1996 Koga-Miyata SilverAce Project
#101
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Sexy saddle, mounted using a sexy, infinitely adjustable, but hella expensive, Brompton Pentaclip saddle clamp.
And mounted a Koga branded Axa Victory frame lock, mostly because it's all black and the blue insert sort of matches the frame.
#102
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
I started a thread over in the electronics subforum but since I got no replies there and it was about this bike anyway I'll try again here.
So I'm looking at a fender mounted rear dynamo light for this bike.
I have always used the B+M Secula Plus, which is an awesome light and pretty affordable at around 14 for the fender mounted version but I was wondering if anyone had experience with SON's offering?
The SON rear light for mudguard mount looks like a aluminum-housed version of the B+M Line Small (which lacks a fender-mounted version).
- How is the sideways visibility?
- Isn't it too much of a focused point which makes it annoying to other users behind me?
- Would you even bother with it?
#103
I have the bracket/rack mount version. I can throw it on the trainer and test its dispersion later tonight.
#104
Quoted: 7348 Post(s)
Liked 2,462 Times
I have a Spanninga Pixeo which is fender mountable. Side visibility is good.
When man invented the bicycle he reached the peak of his attainments. Elizabeth West, US author
#105
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Thanks, I am aware of the Pixeo and there are lots of bikes around here that come with them. I like the Secula better because it is much less blinding.
Likes For JaccoW:
#106
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Received some new parts for the bike today and it confirmed something I was afraid of for a while;
The VO Porteur bars have a tiny grip area and are not suitable for any kind of regular 22.2mm handlebar grip. These are standard 130mm clamp on grips:
I guess it's time for me to look for other handlebars as I cannot seem to find many, if any clamp-on grips that are shorter than this.
Likes For JaccoW:
#107
Quoted: 981 Post(s)
Liked 1,844 Times
This has been an excellent project, indeed! I missed the initial phase of posting and just caught up by staring at all of the photos and reading a bit of the information. I probably missed you saying so, but are you planning to run matching tires anytime soon? The rest of the bike being so spick and span seems to demand such attention to obvious details... Cheers!
-Gregory
-Gregory
Likes For Kilroy1988:
#108
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
-Gregory
-Gregory
Yes I plan on using matching tyres when I buy the parts to build the front wheel next month. But a dynohub and fancy rims are expensive and sometimes hard to come by so spread out buying things so it fits within my budget.
I expect this to be done in 2-3 months from now. Just in time for summer to start around here and to enjoy longer rides.
This month I ordered the lights so I can prepare some stuff and spend some time wiring everything up just the way I want. Looking forward to figuring out how to run the wire on the inside of the rolled edge of the fenders. Should make for a very clean look.
Likes For JaccoW:
#109
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
#110
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,390 Times
I wound up repurposing the grips on my Spin Gen 2, but in the process also ran out of space on those bars - until I realized that it's possible to cut down a set of locking grips: https://www.instructables.com/id/Sho...cycle-Grips-1/
I didn't do a great job of it, but the leather and adhesive below it wasn't that easy to cut squarely.
-Kurt
#111
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
I was in the same exact situation with the Birdy BD-1 - same bars too.
-Kurt
-Kurt
Seems like I have a few things to do this weekend.
Likes For JaccoW:
#112
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Like I mentioned yesterday I wanted to strip and polish the B+M Cyo T Premium to blend in a bit more with the rest of the bike so I spent about 2 hours sanding all the paint off and giving the heatsink a nice polish.
For more details see the thread over at the Electronics lighting and gadgets subforum but for here I just want to show the end result:
I think it works pretty well and I hope to wire everything up and drill some holes later this weekend. Probably shoot some better pictures as well.
Likes For JaccoW:
#113
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Mounted some lights today!
I gave the rear light the special treatment with a SON coaxial wire running through the rolled fender edges so it's practically invisible. I have a similar cable running through the frame to the headset so I went with one of SON's coaxial connectors. They are a pain to solder on but the end result is really nice and means I can just pop off the fender if I ever want to.
The front light was swapped to the other side to prevent water spray damage but I'm not sure I like how exposed it's going to be in racks this way. I'll think on what I want to do with that next month when I will hopefully be able to build the front dynamo wheel.
Instead of buying a new kickstand I decided to just strip and polish the old one. It was pretty corroded and the black paint was flaking off.
Likes For JaccoW:
#114
Shifting is fun!
Bikes: Yes, please.
Quoted: 2197 Post(s)
Liked 4,599 Times
Wow. That bike has some serious άberholprestige!
#115
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
#116
Liked 4,390 Times
Incidentally, how stiff is the thumb shifter? I've tried to avoid them as my previous experience with indexed thumbies hasn't been that great - too stiff and too much throw for my thumb to reach without moving my palm. Are the Sturmey IGH thumbies easier to use?
-Kurt
Likes For cudak888:
#117
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
#118
Liked 4,390 Times
As far as I can tell these are simply a variant of the Sunrace thumb shifters. The throw on these is somewhere around 150 degrees going from gear 5 to gear 1. I can make some pictures if you like?
It's no reflection upon your beautiful build, but it's just my personal preference when it comes to shifters. I don't understand why IGH thubmies don't have a larger barrel for more cable pull for each throw.
-Kurt
#119
Liked 2,462 Times
Yes, I've found thumbies aren't really thumbies. I sometimes have to grasp the whole shifter with my hand as if it's a knob. Not fantastic but not awful. Maybe they should be called palmies.
Likes For noglider:
#120
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Yeah at best thumbies are more of a "thumb down, index finger up" tool. It's why you often see people mounting them point outwards like this.
I have one on a 3-speed Sturmey Archer hub as well and it works pretty well like this or mounted on the stem.
cudak888 I followed your advice and cut down the grips as the instructions described. Works really well on these rubber grips. I hope to be able to do the other one later this week.
Likes For JaccoW:
#121
Liked 4,390 Times
-Kurt
#122
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Likes For JaccoW:
#123
Liked 4,390 Times
Cut that ridiculous binder bolt off, run a new cable, slide the long adjuster barrel onto the cable, then solder the smallest brass sleeve you can possibly fit onto the cable (very thin cable end caps with the tips cut off sometimes work too). It takes a bit of effort to get the length just right, but it'll be a lot nicer in both appearance and function.
-Kurt
Likes For cudak888:
#124
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
We're moving into the final phases of this build. I noticed the XL-FDD dynohub was a good €20 cheaper than it has been these past few months so I just ordered most parts to build the front wheel. The rim, a H + SON Archetype has been ordered but usually that one takes a week or two to come in. I will be measuring the combination myself before ordering the spokes and building the wheel.
Likes For JaccoW:
#125
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
