Group enabling: AD-SLE Project.
#51
StillNewbieButInGrey
Bikes: Austro Daimler SLE
Quoted: 80 Post(s)
Liked 140 Times
Thank you. I figured these parts would have been an upgrade to the originals and possibly something someone would have actually done to the bike in the 80s. I just remember a large period of time where EVERYTHING was made in Japan and while i was too young to be involved in international trade discussion, I do remember the guy from the movie "gremlins" being particularlly upset about it.
#52
Bad example
Quoted: 850 Post(s)
Liked 271 Times
And so the rabbit hole begins!
Starting down the road in toe clips is largely dependent on getting the hang of it from a stop. the toe clip buckle is on the outside of the pedal allowing you to tighten and loosen at the stops. Some folks like to pull down to tighten and flip the buckle to loosen. I tended to do the reverse as a youth...so I threaded it in the opposite direction!
Likes For Aubergine:
#53
Quoted: 80 Post(s)
Liked 140 Times
I dont know if i mentioned this, so i probably sound like a doofus to some of you, but....this is my first drop bar or road bike, my first vintage bike, and my first bike build so I am stuffing a lot of learning in at once.
Where is the best place to get one of those funky cycling caps? 🤣🤣🤣...no, seriously.
#54
Quoted: 80 Post(s)
Liked 140 Times
I happen to have shoes that match my bike well but they are skate shoes and have alot of padding and just dont feel good in the clips.
Likes For Mr. 66:
#57
Quoted: 80 Post(s)
Liked 140 Times
Took the junk test saddle off and replaced it with a slightly less junky one that had an even lower profile. Was able to easily adjust it from the side. Still not nearly as nice as the period correct touring saddle that dave sent but it is a major improvement on the one that I installed and I can actually adjust it. When I feel like getting tortured ill try the vintage again.
Likes For Strawbunyan:
#58
Quoted: 1149 Post(s)
Liked 1,773 Times
The shoes are new, of an old Asics pattern. Lifestyle shoe, now under the Onitshuka brand. The black pair I have are slightly lower profile.
I used to use Avocet but those have been out of production many years.
Likes For Mr. 66:
#59
Edumacator
Quoted: 2490 Post(s)
Liked 3,223 Times
Come to think of it, not sure where my Lake cleats went either...
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
#60
Quoted: 7359 Post(s)
Liked 2,502 Times
You've done really nice work on this bike.
There are tricks to adjusting this type of brake caliper. Make sure there is a bit of oil between the return spring and the caliper arms. A bit of friction will make it work asymmetrically. But the most common cause is unequal spring force. Back in the day, I had a technique to equalize it, and I have not found a video that demonstrates it. I've been meaning to make one. You can't loosen the attachment nut, reposition the caliper, and re-tighten the nut. The unequal spring forces will almost surely take over.
My technique is to determine which side is a bit too strong. Place the back end of an adjustable wrench at the top of the spring near the center bolt. Bang on the wrench with a hammer.
Likes For noglider:
#61
Best place? Not sure. Enough research might turn up some small companies that are worth doing business with. Failing that, you could probably find any number of sites that have Puch replica hats. I've found fun designs on eBay and Etsy.
Likes For The_Joe:
#62
Edumacator
Liked 3,223 Times
Probably easier than trying to find touch up paints for AD. They obviously had competitions in house to come up with the least reproducible paints.
#63
Quoted: 568 Post(s)
Liked 1,059 Times
Walz caps makes cycling caps but they aren’t branded Bianchi, Colnago, etc.
https://www.walzcaps.com/
I found a Legnano cap on eBay. Made in Italy and I believe the same company makes many other brands. eBay search should yield results.
Likes For RustyJames:
#64
Quoted: 1649 Post(s)
Liked 845 Times
The Brooks Imperial saddle works perfectly on these Campy Record seatpost rail clamps. It's almost like they were specifically thinking of the Imprrial when they designed the seatpost.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
#65
Edumacator
Liked 3,223 Times
I have one of those in the stash. Are they comfortable?
#66
Quoted: 80 Post(s)
Liked 140 Times
thank you.
Edit: I looked it up....Brooks is REALLY proud of them it seems.
#67
Bad example
Quoted: 850 Post(s)
Liked 271 Times
#68
Quoted: 80 Post(s)
Liked 140 Times
Brought the bike to work with me today to get some test rides in on nicer roads. Stood up to get up a hill and suddenly the bike just stopped moving. I checked to see if maybe the brakes were sticking or rubbing. Upon closer inspection i found the back wheel to be completly locked up. It had twisted in its the drop outs it seems and was jammed against the frame of the bike. I loosened the QR and got it straightened enough to start moving again enough to roll it back to my car and it seems no matter what i do here it doesnt want to stay centered in the triangle. And when i clamp it down it squeezes the triangle in quite a bit. I adjusted ot straight with those little screws in the drops and stuck it back in the car. I think ultimatly ibmay not have had it tight enough (i have a bad habit of over tightening things so I am trying to avoid that)and it pulled it hard when i put the power down, unsure. Will do more testing and give results.
#69
Edumacator
Liked 3,223 Times
As far as the rear drops pinching a bit, I spread them to 128 and then realigned them....I believe, so that both 126 and 130 spaced hubs could be used.
#70
Quoted: 80 Post(s)
Liked 140 Times
I believe tightening the QR did the trick. I rode the same hills harder than the last time with no issue.
next question: did I install the FD too high?
I am going to swap the chain this weekend and figured i would adjust the FD as well if i did it wrong.
#71
Bikes: Aluminum and Steel
Quoted: 115 Post(s)
Liked 399 Times
I usually set my FD 2-4ish mm above the teeth of the outer chain ring. I use an appropriate size allen wrench (3mm) to check the gap. My memory skills could be lacking, but I believe that to be the measurement I got from watching a Park Tool video. Very helpful videos by the way. I was dumbfounded a time or two when I was learnin’ myself about derailleurs. They helped straighten me out.
“Ride like the wind boy! Ride like the wind…”
-The Voice inside my head, circa 1982
Likes For IdahoBrett:
#72
Edumacator
Liked 3,223 Times
#73
Bikes: A bunch of old bikes.
Quoted: 289 Post(s)
Liked 889 Times
One thing to watch out for is the slightly oval shape of your Biopace chainring. You have to set the FD clearance with the chainring at it's highest point.
Likes For daverup:
#74
Quoted: 80 Post(s)
Liked 140 Times
when i got them i had to google it to find out that oblong CRs are a thing, ill make sure to remember that when adjusting, thank you for reminding me cause i sure would have forgotten.
#75
Quoted: 80 Post(s)
Liked 140 Times
