New to bike repair- brake caliper selection question.
xposting this to a few forums as I truly don't know where to start!
Link to current setup **JK can't post links yet**
I come from a car repair background and am trying to learn more about bikes. I have a bianchi I use to commute, and an ol' fuji single speed I'm using as a learner.
Just toyed around on the brakes a minute and one part broke (old). Yay! New parts! But how do I know which calipers to get? The options are overwhelming and endless.
I tried to link to some options I'm seeing on dreaded amazon but I can't post links yet.
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Start here https://www.sheldonbrown.com/brakes.html
Friendship is Magic
Bikes: old ones
Quoted: 26424 Post(s)
Liked 10,381 Times
The only caveat is that they are all set up for a recessed brake nut, so if your bikes are old enough, you might either need to drill it ( which is to be avoided if you can help it...drilling out an older fork for the larger opening required for a recessed nut can often go wrong), or look for nutted brakes (the nut is exterior to the fork/rear brake bridge.)
Quoted: 1819 Post(s)
Liked 1,696 Times
