Help identifying this (late-80s?) Italian (?) frame
Quoted: 5 Post(s)
I could use some help identifying this (late 80s?) frame. The seller had apparently been given this bike by a taller friend (who had clearly evolved this bike over the years), so he [the seller] couldn't tell me much about it. I plan to sand it down, deal with rust issues (hopefully nothing is rusted through) and repaint it, but was curious if anyone had any idea what the heck it is.
Cross-posting from the steel-is-real FB group, hoping someone here might know.
Notable things:
- Someone previously had put on logos (or paint) that read "Conlago" (yes, not "Colnago"); outlines can be seen under the paint. Also has some Colnago-looking clover logos. So that makes me think it is probably not an actual Colnago. But no idea.
- The internal routing through down tube for the front & rear derailleurs (and chain stay for rear mech) seems very distinctive. Also it seems like there was some other piece here before (probably down tube shifters?). Have been googling for frames that did this, but haven't been able to find much.
- It does have Campagnolo ("Brev Campagnolo") dropouts.
- It has full Campagnolo, though the groupset (Chorus) is 8sp and the wheels are 7sp tubies, so I'm trying to get that fixed (replace wheels) so it shifts properly.
- Italian threaded BB shell
- Seatpost is 27.2
- Rear spacing is 130mm.
- BB has markings, but due to some surface corrosion hard to read other than "60" -- seat tube measures 60cm center-to-center so assume that's the size.
Anything else that might help narrow this down? Thanks in advance!
Notable things:
- Seatpost is 27.2
Quoted: 800 Post(s)
Liked 754 Times
I'm not an expert, or even an amateur, but the downtube shift mount would be early 80s if it's original. Which it probably is, I assume the PO had a frame builder alter the frame to have cable stops and internal routing in the 90s or 2000s to make this frame compatible with brifters. Repainted at that time, too.
Quoted: 3814 Post(s)
Liked 3,345 Times
1984 was the extreme tail end for top mount shifters; launch was 1982
note that drive side dropout exhibits the small hole for the portacatena feature, another dating aid
somewhat concerned by the lumpy appearance in this image
appreciate that it is "probably" just paint
you will be able to closely examine the surface when you have the paint removed...
Quoted: 5 Post(s)
Quoted: 5 Post(s)
Quoted: 5 Post(s)
This is quite an archeology here.
Edumacator
Quoted: 2440 Post(s)
Liked 3,133 Times
I think it is pretty much as built, just someone wanted a Colnago.
Are those Bottecchia or Olmo bottom bracket cut outs?
Quoted: 800 Post(s)
Liked 754 Times
jdawginsc
I'm having a hard time visualizing the holes and cable stops being compatible with top mount shifters...I've never seen or heard of those little brackets or guides being necessary. To my eyes they'd just get in the way.
However, I just found this thread: https://www.bikeforums.net/classic-v...-shifters.html
It has a picture of strikingly similar internal cable routing. Unfortunately it's impossible to see if the cable guides are there as well:
Quoted: 1303 Post(s)
Liked 1,912 Times
That top mount shifter braze on screams Asian build at me, with some modifications added later. I would like to see the inside of the BB and follow the cable routing as it is configured. Smiles, MH
Liked 3,345 Times
few Asian machines constructed with Campag ends and Cinelli investment cast crowns...
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Usual questions:
1) BB threading
2) seat post diameter
3) internal markings on frame tubes
1) BB threading
Quoted: 1079 Post(s)
Liked 1,899 Times
Is the rear brake cable internal too?
Strange that with all the internal cabling there isn't any markings of the marque. Casati comes to mind, but I'd expect to see their logo on the seat stay caps.
As mentioned, the Portacatena holes suggest a 1978-1982 timeframe. Rear triangle must have been cold set if it's 130mm.
Looks like there may be more numbers following on from the 60 on the BB shell. Not that it's probably going to help us much.
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
Seems similar or identical to what the OP has.
The RD exit from the stay is different on mine then what’s shown here, and the lack of branding on the frame indicates its not a Vicini, but may have come from the same builder. My understanding is that my frame came from a contract builder for Vicini.
HTH
Edumacator
Liked 3,133 Times
I think those loops were just re-purposed as cable stops; my guess is they are to keep the shifters in a parallel position when up shifting to the small-small rings/cogs.
As far as a contract build, that seems pretty likely. Top tube cable routing likely done later though maybe not.
Lug cutouts would be normal for a contract builder to use, I think? The lack of pantograph info on the fork crown makes it difficult to say what it was badged as.
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times
Brent
"I have a tendency to meander sometimes." B.G.
Quoted: 5 Post(s)
Quoted: 5 Post(s)
Here’s the top-mounted, internally routed shifters on my Vicini:
HTH
HTH
Interesting idea about contract builder. Just so I understand, Vicini contracted different builders (in Italy?) to build their frames and yours (and possibly mine) might have been "sold direct" from one of those builders?
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
Wow, that does look identical. Your frame is beautiful; I like the Campag 8sp, but maybe I should see if.i could source some top mount shifters 🤔
At this point, the only commonality I see between our bikes is that DT shifter fitting. I don’t know if that was a custom piece indicating from the same shop, or something off-the-shelf which would mean it they (probably) didn’t. I don’t really see anything else that they have in common, fwiw.
One detail you can check is that mine has what appears to be a builder’s stamp (circled MB) on the BB - I don’t see that on yours but maybe it’s there? I have no idea what that stamp means, though.
Quoted: 5 Post(s)
Bikes: None in ridable condition
Quoted: 148 Post(s)
Liked 644 Times
Notable things:
- Seatpost is 27.2
Notable things:
- Seatpost is 27.2
Could you post a picture of the top of the lower head lug (that shows the cutout) and also of the internal cable routing entry/exit on the top tube/
Wondering if they look like this:
Likes For MauriceMoss:
Quoted: 148 Post(s)
Liked 644 Times
I believe that Vicini sold my bike as their own, rather than direct from a contract builder. Mine allegedly came from a shop in Arizona (Domenic’s?) that was a US distributor for Vicini.
[img]https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/640x477/image_af20496dc8c2814269110d5ceb86531b16ae2c83.jpeg
Re: the MB stamp on the bottom bracket shell - I contacted Billato a while back and they confirmed that this was their factory punch for a while. You can also see it on other Billato built frame of the period (like the cromovelato Detto Pietro ones that get posted on BF from time to time).
Quoted: 5 Post(s)
Edit here are the pics (I was cleaning up the brake entry/exit to make sure the corrosion was just surface-deep).
Likes For jethin:
Quoted: 148 Post(s)
Liked 644 Times
Your frame was made by Olmo. They used to do the serial number format both with the size leading and trailing the frame number during this period, so if you look into Olmos, you'll see it stamped either way. Also, the internal cable routing is original. Going by the serial number (9846?) it might be a 1983 (or possibly even 1982) - the Olmo registry has a 9862 as a 1983.
If the frame is in the US (or came from the US), it's highly likely that it was originally badged Nishiki Cervino. Another company that sold Olmo contract made frames that looked very similar to this was Euro-Asia Imports, under their Eurospeciale brand, but I've never seen one of those with internal cable routing.
Here are some pics of Nishiki Cervinos:
60 9835:
Shifter mount w/o shifters (best view I could find):
This one is a 9844:
