Vintage Trek, need model year and opinions
This is an old vintage trek 5200 oclv carbon. Seller says the tires are worn but the bike is otherwise good and frame is good. Anyone able to I'd the model year? What
do you guys think of this bike? How much would you think it's worth?
Looks like a '93: https://www.vintage-trek.com/images/trek/93/Trek93.pdf
Wow ... Spot on! So what do you think? Im a novice for the most part. Are old high quality components better than new low quality ones? What's your advice on the bike for a novice? I'm on a tight budget. One alternative I have is a specialized allez comp 1 2002 model
Some of the components look like they've been replaced. The rear derailleur does not look like the original Ultegra, can't quite tell what it is. Brifters look like 9-speed Ultegra (pointy hoods) instead of the original 8-speed Ultegra (rounded hoods).
Wondering whether drivetrain parts are mismatched. If that's the case, they won't play together nicely. $200 would be a good price if all original.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
Was looking at this post on my ipad and it showed $200 somewhere - but the price doesn't show up on my desktop computer
But for $200, the frame alone is worth updating if the replacement parts on it don't get along
I don't know ... Haven't rode it yet.
I think trek introduced carbon bikes in 92 so it must be one of the earliest versions...
You tube had a video comparing a 92 model carbon fiber trek bike to a modern one and they didn't think there was a huge difference. Ofcourse the bike they road was much better maintained ...
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
Is it worth $200? Sure...would I buy it? No. Old 90s CF scares the hell out of me. Im
not one of these “carbon is a delicate time bomb” people, but it did get better over time (trek was always pretty good to be fair) and there are material issues that would probably discourage me from used CF.
Quoted: 189 Post(s)
Liked 473 Times
FWIW, I just picked up this early Trek OCLV with full Campy Record for a couple Franklins. I may end up parting it out, but not until after it's ridden a bit. I always loved this green and it's my first carbon bike. I think these carbon frames will age well and be ridden for a long time.
So I just found an alternative bargain. A felt z6 carbon bike 2011 model recently tuned with new tires and apparently good condition. This one will sell for 300$. What would you go for? The felt z6 or the very old trek carbon? I really liked the idea of having an old vintage bike but my feeling is the felt is a better bargain, will be safer, and last longer with less maintenance.... Thoughts?
The best thing you can do when you're considering a bike is to go ride it. That will tell you which bike speaks to you and which one doesn't, and it helps you define what exactly you're looking for. Fit and how the bike works for you is key.
As far as whether a newer Felt or an older Trek would fit that bill for you - that's a better question after you've ridden them both.
Likes For bargainguy:
Quoted: 586 Post(s)
Liked 612 Times
