RideNow inner tube
RideNow inner tube
Wonder anyone have experiences using the aliexpress RideNow inner tubes on foldies 20"/16"
How's the ride compare to regular inner tubes?
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 272 Post(s)
Liked 242 Times
They seem to be similar to Tubolito and Pirelli tube. I have tried Tubolito and I cannot say I like them.
The tubes are super light and reduce rolling resistance, with Kojak or even a "fast rolling" XC tyre, they feel faster and smoother which is good BUT, the material used to make them is not easy to fix in the event of a puncture; you need special patches and glue and you have wait ~30 minutes to get it to cure.
I rode with some until 3 weeks ago and after 3 punctures within 30miles, I had enough and when tubeless. I fixed them and I have them in case the tubeless sealant fails.
So unless you race and cannot use tubeless setup, I would not bother with these... That's said I will order a set of tubolito in 20" to use in hill climb races only (clean course that last a few miles only).
Thx for the your feedback.
Could you please share about your tubeless setup? what folding bike are you having the tubeless wheels on? thx.
Quoted: 272 Post(s)
Liked 242 Times
That said, I have a set of spare valves (Muc off sales, 70%off), gorilla duct tape, sealant and booster, I might try to do a "ghetto" set up. basically, set no tubeless rim and folding tyres (does not work with rigid bead tyre) tubeless.
As a precaution, I will use a thick sealant, muc off rather than Stan Race which I use on the gravel bikes wheelsets.
Likes For Fentuz:
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
Given the increased need for tire inflation with these inner tubes, I will pass.
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
I'm not sure how smaller rims impact rim brake heat compared to 700c. Anyone know?
Schwinnasaur
Are you asking about heat buildup? I don't have any direct experience (I use Ridenows but with alloy rim brakes), but from what I've read you should probably avoid them if you're doing long, steep descents. Also, you might want to ask in the General Cycling Discussion forum, since you'll probably find more respondents there.
