GARMIN EDGE shutting off.
Quoted: 112 Post(s)
Liked 25 Times
After saving a ride and shutting the unit off I connected it to a USB cable to charge it, but the unit was dead. I tried starting it in the normal manner, but it would not start.
When I reset the unit by holding down all the buttons it will started up and showed a charge of appr. 50%.
This condition happened twice in a row. The 2nd time by ride was saved, but the 1st time it wasn't.
Any ideas appreciated.
Quoted: 18883 Post(s)
Liked 10,646 Times
Call Garmin.
They'll probably replace it.
Quoted: 6196 Post(s)
Liked 4,811 Times
What was on the other end of the USB cable? A charger or a PC/Macbook?
But for certain call Garmin Support. They'll get you straightened out or otherwise taken care of.
Liked 4,811 Times
It probably is going into charge only mode and won't work for anything else. Might partly depend on the level of battery charge. Maybe if you plug it into a USB3 or a type C port on your PC with the appropriate end for your Edge 530 it might allow you to work with it. USB 2 only puts out .5 amps on the power pins. USB3 is a tad better with .9 amps. So maybe it still won't be enough. If you have a type C port on your PC it should put out plenty to run the thing.
Regardless, if you need to charge your Edge, it will be very slow to charge with a PC or Macbook unless you have that USB type C port.
Sometimes USB hubs will put out a tad more amperage on the ports if you have a powered hub. But if it's just powered from the USB cable it'll be only able to put out what the PC puts out.
Quoted: 3462 Post(s)
Liked 1,468 Times
Try charging it with a different cable. It is rare but I have had a couple cables go bad over the years.
Quoted: 112 Post(s)
Liked 25 Times
Today, I saved the ride and the Garmin worked normally. After saving the ride I shut the unit off, and then switched it on, and it worked.
In the previously mention cases I don't specifically remember that after saving the ride I plugged the unit into the cable from the USB hub, to download the ride and it went "dead".
Most likely that was the case so it must be a matter of the cable or the hub. The cable is a Garmin cable.
I'll watch how this develops.
Thanks for the response.
Liked 4,811 Times
Never anything needed to connect it to except a charger. My Edge 530 has my rides saved and uploaded before I ever get in the house most of the time. Having that Wi-Fi connection or Bluetooth through the Garmin phone app really makes map, software and firmware updates a cinch.
Liked 10,646 Times
Quoted: 3242 Post(s)
Liked 2,089 Times
Do you not have your Edge 530 connected via Bluetooth to the Garmin App on your smartphone or to the Wi-Fi in your home? If you do, then your Edge 530 automatically will save and send your ride activities to the Garmin Connect website for your review with a PC or MacBook. And if you allow, then also to RideWithGPS, Strava and some others too.
Quoted: 112 Post(s)
Liked 25 Times
Out of habit I've always connected my Garmin to my PC after my rides. I also copy my rides to a database which has all my spares and maintenance info.
I'll connect it through bluetooth.
Thanks.
Thanks.
Liked 2,089 Times
Just curious when was the last time you cleared out all the saved rides ?. I've read of a stuffed memory causing odd issues. I dump last years, its all backed up on RWGPS as well as Connect.
Quoted: 112 Post(s)
Liked 25 Times
Never though about clearing saved rides. I thought it automatically discarded older rides when the memory filled up.
Liked 4,811 Times
However I too will periodically connect my Edge 530 to my PC and save off all my activities for safe keeping and delete the activities on my Edge. I've never come close to using all the available free space on any.
Liked 10,646 Times
