Newbie Tire Size Questions
Old 05-17-10, 09:29 PM
nat3r
So for future reference in replacing my tires,
im guessing my wheelset is a 700c, as that's the most common and the tires that are coming on them are 700x23c's
so i'm looking into buying some Gatorskins, and im finding multiple different sizes.
now i know from searching that 700x23c and 700x23 are the same, but whats the difference between 700x23 and, say, 700x25? Will they both fit my frameset?
nat3r is offline
Old 05-17-10, 09:35 PM
Squirrelli
GONE~
Yes, it will fit your frame.
700x25 is basically 2mm wider than 23.
I have a 700x23 Gatorskin, but I measured it and it is actually 700x24, but that 1mm does not matter that much.
Squirrelli is offline
Old 05-17-10, 09:36 PM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 346 Post(s)
Liked 12 Times in 6 Posts
some people put the c, some don't. The c is for the rim, 700c. We can't tell you if your frame can fit 25mm tires until you tell us what it is, but I'm guessing you most likely can.
hairnet is offline
Old 05-17-10, 09:38 PM
nat3r
It's a 52cm Fuji Obey.
im a bit on the heavier side (~200lbs) so im looking for a tire thats a bit more durable for my weight, and will last a while
nat3r is offline
Old 05-17-10, 09:51 PM
Leukybear
THE STUFFED
Leukybear's Avatar
Bikes: Rock Lobster; EAI Bareknuckle; Evil Insurgent
Quoted: 360 Post(s)
Liked 5 Times in 3 Posts
28mm should be a good size for your weight.
Leukybear is offline
Old 05-17-10, 10:01 PM
nat3r
how can i find out if those fit in there though?
also, im not going to be skidding alot at all, so my tire will wear naturally.
nat3r is offline
Old 05-17-10, 10:16 PM
lz4005
coasterbrakelockup
lz4005's Avatar
Bikes: surly steamroller w/coaster brake, electra single speed cruiser, specialized rockhopper commuter, no-name single speed folder, 700c ultimate wheel, 24" unicycle, specialized bmx lsd, single seat single speed huffy tandem, pink upsidedown parade bike
How long the tire will last is more related to thickness of the tread part of the tire than the size. Bigger tires will be more resistant to pinch flats and soak up some of the bumpyness of the road.
I'm about the same weight as you and I ride 28's.
lz4005 is offline
Old 05-17-10, 10:27 PM
nat3r
but how do i find out if it will fit in my frame?
nat3r is offline
Old 05-17-10, 10:28 PM
destikon
FNG
destikon's Avatar
Bikes: Raleigh Special * Nishiki MTN Winter Commuter * Trek Soho 3 * Specialized Langster Seattle
38s here, at least on one of my rides. Go for comfort, but I doubt the obey will fit those... :-(
Originally Posted by powers2b View Post
time's up
destikon is offline
Old 05-17-10, 10:35 PM
nat3r
comforts good, but im mainly going for speed and durability, so i think i might go just under 28
as long as my fork will allow it.
nat3r is offline
Old 05-17-10, 10:36 PM
JacoKierkegaard
Fixed-gear roadie
JacoKierkegaard's Avatar
Bikes: 2008 Masi Speciale Fixed
That one, actually, is more of a trial and error type thing. A lot of the time it will have to do with your brakes more than your frame, and even then the actual size of the tire assigned to a given number can vary from one manufacturer to another. Just in general, I'd say most bikes will at least be able to clear a 28 or so. You should be fine with anything at or below that. As a rule, thinner = higher pressure = less rolling resistance but harsher ride, whereas wider = lower pressure = more rolling resistance, but more cushy. I prefer 23's, and they're more or less the standard for racing, but plenty of folks opt for the comfort of a slightly bigger tire. It's all a matter of personal preference.
JacoKierkegaard is offline
Old 05-17-10, 10:42 PM
nat3r
Thanks Jaco,
the Obey is a track bike, so it isn't drilled for a brake, so i wouldnt have to worry about that, but basically im wondering what is the maximum and minimum width that i can fit on my frameset.
I'm going to go with a middle of the road width, most likely 23's-25's.
From all the reviews of the Gatorskins i've been reading, i think it will be durable enough, im just preparing for the future.
any other input would, of course, be very helpful
nat3r is offline
Old 05-17-10, 10:51 PM
Leukybear
THE STUFFED
Leukybear's Avatar
Quoted: 360 Post(s)
It should fit tightly; if you're not sure just go to your LBS and ask for their opinion.... I'm pretty sure you won't be able to use 38 tho...
Old 05-17-10, 10:57 PM
nat3r
Tight? as in rubbing against the fork?
I also highly doubt ill be able to fit a 38 in there, but again, im not too concerned with which size i should be riding, i just want to know what the max width that my actual wheelset can accept. Or are 700c wheelsets pretty much universial
nat3r is offline
Old 05-17-10, 10:59 PM
Squirrelli
GONE~
+1
Some people here seem to be afraid of going to the LBS for opinions and advices.
I love my LBS/communal workshop, $5/h for tools+stand+advice. Best place ever!
Old 05-17-10, 11:15 PM
Leukybear
THE STUFFED
Leukybear's Avatar
Quoted: 360 Post(s)
Of course not silly; the tire should fit but appear to the eye with little clearance left (there's no repercussions to this; in fact many true track bikes out there are like this). A 38mm tire will not fit for sure... its meant for tarck bikes and conversions that have massive clearance due to them being converted from size 27in wheels to 700C.....
Originally Posted by Vixtor View Post
+1
My mechanic does it for free (even tires!) for me with purchase and sometimes not even.
Old 05-17-10, 11:51 PM
nat3r
But what about the wheelset, im not asking about the fork, im asking about the maximum tire that can fit on the avg 700c rim
nat3r is offline
Old 05-18-10, 12:01 AM
Squirrelli
GONE~
It depends on the inside width of the rim, if it has 23 tires already, the maximum is probably about a 32. I'd worry about the fork more if you looking for wider tires.
Old 05-18-10, 12:04 AM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 346 Post(s)
depends on rim width.
http://www.sheldonbrown.com/tire-sizing.html
scroll down near the bottom
hairnet is offline
Chicagomarkk
Hybrid Bicycles
2
07-06-15 07:05 AM
srestrepo
Commuting
13
07-27-14 08:07 PM
isuckatbiking
Road Cycling
18
06-03-14 01:40 PM
Reeses
Road Cycling
7
12-23-11 07:43 PM
mickey85
Classic & Vintage
7
06-19-10 04:45 PM
