Riding Technique
Fuji Hero
Bikes: Raliegh MT, Specialized i-Drive, Fuji Professional (circa 1982)
Riding Technique
Hi, I finally upgraded my Mt Bike after 16 years. I originally had what I thought was one of the better suspension designs on the market at the time: a GT "iDrive" that isolated the peddling forces from the suspension movement.
So, my front fork's seals are finally starting to go, and it's almost impossible to get a kit for it since it's so old, no shop in my area (Greater Detroit) will touch it.
So I got a new bike, a Marian "Hawk Hill." This is an entirely different setup, different body position and suspension philosophy. I'm also going from a 3x7 gearing to a 1x11 gearing.
However with the time of year and weather here (now that there's snow, I generally rarely ride below 40 degrees) I did get one crack at riding a favorite trail in the area. It had been about 3-4 weeks since I had been on a bike when I did so.
So with that in mind, it felt like the lowest gear ratio was not quite as low as my older bike, my knees feel strained a little bit (I'm mid-50's now, no longer a spring chicken).
with the older GT, I'd almost never climb a hill out of saddle. With this bike, while I was impressed how it felt going up a hill. But I'm wondering if climbing out saddle would dramatically alter the suspension characteristics such that I might not want to do that?
Is there some kind of general guideline when climbing with these newer designs, or can some one point me to something that I can research/read?
And my other question is to ask if I do, do I just replace the front chain ring with one with a couple of less teeth if I decide that I still want to lower my gearing a little?
Thanks.
Thanks.
I find standing does cause noticeable pedal bob on my trail bike but it does not have a lockout on the shock. If your shock has a lockout it should allow standing without pedal bob. You could go with a wider ratio cassette 11-50, so you wouldn't lose your high gear. If you rarely or never use the 11 cog, going to a 30t or maybe even 28t chain ring is an option.
I'm 60 and run an 11-40 cassette with a 32t oval chain ring. Oval gives you the feeling of about 2 teeth less during the power stroke, so helps in climbing. Oval chain rings generally work better for people with lower RPM pedal rates, most spinners find them annoying. I just bought a new bike that came with a 10-50 cassette, but I have not ridden it yet, still putting it together. I live in the south were there are not a lot of hills, so I'm not sure if I will ever use that low of a gear.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Suspension designs vary. Some deal with standing better than others. Also, they don’t all react the same way. Some may compress more, others stiffen more. That said, in general, FS bikes do tend to behave best on non-technical climbs in the saddle as opposed to out of it.
However, sometimes the situation demands standing regardless of efficiency calculations, and regardless of suspension design (or lack thereof).
I would give the new gearing a little time (at least a few rides) to see if you adjust. Otherwise, as long as your crank can take a smaller ring, go for it.
Quoted: 2976 Post(s)
Liked 1,182 Times
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
Old adage used to be 'sit-and-spin' full suspension; but, as Kapusta says, designs vary and most are much-improved from when that was conventional wisdom. I run 1x10 and my 32/42 combo still isn't really granny enough for some climbs seated. But the Switch platform of my Yeti SB66 allows me to leave my shock wide open and it flat hooks up when I have to stand to grunt those last few yards of a tough climb. I say ride it like you need to in order to get the job done and don't sweat whether or not you encounter some bob.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
Bikes: 2019 KonaLibre- 2003 Litespeed Vortex -2016 Intense Spider Factory Build -2008 Wilier Mortorolio- Specialized Stumpjumper Hardtail converted to bafang 750 mid drive -1986 Paramount 2014 - --- Pivot Mach 429c
Quoted: 43 Post(s)
Liked 15 Times
Congrats on the new bike
I am on the other side of 50 as well and that's why I prefer the 2x I think once you get used to it it will be fine. It is a good system
I tend to lock out my front when standing and mashing up hill and leave my rear alone. Most of the bob goes away but not all of it when I sit back down I adjust my shock
Yes ride it like you feel comfortable
The rear has more effect so if you have room I would start there before adjusting the front
enjoy the new ride!
enjoy the new ride!
Fuji Hero
Thanks for all of the responses everyone. I guess it's just something I'll have to experiment with. My front shock can be locked (via dial on the top of right side), but rear can't.
I also hope that over time I'll build up a little strength over the regular season (usually is the case) and hopefully maybe it was just an off season being-out-of-shape.
And thanks hig4s, I'll have to look into an oval chain right. I remember when they came out on road bikes (before the advent of Mt Bikes).
So one change might be the fact that I might be possibly relaying on strength a little more than spinning. I guess I'll just be making sure I do a little more conditioning this season (which is something I'll probably look forward to since I think my overall saddle time has been starting to drop off a little bit).
