Is this normal wear for cleats ?
Bikes: FUJI Nevada 1.0 2009
This is from just one single ride, they were new before that. It's my first time using clipless, so I scratched the cleat against the pavement a fair bit when practicing before going out on the road, just because obviously I wasn't born knowing how to do this.
So I'm wondering if this is normal wear for a single ride or if my inexperience accelerated the decay of the cleats life.
stole your bike
if you were scraping them against the pavement repeatedly then that's to be expected.
I like pie
I like pie
moth -----> flame
Bikes: 11 CAAD 10-4, 07 Specialized Roubaix Comp, 98 Peugeot Horizon
Maybe - Keo cleats do wear down if you do a lot of walking in them - try not to drag your foot on the ground as you come to a stop, etc. Don't sweat it until the cleat wear indicators start showing (you see white teflon coming through those little holes at the rear of the cleat.)
Still, cleat covers are your friend.
BF, in a nutshell
BF, in a nutshell
Bikes: '84 Schwinn World Sport, '77 Fuji Sports 10 (In Pieces)
I rode with Keo's last summer and found that the cleats had a really short lifespan, even when I was being careful not to walk on them more than I had to. I switched brands because of this.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Your foot shouldn't touch the ground until you've stopped, so there shouldn't be any scraping either on the cleat or your heel.
I get a couple of years out of cleats.
Also you might want to consider the gripper version of the Keo cleats, there is rubber where the wear indicators are on the no gripper version.
Quoted: 163 Post(s)
Yeah, I go through about 3-4 cleats a year on my clip-out foot, and 1-2 on the other foot. I don't replace them as pairs, just as the individual cleat wears out. Don't worry about it. They get harder to clip/unclip when they wear out, which is counterintuitive.
i get about a year out of a set of cleats. my cleats look newer than that after 3 months of use and i walk on them a lot.
Bikes: CAAD10 Rival
Quoted: 12 Post(s)
And I am a beginner too and use Shimano SPD-SL pedals. I walked in mine a bunch of times on asphalt and barely had any wear on cleats. Like some mentioned, don't drag them on the ground. Walk with your feet directly lifting up perpendicular to the ground.
+1..... you should be practically stopped before putting your foot down. Anyone who is wearing out cleats and are not walking on them needs to practice there unclipping/stopping method.....
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
