My first Merz
My first Merz
Old 02-21-24, 08:40 PM
jPrichard10
Quoted: 226 Post(s)
Liked 258 Times in 112 Posts
My first Merz
This has hung in a local co-op for quite some time. I knew I couldn't swing the hefty price tag, but always checked it out since it's my size (size NBA) and a piece of local and international bike history (thanks Portlandjim !)
With the Seattle bike swap looming a month or so ago, one of the employees offer me a killer deal on it so they wouldn't have to schlep it up I-5. This has as heartbreaking, because I didn't have the funds then and I know they would be even more motivated to not bring it home... I figured it was gone for good.
​​​​​​With my Gugie rando frame headed out the door, I stopped by on the off-chance it didn't sell. Lucky for me, the employees had work complications and they never made it up to the swap! It definitely made the parting blow of my custom faux-Weigle more manageable.
The problem is, I'm now too broke to dress it.
jPrichard10 is offline
Old 02-21-24, 09:14 PM
repechage
Quoted: 3464 Post(s)
Liked 2,831 Times in 1,997 Posts
You should ask Jim what wheel size it was designed for.
repechage is offline
Likes For repechage:
Old 02-21-24, 09:19 PM
jPrichard10
Quoted: 226 Post(s)
The tag said 700; I'm really hoping that's the case because I didn't check. That said, I've never had a 27" frame that couldn't be converted to 700c. The canti posts on this are quite narrow though.
Likes For jPrichard10:
Old 02-21-24, 10:33 PM
merziac
merziac's Avatar
Quoted: 4512 Post(s)
Liked 6,387 Times in 3,672 Posts
I'm glad you got this, I almost went by to check on it and was going to low ball them just to see, sounds like I may have gotten lucky but glad you did instead.
I didn't have $$$ to build it either but have plenty of stock and would have figured it out.
Pretty sure the cantis would have been Mafacs, maybe tandems, Jim didn't make hardly any 27" frames.
Welcome to the club.
Paging @Portlandjim
merziac is offline
Likes For merziac:
Old 02-21-24, 10:36 PM
jPrichard10
Quoted: 226 Post(s)
Paging @Portlandjim
Glad you didn't! I got it for a song (comparatively).
Maybe not enough tall people interested.
No clues on the tubing though. No "dove" on the steering tube.
Old 02-21-24, 10:40 PM
RustyJames
Quoted: 566 Post(s)
Liked 1,052 Times in 545 Posts
WooHoo! Another member in the Merz tribe. If it’s anything like mine, Mafac cantis. Portlandjim was very helpful providing info about my bike.
RustyJames is offline
Likes For RustyJames:
Old 02-21-24, 10:46 PM
P!N20
P!N20's Avatar
Quoted: 1079 Post(s)
Liked 1,899 Times in 931 Posts
The skirtings and electrical can wait.
P!N20 is offline
Likes For P!N20:
Old 02-21-24, 10:48 PM
jPrichard10
Quoted: 226 Post(s)
😂 This is my bike dungeon. I am always a bit self-conscious of the unfinished electrical but there aren't many other spots for pictures in the unfinished bedroom.
Old 02-21-24, 10:56 PM
merziac
merziac's Avatar
Well that makes at least 4-5 of us that were looking/aware so you got relatively lucky IMO.
This is pretty early so 531 is very possible I think.
merziac is offline
Old 02-22-24, 12:03 AM
jPrichard10
Quoted: 226 Post(s)
Don't think I can get Mafacs tandems for this. Will have to see what cantis are a good replacement.
Luckily I have the 26.8 ITM seatpost pictured here, although the black flutes aren't the best match.
I may be able to get it on the road this weekend with just my parts bin, but it may be a bit ramshackle for a while.
Old 02-22-24, 12:14 AM
merziac
merziac's Avatar
Yeah, they can be spendy, regular ones too, I think others will work, you should be able to reach out to Jim for advice, he's usually glad to help if he can.
merziac is offline
Old 02-22-24, 12:35 AM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times in 2,286 Posts
Hey, you know your way to the Atelier, bring it by and we’ll see if we can answer your questions.
gugie is offline
Old 02-22-24, 02:00 AM
RiddleOfSteel
Master Parts Rearranger
RiddleOfSteel's Avatar
Quoted: 1556 Post(s)
Liked 2,024 Times in 989 Posts
Oh, I was definitely aware of it, by happenstance of course! They wanted real good money for it, which, I understand. Even offered it to me for well off the listed price. 66x59 was perfect. Alas, I remain happily awash in vintage Treks and would have wanted to put serious money into making that Merz good for the next 50 years. Couldn't do it! I'll have to "settle" for the purple '80 510 frameset I picked up from them November of '22 for a healthy $200 (with no decals or head badge, no less). On it now hangs some real fancy parts, which suits my type of bike-building insanity.
I am glad you got a freaking sweet frame, regardless! (always!) You have a flippin' Merz! And a suuuuper tall one at that! Very, very special.
RiddleOfSteel is offline
Likes For RiddleOfSteel:
Old 02-22-24, 02:39 AM
bulgie
blahblahblah chrome moly
bulgie's Avatar
Quoted: 1181 Post(s)
Liked 2,576 Times in 1,076 Posts
Not sure if it's widely known: Mafac Tandem canti is 2 mm taller than the short-arm Criterium canti. So ideally, for Tandem brakes, the posts should have been put on 2 mm lower, for the pads to hit the rim just right. So if you're putting 700c in a bike made for 27" (unlikely in this case but it happens...), then Criterium brakes will fit better than Tandem. 2 mm is a noticeable amount, but Mafacs can usually adjust that much by the "nod" angle adjustment of the pads. It's not a true up/down translation adjustment, but as long as the angle you adjust them through is small, using angle as a height fine-adjust is OK. It's just in the edge cases, like where the posts are too high b/c they're for 27", that the extra 2 mm on Tandem arms can be a deal-breaker.
The lack of any up/down adjustment is just about the only thing I don't like about Mafac cantis. When the posts are at just the right height, I rank them up there with the best modern rim brakes.
bulgie is offline
Likes For bulgie:
Old 02-22-24, 08:35 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3590 Post(s)
Liked 3,401 Times in 1,935 Posts
The tag said 700; I'm really hoping that's the case because I didn't check. That said, I've never had a 27" frame that couldn't be converted to 700c. The canti posts on this are quite narrow though.​​​​​​
Cantilever brakes can be a bit trickier to convert from 27" to 700C. MAFAC cantilevers, for example, don't offer any reach adjustment for the pads. Shimano MC-70s have a few millimeters of reach adjustment, which may or may not be enough, depending on where the posts were brazed.
JohnDThompson is offline
Likes For JohnDThompson:
Old 02-22-24, 10:08 AM
cinelliguy
cinelliguy's Avatar
Bikes: 57 ExpressWerke, 58 CinelliB, 62 CinelliB Altenberger, 70 Cinelli SC, 76 Masi, 77 Colin Laing, 78 Ritchey, 80 Jack Taylor, 82 Appel, 82 Davidson, 85 Ironman, 92? Andy Gilmour, 04 Peter Johnson, 91 Ed Litton, 11 Bianchi
Quoted: 96 Post(s)
Liked 451 Times in 133 Posts
Bravo! Looking forward to the build thread on this Merz. Congrats :-)
Guy
cinelliguy is offline
Likes For cinelliguy:
Old 02-22-24, 11:03 AM
jPrichard10
Quoted: 226 Post(s)
And the posts on this look quite narrow. But chances are that this was made for 700c it sounds like. Here's hoping at least; I'm away from home until late tonight so I can't check!
Old 02-22-24, 12:13 PM
VRJAKE
Bikes: Bakers dozen is the limit!
Quoted: 87 Post(s)
Liked 445 Times in 140 Posts
Ya, recommend doing this. Gugie will be able to test fit or measure to figure out the kit needed. Need to confirm BB threading in the very low chance it's 753 with a French threaded BB shell. And is 26.8 the right size pillar? Probably but worth checking.
Due to the down tube decal, may be an earlier one, but good to connect with Jim Merz, he lost some early build sheets, but if he doesn't have access to it, he often remembers the customer, promising that he will as how many 65cm frames did he build?
VRJAKE is offline
Old 02-22-24, 12:19 PM
romperrr
Pedal to the medal
Bikes: 1991 Team Miyata Track, 1992 Lemond Alpe d'Huez, 19?? Schwinn High Serra, 1982 Trek 614, 198X Raleigh Alyeska
Quoted: 289 Post(s)
Liked 205 Times in 131 Posts
Wow, great score! Build it with what you can for now and gradually upgrade as your finances allow. I'm so glad to hear you got this frame after pining for it for so long.
romperrr is offline
Likes For romperrr:
Old 02-22-24, 12:22 PM
jPrichard10
Quoted: 226 Post(s)
I had seen elsewhere that he doesn't have the build sheet for this one, but I agree: how many frames this size did he build this early? Hopefully he remembers a little about it.
Haven't checked the BB threading yet. 26.8 fits great (just barely slides down with gravity with the bolt open), but I don't have a 27.0 to check.
Boy would I love to discover this was 753. Is that likely? I'm assuming it's 531 or SP at this point. Not sure how much Jim mixed and matched, but no tubing sticker (or traces of one) might indicate a "maker's blend."
Old 02-22-24, 12:28 PM
VRJAKE
Quoted: 87 Post(s)
I'm lucky to have a 753 Merz frame to care for (it needs paint), build sheet dates it 1980. 27.0 seat post, French threaded BB, per Jim, early 753 tubing was available in French metric sizes, hence the BB shells. Steerer is standard 1", English thread taking a 22.2 diameter stem quill.
VRJAKE is offline
Old 02-22-24, 01:32 PM
merziac
merziac's Avatar
This one is MM073, Jim doesn't have the build sheet for it but it is between 2 that were built in Jan 1976.
Not sure if he remembers much else but now that you have the frame I'm sure he'll tell you what he can.
Here's a timeline, doesn't look like it would have been 753 although Jim was the first American builder to use it, so you never know.
https://bikeretrogrouch.blogspot.com...nolds-753.html
merziac is offline
Old 02-22-24, 02:02 PM
bulgie
bulgie's Avatar
If you determine the tubes are metric, then it's definitely 753. No way would Jim have used metric tubes for any other reason.
One clue, not conclusive by itself but indicative, is if the BB shell is a Cinelli investment cast that says "FRANCE" in the flat spot on the bottom. The shells weren't made in France, that's just telling you it's a French shell as in threading, and metric sized tube sockets.
26.8 seatpost is also indicative of 753. Normal French frames with metric tubing (531 or Vitus) take 26.4 or 26.6 posts. A 26.8 post in a 28.0 tube is possible with 531 but only just barely, and uncommon. Like putting a 27.4 post in a 28.6 tube — you do see it in 531 sometimes but more often you see 27.2, with 27.4 more likely to fit in 753.
Honestly though I'd hope it's not 753 if it were mine, due to how whippy that would be in such a large frame. So my money is on 26.8 being the seatpost due to a heavier 28.6 seat tube, chosen for adequate stiffness for such a large rider. Did you say it was a 66 cm? I don't think 753 seat tubes even came that long.
bulgie is offline
Likes For bulgie:
Old 02-22-24, 02:09 PM
jPrichard10
Quoted: 226 Post(s)
Well for the first time ever, here's hoping for French threading!
Somehow I've never found a frame too whippy, but I suppose there is a limit eventually.
Might have to sneak home on my break just to ogle and check sizing.
Old 02-22-24, 05:12 PM
VRJAKE
Quoted: 87 Post(s)
If frame date is 1976, 753 was reportedly launche then, agree with Bulgie, 26.8 post likely means thicker gage tubing to support a large frame. Caliper to the diameter of the seat tube would help, if 28.6, not metric.
VRJAKE is offline
