Tapered fork to non tapered headtube
Hi can someone tell me if i can put tapered fork on this frame? its 44 mm diameter. i saw some external cups but i need confirmation of this
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Just be aware that it will add to to the stack hieght (and raise the front end of the bike) and slack out the front end a little.
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
44mm headtube was for 1 1/8" integrated headset. The one-point-five (1.5, 1 1/2) standard that the lower end of a tapered steer tube uses is 49.6mm. There are adapter headsets like the Cane Creek Cane Creek 40 ZS44/EC44 that adapt the 44mm headtube for use with a tapered fork. It has an external lower cup (which will slightly raise your axle-to-crown) and an integrated, zero-stack upper. That is the type you need to look for.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
robertr81
Bicycle Mechanics
5
05-22-13 03:20 PM
B17
Bicycle Mechanics
17
08-07-12 07:39 AM
KillerBeagle
Bicycle Mechanics
8
05-18-11 06:26 AM
