what else needs lubrication?
I've been lubricating my chain regularly but was wondering what else needs to be lubed periodically? I don't think hubs or crank bearings ever need lube. So maybe the that just leaves the derailler pivot points and rollers? Anything else or nothing needs lubing ever? Just wondering...
Quoted: 6975 Post(s)
Liked 10,975 Times
With this thread title, I won't be surprised if it's locked down in a few hours.
I use lube very sparingly on brake and derailleur pivot points, as it will attract dust and dirt. Really, aside from lubing the chain, you don't need much lube. Assuming cartridge bearings (hubs, bottom bracket, headset), you don't even need much grease either. At least that's what I do, and it's working so far. More experienced people may have different practices.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Depends on what kind of stuff you have on your bike and the conditions you ride in. Chain, obviously. If you have cartridge bearing bb and hubs the bearings will need replacement every now and then. I never really bother with servicing them. Loose ball hubs definitely need service every now and then. Derailleur pivots? I keep my bikes really clean so they don't need it very often but a few drops of oil won't hurt. Headsets last ages if properly adjusted but the bearings need to be taken out, cleaned and greased...how often depends on you again. I never lube cables/housing, I just replace.
And of course this should not be in GD, it should be in the proper section which is obviously 'bicycle mechanics'. Come on people, stop dumping every thread you start in GD.
Likes For cxwrench:
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times
Many bottom brackets are the cassette type and can not be overhauled, but I believe most hubs and headsets can be cleaned then greased. (This doesn't need to be done very often.) Derailleur pulleys can be greased also. Why not post your question in Bicycle Mechanics and phrase it - which parts should be lubed and how often.
Another thing to check for is chain stretch. Chains should be replaced after they reach a certain point, or you'll wear our your gears.
Quoted: 427 Post(s)
Liked 700 Times
Anything that moves against another part needs lubrication. What type of lube and how often is the question. In general, parts open to the elements (such as chains) need cleaned and lubed more often. Those type of parts would use a thinner lube (not grease), such as lube specifically designed for a chain, or a lube such as Tri-Flow, or maybe oil. Parts not "open" to the elements (but not sealed), headset as example, need cleaning less often and use a thicker lube, usually grease. "Sealed" parts, ex: sealed bearings, bottom brackets, are designed to be replaced if worn and are generally not able to be, or may need disassembled, to be lubed-with grease. This is not "etched in stone", only meant as a general guide.
Quoted: 4420 Post(s)
Liked 4,873 Times
Likes For epnnf:
Liked 4,873 Times
Likes For PeteHski:
Quoted: 18429 Post(s)
Liked 15,583 Times
Likes For indyfabz:
Liked 4,873 Times
UK engineering terminology was invented by a bunch of perverts for sure! e.g.
Flange -Gusset -Penetration -Lubrication failure -Ring Expander -Shaft (especially when combined with Thrust) -Orifice gauge
Reference: https://www.physicsforums.com/thread...-saying.62591/
Likes For PeteHski:
Liked 10,975 Times
Liked 15,583 Times
Quoted: 3241 Post(s)
Liked 2,512 Times
Lowest hanging fruit I've seen in a while.
Bikes: lots
Liked 2,932 Times
Quoted: 696 Post(s)
Liked 910 Times
The ziplock looking zipper on Ortlieb Velo Shopper panniers. It needs a periodic application of zipper grease.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2590 Post(s)
Liked 5,659 Times
Stopped by to see how far off the rails this thread went and am glad to see, from a strictly engineering standpoint, I am not disappointed.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Liked 2,512 Times
It depends on what brand of chain lube you use. Better go check in one of the chain lube threads.
Should I oil my bell, or is it best left dry?
Quoted: 2333 Post(s)
Liked 2,097 Times
I find my pedal bearings need serviced a couple times per year. Headset never. I just replace hub and BB cartridges although sometimes clean and lube. I put duck fat under the Brooks B17 onto the leather. I clean the jockey bearings a couple times per year. The cassette freehub needs disassembled and lubed a couple times per year or bearings binned. The Garmin cable port gets dielectric grease a couple times per year.
