What’s this Bianchi mid 1980s model?
Hi all,
I’ve got this Bianchi from the mid-end 80s I guess. I’ve been looking what model it exactly is, but can’t find it really.
Especially the rear triangle never matches (at the rear derailleur, and at the saddle).
I wonder what components originally were mounted (definately not the handlebar currently mounted ).
I assume the original color was celeste, considering the little scratches on the frame which shows the celeste color.
Bianchi Goddess
Quoted: 2937 Post(s)
Liked 2,934 Times
Hi all,
I would say this is more late '70s early '80s. It is curious that there are no cartouches on the frame or fork, is there anything on the dropouts? Can you read the BB threading?
Yes those handlebars and stem are not original, I don't think that high rise adjustable stem was even around until the later 2000s. The wheels are also much newer than the frame and I suspect the brakes were installed to match the deals.
If you looking at the correct catalogs for your country, conentrate on matching the crank (SR?) and the headset. @T-Mar would probably know the year better than I though
Sugar "Kane" Kowalczyk
Quoted: 4722 Post(s)
Liked 3,039 Times
The subject bicycle appears to have been largely rebuilt, complicating identification. The frame itself, appears to be one of the Italian manufactured Rekord 74X variants from the very late 1970s. The serial number, which should be on the front of the upper head lug, will tell us the year of manufacture, while the seat post diameter will give us an indication of frame level.
feros ferio
Quoted: 1393 Post(s)
Liked 1,330 Times
Your serial number indeed appears to be stamped across the top head lug; mine wraps around the seat lug. T-Mar knows best, but I wonder if yours is Japanese. The easy way to tell is the BB shell width and threading -- 70mm 36x24 Italian, 68mm 1.375x24 ISO/Japanese. Do report the seat post diameter, as well -- mine is 27.2mm, befitting its Tre Tubi frame with double-butted CrMo main triangle.
Likes For John E:
Likes For big chainring:
I did some quick measuring this morning.
Seat post diameter 26,6mm
36x24 thread Gipiemme - Italy (*marked - not measured)
bb 68mm (I'm now wondering if I made a mistake here, but I was convinced it was 68mm this morning.)
Serial number on the top head lug:
7A00177
With sticker "Bianchi 00.4.23" (if I read correctly)
7A00177
Liked 3,039 Times
Serial number indicates a 1977 model. Definitely Italian manufacture, based on both the serial number and bottom bracket thread standard. Seat post size is too small for a Columbus tubeset of the era but too large for for Bianchi's Calibrati, high tensile steel. It could be a something like one of the Falck tubesets. The 00.4.23 sticker is the model number, indicating a Rekord 746, though OP previously suggested a possible repaint and re-decal based on underlying celeste paint.
Likes For T-Mar:
Quoted: 1609 Post(s)
Liked 2,216 Times
@.joeri. - Is there a chance the post is undersized? Are the ears on the lug pinched?
Liked 3,039 Times
26.2mm is the typical post size for Bianchi's Calibrati hi-tensile tubeset. found on many of the Rekord 74x models.
Likes For T-Mar:
Likes For .joeri.:
