Removing selected gears from a cassette
Quoted: 13 Post(s)
Hi! Is it possible to remove selected gears from a 10/11 speed cassette to fit into an 8 speed shifter? I'm broke af and can only make tiny upgrades from time to time. I just started cycling a few weeks ago and my knowledge with the technical side is kind of limited.
I'm planning to change my hubs first since it is a freewheel type and then change the cassette like I have said earlier. And when I have earned enough money, probably upgrade the groupset to an m6000 or Sram SX.
Any tips and comments will be appreciated as long as it's not hostile
edit: How does the alivio groupset perform compared to the deore m6000?
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
No, the spacing between the cogs is different. It will not line up properly when you shift.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Depends. Shimano 8-9-10 freehubs are the same as is the spacing. 11 is different. Campy is another story altogether. You need to be more specific on what it is you have exactly, and what it is you're trying to do.
Are you trying to do individual cogs on the cassette?
https://www.sheldonbrown.com/k7.html
Quoted: 13 Post(s)
It's a pretty wild idea and I have no clue if it will even work.
Are the cassette gears riveted on and is impossible to remove?
Why don't you just mount 8 speed cassette on the freehub? 8, 9 an 10 speed cassettes use the same freehub body. Plus an 8 speed cassette is cheaper than 10 speed.
SE Wis
Liked 3,390 Times
Where are you located? Do you have a bike co-op in your area? They can assist with parts and expertise.
https://www.bikecollectives.org/wiki..._Organizations
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Exasperated.
Don't. Stick with the 7-speed freewheel (or 8-speed freewheel) and continue to ride it until and unless you have an end-to-end design that will work from a compatibility perspective, and that is affordable. What you attempted to describe in your post(s) has unforeseen pitfalls that will cost you money to untangle. This is a waste of your scant funds.
And, the current rear hub cannot support the change to a freehub and cassette. So you're going to replace the wheel?
Likes For Phil_gretz:
What's wrong with your present set up?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If you’re “broke af” and just started riding, upgrades are the last place you should be spending your money. Just ride your bike as it is.
Likes For ThermionicScott:
SE Wis
Liked 3,390 Times
Liked 2,568 Times
The homeless guy whose bike was incomplete without an 11-speed Campy chain, or a different one? We get all kinds here, don’t we?
Quoted: 13 Post(s)
I don't know what the exact problem is but I think the rear wheel is not trued. The rotors rub the brake pads even after adjusting. I took a closer look at the wheel and saw that it wobbles side to side. Now, if I were to do something about the rear wheel, I might just as well do a hub replacement, but this will include having to change the cassette too.
Quoted: 13 Post(s)
It's really hard to ride it as it is because of a plethora of shifting problems (kinda worrying when you're out on the road) even after setting it up as properly as I can to the best of my abilities.
Quoted: 13 Post(s)
STOP!!! The problem is that you want to fundamentally change your drive train without either the resources or understanding of how to do it efficiently.
SE Wis
Liked 3,390 Times
Quoted: 1324 Post(s)
Liked 927 Times
If you change the wheel and get one that'll take an 11-speed cassette then you also need an 11-speed chain. Then you might have problems with that 11-speed chain getting caught between the chainrings on your crankset because the 11 speed chain is narrower. You'd also need new 11-speed shifters and possibly derailleurs too. Thus you're looking t a very expensive upgrade. You might be better of just saving and then buying an 11-speed bike.
I'd take the bike to a bicycle co-op if there's one near you and have someone with knowledge about your type of bike have a look at it.
Disc brakes on a wheel with a freewheel? Could be that the wheel or the brake or both are really low-end and prone to problems. Again a co-op should be able to help you. If there isn't one near you then a good shop might troubleshoot your brake/wheel issue for you. I'd take the bike in when they're not busy.
Cheers
Cheers
Quoted: 13 Post(s)
It doesn't wobble that bad but i'll have it checked when I go to the shop on the weekend.
Well, that all went over my head. Totally forgot about the chains.
Everything is low end. I bought the bike brand new for about 100USD. I changed the FD to a Deore M590 used and RD to a non-series shimano.
Cheers
Cheers
Liked 927 Times
Cheers
SE Wis
Liked 3,390 Times
A $100 USD new bike is usually in no way, shape, or form, worth upgrading unless you have all the parts for free and can do the work yourself. Keep the original stuff maintained and save your money for a better bike.
Likes For dedhed:
Likes For alcjphil:
Quoted: 13 Post(s)
Even if I am to save my money to buy a better bike, It would probably be a 400 to almost 600 (maybe? or around 500) dollar bike. Which would be better then? A 400usd built bike or this bike with upgraded components?
Likes For uratex1:
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
While I did say I'm "broke af" I did not really mean I am seriously broke. I have around 400-500USD on my parents and I don't think I will be able to get it until April or so.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Why? Is it about the frame? The only problems I have with it currently is the drivetrain, brakes, and the front suspension. I use it on the road around 90% of the time and the off roads aren't even too rough. I just want a bike that shifts and brakes nicely when I need to.
SE Wis
Liked 3,390 Times
What exactly is the current $100 bike?
Quoted: 13 Post(s)
It's really hard to find a used bike like what you're trying to say and tougher luck if it will even be in good condition. What if a used bike is out of the question, then?
