Misery with swap from Shimano to FSA square taper crank
Quoted: 10 Post(s)
I want to switch to a FSA Vero compact crank 330-6482 with JIS square taper on my 1995 Lightspeed Catalyst but the original BB appears to have a square taper segment that is too short. The bike has a Shimano FC-6400 tricolor crank, sealed BB with 115.3 mm axle length and 68 mm wide BB shell. What BB is needed?
Many thanks
Jim
Many thanks
Jim
Quoted: 1438 Post(s)
Liked 1,092 Times
Perhaps you have a "low profile" JIS bottom bracket: https://www.sheldonbrown.com/bbtaper.html You could replace it with a more-common standard one. Perhaps FSA has a recommended length for that crankset.
Likes For dsbrantjr:
Really Old Senior Member
Have you actually installed the crank, or just eyeballing?
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Do yourself a favor and use a Shimano crank with HTll. You can get a nice Sora compact for under $50.
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Marwoz87
Bicycle Mechanics
11
12-03-14 08:53 PM
TeamCNY
Bicycle Mechanics
6
10-04-10 04:23 PM
