Video: CF failure
Quoted: 18883 Post(s)
Liked 10,645 Times
Quoted: 4559 Post(s)
Liked 2,798 Times
BTW, that Lanterne Rouge YouTube channel should be on your subscription list. That kid is good. Check out his race analysis videos. His insights and dissections are better than 90% of the broadcast commentators and analysts.
Likes For canklecat:
Quoted: 3192 Post(s)
Liked 2,461 Times
When you got hours and hours to replay/rehash, most anyone can come up with a better dissection than the people on the spot.
Liked 2,461 Times
Liked 2,461 Times
Still in awe of the rider's mental coolness throughout the incident. He realizes he is going to wreck, and does everything he can to minimize it. He had no choice, though.
I'm surprised that another view of the incident from the side has not surfaced. Maybe someone got paid a good chunk of change to not make it public.
Likes For seypat:
climber has-been
Quoted: 3342 Post(s)
Liked 3,443 Times
I've heard it bandied about--usually as bike mechanic scuttlebutt--but I've never found a manufacturer publicly requiring it.
On the other hand, some manufacturers provide downright dinky compression plugs that couldn't possibly cover the stem clamp length. Like Cannondale:
I had an Easton fork that didn't even use a compression plug at all. Instead, it had an adjuster you installed under the stem on the outside of the steering tube, turning a screw to produce the preload:
So, has anyone seen written notices from manufacturers requiring these "full length" compression plugs?
Ride, Rest, Repeat. ROUVY: terrymorse
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
I've seen some things over the years that would make this crowd go into perpetual fear of every piece of bicycle gear they have and never ride again.
We all can guess on all of this forever. One thing I do know from experience is that punk cat 1/2 pro kids think they're invincible and care little to nothing about the actual tech and more about how cool something looks. I would place a bet on whether that setup had a spacer or not and I am siding on the side of not....because "slam it" and stuff. not only that but most of the gear in any race at that level of ability has been in some sort of a wreck. Just has. No team is using ultrasound to inspect anything. *shrug*
I'm sorry but my first reaction when watching the original race clip was to laugh. It's probably because I have seen enough wrecks to just intuitively know that guy made it out with little by way of injury. He was lucky. His bars were mushy for a while though so....
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
The rider who crashed was using his rear brake, despite the bars being detached. If you watch the video closely, his back wheel is locked up when he's doing that fish tail skid back and forth. It looks like me might be also consciously trying to use the bars to reach down to manually steer his front wheel, but not sure about that. In any case, he was fully in mental control of his body and reacting so well to the chaos of his broken bike. Watch his face and concentration -- he's still riding the bike all the way to the ground. Super impressive.
Quoted: 1455 Post(s)
Liked 1,477 Times
Yeah, the more you watch the videos, the more impressive the riding is -- mostly his, but also the guy between him and the barriers who leans against him and stays upright early on.
Liked 1,477 Times
This is the most surprising (and impressive?) thing about this video to me. His bars are visibly loose almost as soon as he comes into the frame. You see him look down at them as they're wobbling around 2 seconds into the video, and he takes at least 5-6 more pedal strokes before they break off.
Liked 2,461 Times
He was probably looking for Cavendish along the wall to use as a buffer. Give him an elbow and get some support. He wasn't there, so he used the other guy.
One thing that can damage a steerer tube that few mechanics consider is the clamp used to guide the cut saw when it's shortened.
Take a spare length of carbon steer tube you've got laying around and clamp it up tight with a Park steer tube cut guide. If you use the force that might feel right from clamping a piece of wood that's going to be sawn, you'll see it will totally deform the thing.
Over clamping a steer tube when you're cutting it is a sure way to crush some of the carbon.
bike whisperer
Quoted: 1520 Post(s)
Liked 716 Times
That's another thing - even with the diamond blade in the hacksaw, it's still possible to splinter the cut. Not with a Dremel. But then there's the dust...
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
just another gosling
Quoted: 3873 Post(s)
Liked 1,920 Times
I once had an aluminum stem break on me. I'd just finished a somewhat technical descent up to 40 mph, was on the flat and crossing RR tracks when I felt the stem get wobbly. I sat up, took all the pressure off, and managed to ride the thing another 10 miles. Weld failure. I admit to enjoying sprinting and really pried on the bars back then. I also had a steel bike, threaded stem, which felt like I was going to rip the bars right off the bike. Good thing I never did. I also had a stem bolt break in the parking lot before a populaire, different stem. I was doing my usual "torture test everything before the ride." Bontrager later recalled that stem. I drove home, got my spare bike, came back and started ~59' late, still managed to finish in the middle of the strung-out riders. Those were good days. I don't break anything anymore.
I wrote to the broken stem's manufacturer, explained how it had failed, no answer. Not on the market anymore, anyway.
Results matter
Results matter
Likes For 02Giant:
Likes For eduskator:
steel frame breaks too
https://www.bikeforums.net/cyclocros...p-cracked.html
Liked 10,645 Times
Likes For Seattle Forrest:
Liked 10,645 Times
Well, you definitely shouldn't ride a bike somebody is sabotaging. That's the take home message from this thread.
I'm doing it wrong.
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Quoted: 9742 Post(s)
Liked 2,812 Times
What I took away from it was that I'm not getting involved in a bunch sprint unless I get paid for doing so...but I already knew that before seeing the video.
Likes For RJM:
