Any adapters to add fork cargo cages?
Old 04-02-23, 11:57 PM
badger_biker
badger_biker's Avatar
Bikes: 10 vintage touring machines
Quoted: 112 Post(s)
Liked 126 Times in 66 Posts
I have a Diamondback Haanjo that I want to tour on but don’t want a front rack and panniers. It has carbon forks with one mid fork mount. I’d like to find adapters with 3 mounts for bike packing cargo cages that I can bolt to my existing mount and probably zip tie the top and bottom. Any suggestions for such a product?
Nothing compares to the simple pleasure of a bike ride - JFK
badger_biker is offline
Old 04-03-23, 05:33 AM
gauvins
Bikes: Custom built LHT & Troll
Quoted: 846 Post(s)
Liked 149 Times in 106 Posts
You could use an adapter such as this , or go with Ortlieb fork packs.
gauvins is offline
Old 04-03-23, 07:23 AM
timdow
Miles to Go
timdow's Avatar
Bikes: 2022 Juiced Crosscurrent X, 2022 Fuji Touring, 1998 Schwinn Moab (drop bar conversion), 2010 LHT (Stolen)
Quoted: 151 Post(s)
Liked 145 Times in 95 Posts
Proceed with caution. Per Ortlieb's website for the fork packs: "Attention: Not suitable for mounting to carbon forks without „braze-on“ eyelets, tapered fork blades or frame tubes."
Any kind of hose clamp or band around carbon forks is "not recommended."
timdow is offline
Old 04-03-23, 08:33 AM
badger_biker
Quoted: 112 Post(s)
The Ortlieb setup is pretty limited for non suspension forks since nearly all have some type of taper.
I understand the banding concerns with carbon forks. That is why I would like to find an adapter to utilize my mid fork mount to take the weight of any attachment. Any bands used top and bottom wouldn’t have to be too tight because they would only be there to stabilize and keep the adapter from rotating forward or back. I’m not planning for much weight on them. Just a small dry bag or sleeping pad.
Old 04-03-23, 09:59 AM
gauvins
Quoted: 846 Post(s)
Looks more like a legal disclaimer than a real issue (for tapered steel forks). I've installed them on my LHT (single mount point + one adapter) and they appear to be rock solid.
gauvins is offline
Old 04-03-23, 07:06 PM
balto charlie
balto charlie's Avatar
Quoted: 170 Post(s)
Liked 156 Times in 99 Posts
I use my front forks for water bottle cages and have a large frame bag for most of my gear. My bike is steel, has a single mount like yours. Along with the single mount I use electrical fusing tape. I read on bikepacking.com about using tape, which can be easily removed. BP did not have a single mount used the regular electrical tape. The fusing tape I used is different BUT bomber. It actually fuses with itself and bonds tightly. The cages remain in place after years of gravel grinding. The tape comes off clean because it does use glue.
Here's bikepacking link where I got some of the information.
https://bikepacking.com/gear/bikepacking-hacks/
here's the fusing tape:
https://tinyurl.com/59fyatu6
balto charlie is offline
Old 04-04-23, 05:26 AM
timdow
Miles to Go
timdow's Avatar
Quoted: 151 Post(s)
I have also used bands on my LHT for the second mount. The one mounting point in the threaded hole keeps it in-place without issue.
Like the OP, I also had a bike with one hold and carbon forks and did not try it. Maybe wrapping the forks with something to spread the load would do it.
timdow is offline
Old 04-04-23, 03:56 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6220 Post(s)
Liked 4,221 Times in 2,367 Posts
I recently discovered Fidlock adapters. They are mostly for water bottles but they make a base that uses rubber straps. I used a Fidlock Tex connector which screws into a base through the fabric of the leg bag. A little twist and the bag comes off. By itself, the Tex connector in the bag is a bit floppy so I used a strap to hold it more tightly to the leg. I haven’t tried it in really rough conditions yet but it held quite well in the tests I have made. I can use this on my suspension fork and it doesn’t seem to slip. For a tapered leg, you could tighten the straps as much as needed without risking damage of the fork.
An alternative would be the Topeak Versacage. I’ve tired those too. They use a worm gear on a plastic clamp that would also be better for a tapered and/or carbon fork. The worm gear tends to wear out quickly if you want to install and remove it a few times. Slipping on a tapered fork leg would be something of a problem. It tended to slip on my suspension fork legs.
Cost of the Fidlocks is a bit expensive. The Uni base costs about $25 per each. The Tex connector doesn’t seem to be made anymore but you can find it on Etsy or Ebay for $12 to $15 each. The Versacage, on the other hand round about $35 each so the cost is a bit of a wash.
Stuart Black
cyccommute is offline
