Will 35c Bon Jon Pass tires fit with fenders on the 78-80 Centurion Pro Tour?
I'm looking for someone with experience with this particular model. I see a few people using 35's on theirs but not with fenders. I don't have the fenders yet, are there some fender that offer a tighter fit for when space is limited?
I'm talking about this particular model, I believe from 1978-80 they were all the same geometry, mine is 23" if that matters.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Yup, but without fenders.
I tried them with fenders, very little clearance (almost none). 32's would work with fenders.
Likes For gugie:
Dagnabbit! Isn't there all kinds of fender clearance with 32's? I wonder if the Rivendell Jack Brown's would have clearance for fenders, supposed to be halfway between the 32 and 35c Rene Herse tires.
Liked 5,803 Times
My Pro Tour is stored at a friends house, so I don't have a way to measure Jack Brown's on them. I'd say they might fit, just stay on clean paved roads.
The ride difference between 32's and 33 1/3 tires is significant, much more than one would think. I'd ride the 35's on unpaved roads, and have done so. 33 1/3's maybe not so much.
Likes For gugie:
Thanks for the input gugie. What fenders would you go with if you were trying to squeak Jack Browns onto a Pro Tour? My preference would be aluminum in a smooth polished finish.
Liked 5,803 Times
The fender to use would be the Velo Orange 700c x 45mm Facette fenders, which you can see on my Grander Sportier, above.
Just to be clear, I haven't confirmed that Jack Browns and your Pro Tour are compatible, but I think they are somewhere between might and probably.
Liked 5,803 Times
I understand it was just a suggestion, I just think I'm going to give them a shot. Unless another member has experience that says it's not gonna work. What makes those particular fenders good for tight clearances? I was also thinking that stainless steel is probably thinner than aluminum for fender applications so might offer greater clearances?
