use two chainrings for chain stretch?
It's got electrolytes!
Bikes: Self-designed carbon fiber highracer, BikesDirect Kilo WT5, Pacific Cycles Carryme, Dahon Boardwalk with custom Sturmey Archer wheelset
Anyone ever try taking up the slack due to chain stretch by switching between two chainrings one tooth apart?
For example, you bolt a 39T chainring on one side of the crank spider and a 40T on the other. The difference in circumference is 1/2" so when the chain stretches 1/2" you move from the 39T to the 40T to take up the slack. Then when it stretches again you remove a link and move back to the 39T (-1"+1/2"). And repeat until it's time to replace the chain.
Or maybe they should be 2 teeth apart since the chain only wraps around half the circumference?
Does it work?
Does it work?
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12757 Post(s)
Liked 7,672 Times
You should get a new chain when it gets about 1/4" longer than it's supposed to be, IMO. Maybe 5/16" tops.
But if, in fact you have a chainring that's 1/2" bigger in circumference, that doesn't mean it's taking up 1/2" slack.
Never tried it, myself.
Bill
Bikes: Specialized Globe Sport, Specialized Stumpjumper FSR Pro
Then you could accelerate the wear on two chainrings.
Come on! The real issue is not the change in length but the change in link spacing caused by the chain WEAR that will result in additional friction/wear of the cogs on all used drive gears. But you could keep the worn out chain and just keep adding additional gears.
It's a dillusional solution to a problem that is easily solved by (as LesterOfPuppets said) put on a new chain. Of course you may have already caused 'chainring stretch' by using a worn chain too long and even a new chain won't fix it without all new gears. Chains are vulnerable, expendable, replaceable, and inexpensive.
You sound like a doctor - treat a symptom rather than the cause.
"Now go do the right thing."
Quoted: 7 Post(s)
getting a new chainring changes nothing. The chain it stretching between the links, not adding an extra link in the chain.
The teeth in the cog and chainring are still the same distance apart. If you could get a new cog and chainring with teeth spaced a little farther out then that would work, but the chain would snap soon anyway!
Bikes: Norco CCX1, GF HiFi Plus, Dawes SST AL
As has been said, by the time the chain is stretched a full tooth the chain is beyond toast and has probably eaten up the cog and chainring. Chains are cheap, much cheaper than replacing cogs and chainrings.
As it is written:
"The end of all things is near. Therefore be clear minded and self-controlled so that you can pray. Above all, adjust each others chains tightly, because tension covers over a multitude of sins." 1 Peter 4:7-8
You just sandwich the spider between them, line up the holes, and put in the bolts. Same way you attach a chain guard (you might need slightly longer bolts).
That's funny because over the years I've taken about three links off the chain on my primary bike due to stretch and it's still going strong. Although it's started making nasty popping and grinding sounds after this last winter, I wonder if it will ever die.
Bikes: everywhere
Liked 7,672 Times
I suppose if you're really gonna go for it, You'll want to get a second rear wheel with a cog you'll use only with wasted chains and a spacer to get said cog inline with the big ring up front.
I still think you're crazy. I do just fine with $13 chains, sometimes I splurge and blow a whole Jackson on one!
They're usually cheaper than tires, but typically last longer, so why not replace 'em when they hit 1/8" over a 12" run?
You guys are right. This is basically the magic ratio method streamlined for making a quick adjustment. It's not gonna work well.
But the good news is I realised how little adjustment it takes to tension a chain as it stretches (less than 4mm!). You should find that much play in any set of dropouts that aren't completely vertical (certainly mine).
Listen to me
A couple of years ago there was a guy that would bring his completely un-maintained road bike into the shop , (on busy saturdays of course) and complain that it was not shifting right or stopping quickly enough.
We would put the bike on the stand and spend 20 min explaining all the things that needed replaced adjusted.
Then we would give him an estimate of the time and cost.
He would say no I don't want to do all that just fix the shifting....another 20 minutes explaining chain wear and why his cog teeth look like shark fins....He would say "I don't care about that, I just want you to fix the shifting"
The shop owner would have to come over, pull his bike from the stand and walk him out back and explain that we don't have time for him today and to come back another time.
Finally, one day his chain breaks and the guy comes in for a new chain. We replace the chain, explain what is going to happen when he tries to ride (because he only wants a chain) and send him off.
He comes back the next Sat and in front of a shop full of customers starts yelling that we ruined his pride and joy.
Fast forward to today on bike forums........
Enjoy
Enjoy
Gone Tarcking. Back Later
Bikes: Iron Horse Warrior Team (tricked to high heaven), Jamis Coda Sport (frame and fork, built into CX commuter), Gary Fisher Opie Dirt Jumper,SE Lager tarck bike
KMC 410s are 10 bucks. Find a friend with a chain tool and you have no excuse to not replace your chain.
Either that or we all just got trolled.
