Grenaded a freewheel tool...
Old 01-08-23, 04:44 PM
francophile
PM me your cotters
francophile's Avatar
Quoted: 1137 Post(s)
Liked 590 Times in 422 Posts
Found a random wheel with a Sachs LY 96 freewheel, M700 high flange MTB hub. Freewheel frozen, but salvageable, and figured the hub was definitely worth salvaging.
Hit it with some PBB to loosen up the freewheel and sit overnight. Freewheel started to spin once the grease dissolved, but the freewheel wasn't budging off the hub with standard force and a 24" adjustable wrench. Slapped my Shimano fw tool in the vice and gave it a couple torques... SMASH! Shattered to many small bits.
I bought this one on Amazon a couple years back to replace my Bicycle Research tools. Knowing Amazon, it's entirely possible it's not even legit, there's so many knockoffs on there anymore.
Anyone seen similar? I've definitely put more force into others. No clue why this blew to bits. Yes, I was definitely spinning the correct way!
francophile is offline
Likes For francophile:
Old 01-08-23, 04:47 PM
fender1
fender1's Avatar
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times in 233 Posts
Oof!
fender1 is offline
Old 01-08-23, 04:59 PM
Schweinhund
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times in 456 Posts
Yeah, that's that famous park tool quality.
Park tool stands behind their product with a lifetime "you bought it, you got it" guarantee.
They say they are forged, I say they are cast. I'd bet money on it.
Schweinhund is offline
Likes For Schweinhund:
Old 01-08-23, 05:02 PM
mechanicmatt
Hoards Thumbshifters
mechanicmatt's Avatar
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 339 Times in 193 Posts
I've had an old uniglide one that had the teeth grind down and an Ice Toolz version cracked apart like yours. It is likely from over hardening the steel, which will make it strong but instead of stretching or deforming, it will instead fail by blowing apart like a cracked egg.
mechanicmatt is offline
Likes For mechanicmatt:
Old 01-08-23, 05:04 PM
C9H13N
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times in 121 Posts
I’m normally a Park hater but that’s a Shimano TL-FW30 in the picture.
C9H13N is offline
Likes For C9H13N:
Old 01-08-23, 06:25 PM
Velo Mule
Velo Mule's Avatar
Quoted: 813 Post(s)
Liked 1,028 Times in 668 Posts
That tool does have a thin wall on it. And that is some damage on the tool. Wow. It was hardened. That is for sure.
All I can say is try it again with a new tool or bring it to a bike shop and see if they have better luck.
Heat often helps as well. If things get to the point that you break another tool, dismantle the freewheel so that you can heat up the only inner part of the freewheel without heating up the rest of the freewheel and try it again. Keep cycling the heat until it gives. It will come off.
Last edited by Velo Mule; 01-08-23 at 06:34 PM. Reason: Because I missed the fact that Francophile said that he did the bench mount method.
Velo Mule is offline
Likes For Velo Mule:
Old 01-08-23, 06:39 PM
francophile
PM me your cotters
I may try again with heat, and thanks for the edit, although I realize in hindsight I misspelled "vise".
I still have the wheel. I'm actually going to try heating the freewheel, and hit it from the backside with PB to cool it, sometimes that'll wick penetrant up between the metals as it cools. I just don't know if I want to risk exploding another tool. Definitely not going to throw my Bicycle Research version, even though it's thicker-walled and I think he machines from solid block vs. cast+harden, I don't want to grenade it also.
Old 01-08-23, 07:06 PM
Steel1
Quoted: 45 Post(s)
Liked 121 Times in 55 Posts
I have the Park FR-1.2 which has similar thin walls. Never had a problem, even with prodigious torque applied with my 3’ long pipe breaker bar extender.
Steel1 is offline
Old 01-08-23, 08:14 PM
francophile
PM me your cotters
For S&G, I ordered a couple off the old scammerzon site. One from VANICE, and another from Bikehand. I wanted to try the BW brand, looked similar to the VANICE, the longer body looks appealing. Will see how it goes.
Old 01-08-23, 08:31 PM
wschruba
Quoted: 499 Post(s)
Liked 63 Times in 48 Posts
Jeebus. The Shimano tools are impact rated, so that's some serious torque that went through there.
wschruba is offline
Likes For wschruba:
Old 01-08-23, 08:41 PM
repechage
Quoted: 3464 Post(s)
Liked 2,831 Times in 1,997 Posts
yeah, need to resume clean living
repechage is offline
Likes For repechage:
Old 01-08-23, 09:08 PM
etherhuffer
etherhuffer's Avatar
Bikes: Surly Long Haul Trucker,81 Fuji Gran Tour SE, 83 Fuji S12S LTD, Voyageur 11.8 chrome, Raleigh R300 Touring, Voyageur 11.8
Quoted: 283 Post(s)
Liked 510 Times in 229 Posts
In the iffy advice dept, I use a very low powered air impact gun on some stuff like this. My big one would do what just happened, blow the tool apart. My really low power one with air adjustment dialed down sort of beats/vibrates the stuff apart without damaging the tool. You really have to know your air tools to do that. YMMV
etherhuffer is offline
Old 01-09-23, 11:44 AM
Bad Lag
Bikes: 1974 Bob Jackson - Nuovo Record, Brooks Pro, Clips & Straps
Quoted: 1104 Post(s)
Liked 794 Times in 452 Posts
BUMMER!
I had a Campagnolo crank removal tool shear in half, if that counts. It broke right at a stress riser which coincided with where the wall was thinnest.
At the time, I was devastated. Obviously, I am still disturbed by it.
I do still have the "peanut butter wrench" that went with it when I purchased the pair.
Bad Lag is offline
Old 01-09-23, 12:21 PM
nlerner
Quoted: 3815 Post(s)
Liked 6,736 Times in 2,621 Posts
Note to self: Do not challenge @francophile to an arm-wrestling match.
nlerner is offline
Old 01-09-23, 12:43 PM
francophile
PM me your cotters
Know your compressor, you mean? You could just dial down the regulator for less kick, right? I contemplated throwing my electric IH on it, but the only impact socket I have in that size is 1/2" and my IH is 3/4" drive. I lack an impact reducer for that stepdown. I thought about whipping out my butterfly IH to feather it out. I can't seem to find that damn thing. I found my impact chisel. Not sure where my butterfly went. So much of my stuff is boxed right now...
Those Campy PB wrenches are the best. I dunno what the hell I'd do without mine. Out of all the tools I own, it and my Campy t-handle are king. I could live without half my tools just having a pair of PBs and one t-handle.
Old 01-09-23, 12:46 PM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 1449 Post(s)
Liked 1,069 Times in 791 Posts
my guess (and I'm not a metallurgist, not even on TV) is this was just "bad luck" due to the tool being thin-walled, cast steel (and prone to having some hidden defects in that casting process) then heat-treated to make the splines "harder" but the entire tool more brittle, which is a trade-off.
If this had been made by forging and then finished machining it may not have "exploded" but probably cost a great deal more and there are still other ways a tool can fail (broke my heart when a beloved VERY thin-walled Phil splined FW tool "collasped" on me! But my replacement, same tool, has held up).
unworthy1 is offline
Likes For unworthy1:
Old 01-09-23, 01:30 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3597 Post(s)
Liked 3,418 Times in 1,944 Posts
I've broken thin-wall Phil removers, and Park's two-prong SunTour removers, but not (yet) a Shimano TL-FW30.
JohnDThompson is offline
Likes For JohnDThompson:
Old 01-09-23, 01:34 PM
squirtdad
squirtdad's Avatar
Quoted: 2342 Post(s)
Liked 2,843 Times in 1,548 Posts
to show that great minds think the same (take that for what you will ) i was about to put the exact comment in
squirtdad is offline
Likes For squirtdad:
Old 01-09-23, 01:45 PM
79pmooney
79pmooney's Avatar
Quoted: 4824 Post(s)
Liked 3,947 Times in 2,568 Posts
I look at those hubs and those removers and simply think that's collectively poor design to have one of the most highly torqued tool used on a bike to have that little material at the key spot. And yes, a delicate balancing act between hardness and strength with the real answer being more material.
Both Park and Shimano make good tools. But designing (or not designing and simple following along and making) FWs and hubs that require that thin a tool - well we really need a new metal that is substantially stronger and brittle failure free than steel. Or live our lives dedicated to the notion that FW threads will always be properly greased and not sit for years and decades, then removed. Or just accept that every once in a while, those tools break. (A good reason to clamp them in a vise and turn the wheel with both hands vs using a big wrench. Much less exciting. You don't slam your hands into things.)
79pmooney is offline
Likes For 79pmooney:
Old 01-09-23, 01:51 PM
79pmooney
79pmooney's Avatar
You just witnessed one of the dark places playing with vices can take us.
Old 01-09-23, 03:16 PM
JohnDThompson
Old fart
Other, thicker-wall tools were available for the Atom/Regina/Zeus splined interface, but those often required removing axle locknuts to seat the tool. In the case of Phil hubs, this wasn't possible, which is why they produced their extra-thin remover tool. That tool became popular with other hubs as well, since there was no need to remove the locknuts to seat the tool.
As others have noted above, the Shimano tools were impact-rated, but they can still fail. Fortunately, the need for unbreakable freewheel tools has been largely obviated by the wide adoption of freehubs, whose cassette lockrings don't need to be super-tight, and don't self-tighten with use. Only those of us who use and service the older technology need suffer with the breakable remover tools.
Old 01-09-23, 03:17 PM
etherhuffer
Quoted: 283 Post(s)
Yes, I have a nice line pressure adjuster
Likes For etherhuffer:
Old 01-09-23, 08:14 PM
Hondo6
Bikes: Yes
Quoted: 550 Post(s)
Liked 675 Times in 466 Posts
That may be true about Park Tool's freewheel removal tool(s). But the OP's tool - or what's left of it - appears to be marked "SHIMANO TL-FW30".
Hondo6 is offline
Old 01-09-23, 09:28 PM
79pmooney
79pmooney's Avatar
I know and appreciate the history, but still - the end result is poor from this engineer's view. (Like narrow chains and big wheel dish. Yes, it all works but the simple 1/2" x 1/8" chain and no or velodrome levels of dish; now those are clean solution!) (I never did like the need to unscrew the right locknut. I like that side near permanently tight and do everything from the left.)
Old 01-09-23, 09:33 PM
79pmooney
79pmooney's Avatar
That was a Park employee having a little fun. Got fired the next day and every trace of his employment banished.
