957 Times
Never really used the front rack except for a few times when I did some shopping. The bike was used for commuting in NYC, and I did use the rear with both roll-up bags to carry work stuff, groceries, etc. and a Racktime briefcase. The older PX10 is a very stable setup and it didn't mind having weight on it. In later years the geometry got much more upright.
Likes For ascherer:
