If you have the option would you go 1/8 or 3/32?
Received a White Industries 17t ENO freewheel that is 'designed for 3/32' but works with 1/8 chain. I don't have the chainring or chain yet. If you guys had the option to go with 3/32 or 1/8 drive train components which would you go and why?
1/8". I have both on two different trikes, single speed and multi speed. The 1/8" lasts twice as long before stretching requiring replacement. 3/8" is thinner for engaging gears on a cassette and/or chain ring. The thinner = faster wear.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12757 Post(s)
Liked 7,672 Times
Id go 1/8 chain. Then you can get 1/8 chainring or a skinny one.
Quoted: 586 Post(s)
Liked 612 Times
One reason not to go with 1/8" chain is if your chain line isn't dialed in pretty close. 3/32" chain has more lateral flex and is more forgiving. I'm not suggesting you not try to get a proper chain line, but if you've done the best you know how and it is still off, then a little forgiveness is good.
Clark W. Griswold
Quoted: 4346 Post(s)
Liked 3,982 Times
If I had 3/32 I would match up to that. Now if there were particular drivetrain bits and bobs I wanted that only came in 1/8 then I guess that would be the jam. However I can find some decent quality 3/32 stuff so why not. I like really quiet set ups for single speed or fixed gear (though I like a freewheel with loads of engagement like my WI trials version)
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
If I already had the 3/32 WI freewheel, then 3/32. Quieter and lighter. If I was starting from scratch with nothing, 3/32.
I question the claim that 3/32 stretches faster, and especially that "1/8 lasts twice as long." Not in my experience they don't.
Chain width has nothing to do with its strength or wear rate or how much noise it makes. You can buy single speed-specific chains in both widths. I would choose the chainring first, then use whatever chain is necessary to match it.
If perfect chain tension and smoothness is important to you, there are a few brands of very high quality track chainrings that come in the traditional 1/8” width. They are expensive. Otherwise 3/32 chainrings are more commonly available with many more BCD and tooth-count options.
Quoted: 4802 Post(s)
Liked 3,922 Times
I ride only fix gear, never single speed. I rode on the road and in hills. I only use 1/8". I started on 3/32" and rode 2 decades on it but I will never go back. Reason? It is harder tho throw an 1/8" chain off an 1/6" cog, especially a cog that has been cut to very square teeth. (Eur-Asian cogs are my 1st choice.) I also run chains designed to be sturdy and not throw off. (Izumi. Not quiet or especially smooth but they stay on.)
The 1/8" drivetrains are more forgiving of too much slack, especially on poor roads and/or high RPMs. I really do not like throwing chains, especially at speed. I have been known to descend in gears like 42-17 at speeds approaching 50 (I've gained a little sanity and lost a lot of spin so I do not, cannot any more. But crashing hurts far more now so I want that same conservative drive train.
Chain slack is often a juggling act if the crankset is not of track quality. I refuse to ride with a chain that goes tight, but on many road cranksets, that means the slackest portion of the chain cycle may be looser than is comfortable for piece of mind, There I really like having that heavy, solid, stiff track quality 1/8" chain running on square cut quality cogs. (The black Izumis cost $20 and go a long ways, I call that a deal. I willingly pay twice that for the Eur-Asian cogs. Funny - I believe made in USA despite the name.)
For a single speed, this matters far less. But the OP might want to consider 1/8" to have the more rugged system should he ever decide to dabble in fix gear.
Ben
Ben
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
If you use 1/8" chain, you can mix and match 1/8" and 3/32" chainrings and sprockets. If you use 3/32" chain, you can only use 3/32" chainrings and sprockets.
