What's the Dumbest Thing You've Ever Done
Quoted: 821 Post(s)
Liked 254 Times
I can still shift with ergos, but maybe not for much longer.
Probably be back to DTs on my next project. Seems to be easier.
FWIW I have XTR thumb shifters on my Yeti and they're the hot ticket for me right now.
Bikes: Trek Farley, Giant Trance X, Salsa Vaya
Quoted: 89 Post(s)
Liked 75 Times
I tell ya, I feel a little bit better reading through these. I'm just a newb when it comes to this stuff but I've done many of the things mentioned above. Most painful was probably punching the big ring trying to get a pedal off, I had several fingers bandaged for days. However, my most boneheaded mistake is when I partially disassembled a rear derailleur to clean it. I thought I did a pretty good job getting all the gunk out, cleaning the pulley wheels, etc., I put that thing back together and I can't get it to shift right. I spent an hour fiddling with it, only to have Mike / 9volt take a look and see I had the pulley wheel cage on backwards. Huh. Never thought that would make a difference. Turns out another poorly shifting bike I had cleaned earlier suffered the same mistake - boy did I feel dumb.
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
Bought frame on eBay. Stuck seatpost. Sawsall. Sadness.
Jim
Jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
1989, age 12, riding my Murray 24in MTB, with a Super Soaker in each hand, headed for a dual wielding ride-by drenching, leaned harder than ever before around a corner, dragged pedal, broke collarbone
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 684 Post(s)
Liked 370 Times
Last year, on my “new to me” and really well preserved ‘84 Trek 610 I patched the rear tire, put it all back together, making sure the QR was tight and pedaled away.
Leaving the chain on the chain hook on the seat stay! I bent it! At the time it seemed like I bent the snot out of that thing, and a year later it’s not quite that bad...
But man, that frame was structurally pristine when it came into my hands and I botched it up. I still kick myself for that. Parts can be replaced but that chain rest is part of the frame! 😣
Put my full weight and force into a pedal wrench on the driveside……..large ring was fully exposed; wrench slipped. hand went into large cog's teeth with my full body weight
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
Uh, pretty easy.
Death fork? Naaaah!!
I once tried to clear a stoppage to feed on a M1 Thompson SMG by whanging the bolt knob forward to seat the round, as you would with a M-16.
Top
Top
Quoted: 378 Post(s)
Liked 1,409 Times
I chased a haji up two flights of stairs, down the hallway, and into an apartment. This before the UN allowed us ammo.
I bunny-hopped off a loading dock on a West Point banana bike. It was simply not equipped for a 4-foot drop.
I closed Tony's Tap the night before the Dairyland Dare. Twice.
I bet a guy I could run 3 miles in 18 minutes after a pint of tequila.
I offered to spar with a Korean Recon Marine in Tae Kwon Do.
I learned the subtle difference between an in'n'out done right and a roundhouse kick.
Or my head did.
I did the third "E" in SERE school. Very, very dumb.
The question is not the dumbest thing, because for some of us, the list is uh, long.
Maybe someone should ask "What is the least dumb thing you've done?"
Of course, I'd be stumped.
Or my head did.
OK, you win the question, but only because I'd expect more dumb things from a Marine. Were you one of those guys who yelled 'RECON' rather than 'AIRBORNE' at Benning?
Top
Top
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
- Lighter fluid assisted dragster style flaming burnout
- Evel Knievel style high arching jump assisted by springy plywood ramp at the bottom of a creek valley trail
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,693 Times
IMG_0063 by Dave The Golden Boy, on Flickr
IMG_2402 by Dave The Golden Boy, on Flickr
Commence to jigglin’ huh?!?!
Liked 1,693 Times
Lately?
How about forgetting the washer on a Sugino AT? Wondering why that crank extractor isn't working...
surly old man
Quoted: 46 Post(s)
Liked 42 Times
Jim
SB forever
SB forever
I feel your pain. I'm going to ride mine and see what happens I guess.
SE Wis
Quoted: 2738 Post(s)
Liked 3,379 Times
I always tell my kids,"only do 1 stupid thing at a time". It's when you mix multiple ones is when the SHTF
Quoted: 378 Post(s)
Liked 1,409 Times
It's only stupid if you get hurt ….BAD.
Now, I did see a bike shop I won't name (REI) break two gear pullers trying to pull off a Campy crankset, basically pulling against the spider. Proved to me that the Campy spider was stronger than their Park gear puller.
I also saw a guy try to use a channel-lock pliers to remove an external BB cup set from a Trek Y-Foil. Failed, killed the BB.
Quoted: 378 Post(s)
Liked 1,409 Times
I bought a bike with STI's before I knew what they were. I couldn't figure out how to shift them, and actually took them to a bike shop for repair. The bike shop was run by a very cute lady, who shifted them up and down flawlessly and charged me $5.
A few years later, a guy went in there to put a 10sp wheel on the back of an Ironman. She told him it should not be done, but gave him my number.
I bought Tufo C S33 tubular clinchers, and then taped them to tubular rims. I couldn't figure out why they looked so funny, and rode a century on them. That was some good tape.
I tried 650c wheels with long reach brakes. Rubber-rubber braking gets very hot, very fast, and smells bad. This was my aero stage.
I descended Thunder Ridge and Hwy 43 in the rain. I will not do so again.
At the beginning of any given charity ride, 2 out of 100 riders will not have their QR skewers tight.
Recent years: Pulling a crank arm halfway off before realizing I had not first removed the nut. It turns out Aluminum is pretty soft stuff.
The younger me: Stopping to ask a policeman how to get to the start of a race, forgetting that my straps were fully cinched on my cleated shoes. Real cool.
I.C.
I.C.
Quoted: 1627 Post(s)
Liked 630 Times
Raise stem on MTB. Load MTB on top of car. Drive 20 miles to trail.
Crash bike in first 15 ft of trail ride (because I didn't tighten the stem after I raised it).
Load bike back on top of car. Drive 20 miles back to where I have a 6mm hex wrench to tighten stem
52psi
Quoted: 790 Post(s)
Liked 801 Times
Crammed a wrong-size headset into a nice frame.
