Front Wheel Kickstand
Quoted: 5 Post(s)
I would like to put a front kickstand on my 26" touring bike .. The only one I have found is the Tubus & it looks like it will ONLY fit their certain racks .. I have a *NITTO* rivendell big front rack 34F (silver) which I prefer to keep .. has anyone used a Tubus front kickstand on any other racks .. I'm thinking some modification might be necessary .. but I can not see why it would NOT work ... what am I missing .. thanks Glenn
good luck with some experienced opinions. I would say that I think I have ever only seen one of these in real life once, you just tend not to see them, not around here anyway.
I suspect that you are going to have to figure out on your own using common sense if you can adapt it to your rack successfully. Might be tricky though without having one in hand to really see how you would finangle a workaround.
good luck
good luck
