Cork in the seat tube?
1. Was this a common back in the day? My 68' PX 10 has what appears to be a cork rammed in the seat tube.
2. How the heck do you get it out?
After I discovered there was something stuck in the seat tube, I took a piece of wood dowel and poked at it. I broke off a piece of what looks like a cork
Now, i cannot get the darn thing out.
Quoted: 3375 Post(s)
Liked 5,514 Times
Looong corkscrew?
Liked 5,514 Times
I was thinking of the business end of a wine corkscrew welded to a 1/4" steel rod.
Be thankful it's not mummified remains... https://www.bikeforums.net/singlespe...onversion.html
Likes For FBOATSB:
Likes For Jon T:
A long aircraft bit is the most sensible. In a shop we might have figured out a way to use compressed air, because it's fun and dangerous.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
Try a wheel spoke or a wire coat hanger.
Best, ben
Best, ben
Voltaire
Voltaire
aka: Mike J.
I’m thinking some previous owner stuffed some cash or paperwork or theft-recovery identification under the cork.
Remove the bottom bracket and use air pressure to pop the cork out, just be sure to have the opening pointing in a safe direction to avoid injury and contain whatever pops out.
Life happens, don't be a spectator.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Quoted: 913 Post(s)
Liked 515 Times
ya know....i may just have this bit.....man, if I could dig it up,
Stripped down Xmas 2017 then he waited all year 2018 for the rechromer to do his magic, didn't he only just get the chromed frame back last week?? patience brudda, you're not the only one waiting to see
Liked 5,800 Times
Just go to the latest post on jyl’s phat bianchi thread
Remove BB. Run a piece of all-thread through the cork, put a washer and nut on in the BB shell, clamp the other end in a bench vise, and yank on the frame.
If you don’t have a bit long enough to drill the cork, you can grind the tip on the all-thread and chuck it in a drill.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I guess the plastic bag trick won't work if it's not a wine bottle
Genesis 49:16-17
Genesis 49:16-17
Quoted: 569 Post(s)
Liked 582 Times
If not in a hurry the cork moth (nemapogon cloacella) might work, don't let them spread to your wine bottles.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
It could be a Gino Bartali secret message.
Commence to jigglin’ huh?!?!
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
Using a cork in the seat tube was a common way of carrying spare spokes on long tours. Push the cork down "far enough" that you can stick a few spokes in it with the elbows up. If you need a spoke, just loop a piece of dental floss around the elbow and pull it out. Wrap a piece of dental floss around one of the seat rails and secure it with scotch tape. It actually is an ingenious solution to a common problem. Some frames, like the Surly, have a spare spoke holder on the DS chainstay, serving a dual purpose there.
Dale, NL4T
Dale, NL4T
Likes For speedevil:
