I'm convinced - large frame, thinwalled tubeset = plushest ride
Quoted: 7348 Post(s)
Liked 2,465 Times
@ascherer, you're describing my feelings for my McLean (analogous to your Mercian) and my International. I've also had my McLean a long time, in my case, 36 years. I feel melded to it when I'm riding, though I admit I get backaches after riding it. Maybe I need the bars higher. Right now, my McLean has 28mm Continental GP4000S-II tires on it, and they are amazing. What's the maximum width your Mercian will take?
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
You guys amaze me. All my bikes feel the same to me, 531, A&P kromo, plain gauge or butted, columbus, tange no 1, whatever. Even aluminum I don't think I notice a difference. I have them all set up more or less the same, but I notice differences in the brakes, gears, etc, and maybe tires, but even then I'm not sure.
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
I think my 55cm DeRosa SLX is plush, but like @rhm I think all my bikes ride similarly. I’ll have to test your theory on the 60cm Ciocc, also SLX, with my favorite tubular wheels. Actually, my only tubular wheels...
Liked 2,465 Times
My bikes ride noticeably differently, but I can't be sure which factors contribute to the differences. And neither can you.
Quoted: 938 Post(s)
Liked 2,939 Times
Have you had a fitting for the Maclean recently? I know how much you love that bike, you might still be comfortable on it. That’s a partnership worth maintaining!
Quoted: 938 Post(s)
Liked 2,939 Times
I’ll always remember riding my International at your place upstate the first season I had it, and going right into a pothole because it didn’t just scoot around it like my Mercian would. On that bike a subtle shift of body weight puts it just where I want to to go. The Raleigh needs more input. Not worse, just different. I like that my bikes feel distinct from each other.
Liked 2,465 Times
@ascherer, I remember that, as I saw your bike jump to the side. In my mind, the International is decidedly less agile than other bikes. Different input doesn't change that. It just can't dart around in certain ways. It's the result of a tradeoff I don't mind making when I ride it. I just don't get into situations where such agility is needed.
Quoted: 3241 Post(s)
Liked 2,512 Times
Quoted: 981 Post(s)
Liked 1,844 Times
I still have the 25.5" Raleigh Super Course 12 frame that was my first road bike, which I have intended on restoring several times but never got around to. The excuse was that it is technically slightly large for me (though with 700c rims and 32mm tires I can just stand over it flat-footed) and a bit whippy, with enough flex to make climbing almost impossible. It had double butted 531 main tubes and unidentified stays and fork blades.
On flat ground it was absolutely the "plushest" ride I've had! I may still re-equip it for a tour of the Sacramento Valley I have planned.
-Gregory
-Gregory
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I've recently put that bike away in favor of my old Peugeot and Trek 750. There's a real difference in how much road buzz you can feel in the steel bikes (less). Despite having 50mm tires, the Roam seems to transmit a lot more of the surface to the rider. I imagine this is due to frame material, tubing shapes and sizes, relatively stiff 31.8mm handlebar size, non-compliant fork material (steel stanchions), etc. Compared to the Roam, my Peugeot and Trek just feel...smooth. They have narrower tires, but the ride quality is just...smooth.
With that and the complete lack of noise (the drivetrains on both are nearly completely silent), it's a much more peaceful ride on my old bikes. It feels like a more "elementary" experience -- just me and the outdoors. In some ways, a good bike blends into the background and disappears.
Quoted: 981 Post(s)
Liked 1,844 Times
If such observations weren't grounded in some kind of actual difference, then methinks generations of riders would not have bothered paying extra for the butted tubing and the craftsmen would not have focused on building almost exclusively with the stuff. Weight and technological innovation was certainly motivating factors back in the day, but if all you could say was that your bike weighed a pound or two less for all the extra expense of having a frame made from quality tubing, I think it would not have been held to such high standards.
Come to think of it, I've also noticed rather drastic differences in stiffness between butted and plain gauge 531 tubing on two different 25.5" Raleigh Super Course frames, and both were equipped with rims laced to Weinmann concave rims and similar quality tires.
-Gregory
Quoted: 106 Post(s)
Liked 36 Times
So recently I’ve had two cromor bikes, one a schwinn prelude that was as small as I could comfortably go... maybe a 54-55? Running on semi aero campy rims laces to some suntour hubs. It was stiff and buzzy over rough patches. Traded it for a viner in size 59, and kept the wheel set. The viner accelerates just as quickly, but the ride is smoothed out.
Now, the difference between the two bikes I think actually comes down to the seat stays. The viner stays are pencil thin, where the schwinn were a bit larger diameter thru the entire length. The fork on the prelude was hi ten compared to the viners cromor, but sitting is where I notice the most difference, not in my hands.
Quoted: 101 Post(s)
Liked 49 Times
Quoted: 659 Post(s)
Liked 595 Times
The smoothest ride in my little fleet is the ‘87 Miyata 712 Comp. though it is a triple butted frame it’s probably the heavier rear stays and such for the tri-athlete that lends to the smoothness. At 23.5 pounds it is also my heaviest in this fleet of racers.
Quoted: 1627 Post(s)
Liked 630 Times
I'm convinced, too. The Grandis - supposedly made from SL main tubes, at least - is a "soft" ride no matter what wheel set I put on it. And I've tried at least a half dozen. Not really "whippy," though; just a compliant, forgiving, all-day comfortable ride. Whenever I take this thing through a really bumpy, pounding, gravel-crushing ride, I feel like I'm going to break it (I weigh 200 lbs). But far, so good.
You want whippy? My relatively small (59cm square) Raleigh Technium Pro was whippy as hell under all but the most leisurely riding conditions. This was with a good, solid wheel set that felt really hard on other bikes. Not sure what to make of the tube set; aluminum main tubes glued to cro-mo everything else. I guess that's the culprit; who else to blame?
And of course the tube set makes a difference. Longer and probably slacker than any of my other bikes, my '90 Cannondale is also notably stiffer (regardless of the wheel set). Plush it is not. But the right saddle and fat tires make it plenty comfortable.
Strong Walker
I have only a few data points, and also only my touch points to prove me accurate.
61 cm all SLX with light internally lugged sloping crown fork.
62 cm R531 db f+f.
Not saying that it's a better or faster ride.
Not discounting drivetrain stiffness as a good thing.
Not against mixing tubesets for size and ride tuning.
But all tubes thin means 'Cloud-like' rides. even with 22mm tires.
yeah, yeah... geometry makes a big diff. But 73deg parallel seems a good common point of beginning, for discussion purposes.
ANYONE ELSE AGREE?
YMMV
will update with pics.
It only makes sense, a tube that's longer and a rider that's bigger makes for a more compliant ride.
62 cm R531 db f+f.
ANYONE ELSE AGREE?
YMMV
so, you *may* feel a difference in the "plushness" of the ride of two different bikes, but its not because of the stiffness of the frame.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
in short, i don't agree. at the same force applied, a diamond frame - any frame- will give about 1/10th of what the handlebars (26mm) do, 1/5th of stem and seatpost, any amount of the fork, wheels, saddle and tires do. physics formula of any combination of springs in "serial" says the softest in the chain has the most impact, and the stiffest one the least. the frame is the stiffest part of the equation.
does a 56cm frame possess the same ride characteristics as a 62cm - given identical components?
I don't know the answer.
Quoted: 288 Post(s)
Liked 329 Times
I doubt it. Aside from handling, my guess is that a larger frame has longer tubes and “more metal” to distribute road shocks. Therefore a larger frame would generally have a more compliant ride. Of course if it doesn’t fit you well you may be giving up comfort in other ways.
Quoted: 4511 Post(s)
Liked 6,378 Times
Totally agree with the opening statement and adding that the builder and the build can be just as important.
Many bikes ride well but it can be very special when a bike really works for you, I always equate it to vinyl and digital, vinyl has soul, digital does not.
In olden times - and I don't know when the change occurred - the most common Reynolds 531 tube was 'Club Special' butted to 21/24 British Wire Gauge. That worked out to 0.81/0.56 in metric measure or 0.032"'0.022" proper Imperial measure. All three main tubes. So a good touch lighter than Columbus SL and very close to the 0.8 that would be considered an extralight tube. Combine that with pencil stays and the frames were plush. The Super Resilient fork was mostly for Froggy, some English builders had them.
Lots of basic slightly better French bikes were built with Vitus 888 which simply meant all three main tubes were 0.8mm straight gauge. Rides about same as a 0.8/0.5 tube only heavier. In larger frame sizes this meant Motobecane Grand Touring or any similar could be quite springy.
Quoted: 767 Post(s)
Liked 1,898 Times
Just wanted to share my liking for my Vitus 888-tubed Motobecane Grand Sprint. Mine's a 23" frame, so not the largest, but it is a very comfortable bike. The fit probably has a lot to do with that in my case, but I really love the way it rides. I would call it plush compared to my Ironman, or my Columbus Cromor Puch, although the geometry is also different between the three. I'm not experienced enough to really understand the subtle differences between tube sets. I have mine setup with Campy NR shifters and derailleurs. I would encourage anyone to give a Vitus 888-tubed bike a good ride. Mine's a keeper.
Quoted: 237 Post(s)
Liked 83 Times
I've no idea how thick the walls of a Super Resilient blade might be The outer diameter is sharply reduced and that is plainly visible. Riding the SR blades there is no question they are plush.
Quoted: 237 Post(s)
Liked 83 Times
Reynolds still issued Wire Gauge specs for their tubing at least until late 60s. In 40s Britannia still ruled the waves, or thought they did, why would they be metric?
S.R. fork blades are plusher than plain gauge fork blades because they were still butted, but they were thicker than some taper gauge fork blades, which were offered in a variety of tip diameters. Resilient means able to spring back after being bent, not the ability to be bent more (in plain English, stronger) and that's what S.R. blades appear to be designed to do. They took a butted fork blade on the thicker side, then made it even thicker at the moment of bending. As far as I can tell, S.R. blades were designed by Ernest Russ (who also designed the rapid taper chainstay), for the purpose of being being stronger and being able to survive things like head of collisions with a car (Russ' claims, not mine).
I can only assume that the idea that S.R. was extra plush was started because S.R. blades are more expensive, and lighter tubes are more expensive, therefore S.R. blades must be lighter. S.R. blades were indeed higher cost and a premium option, but this is because the pre-tapered blanks were triple butted (1.2/1.4/0.9) instead of single butted like normal fork blades (1.2/0.8 or 1.2/0.9). You could make the argument that they're technically lighter than the 1.4/0.9 heavy duty (track) blades but if S.R. is supposed to be extra plush it only makes sense to compare it to the normal light blade. The New continental blades were drawn out even thinner to 1.02/0.56.
If you have any primary or even secondary source that can authoritatively state that S.R. blades are indeed of lighter gauge or thinner or magically somehow more plush, I'd love to see it, but as far as I can tell they're actually heavier, stronger fork blades than regular 531 taper gauge (albeit with thinner gauge tips than non-531 PG fork blades).
