New chain or chain too tight?
I recently got a $300 State fixie and there's some clicking coming from the rear cog when I ride. I know that this is commonly caused by new chains and by too much chain tension, but I was wondering how long it takes a new chain to set so that I don't accidentally loosen the chain too much if it's just the new chain. I've only ridden it about 20 miles so far.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 766 Times
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
Liked 137 Times
If you're using fixed cog then it’s something else.
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 407 Times
Op.....while you're at it ensure your chain is properly lubed. The "clicking" may be coming from stiff links cycling around the (smaller) rear cog......
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times
it's just your components crying out for help as the rubber band tight chain crunches and munches the drivetrain.
How old is the cog? Should replace cog when you replace chain.. Even if the chain is too tight, it shouldn't be clicking or making excessive noise. When you are riding and applying force to the cranks does the noise get noticeably louder as apposed to free wheeling?
