Max tire size on road rim
Quoted: 8 Post(s)
I am planning to turn my old faithful do everything touring bike into a tracklocross. I am pretty confident I'll be able to fit 43mm tires into the frame but I'm not sure about the rims I've got.
The wheels I'll be using are the stock wheels off my cinelli Tipo pista so pretty standard 700c fixed/single speed deep aluminium rims. They obviously run 25-28mm normally (think they came with 28) and I've fitted 32mm to similar rims in th past.
So my question is can I achieve the big tires I want with my current rims or am I gonna have to buy different wheels?
TIA
TIA
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
TIA
TIA
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1333 Post(s)
Liked 764 Times
See the following chart >>> https://www.wtb.com/pages/tire-rim-fit-chart
You should match the tire width to the rim width. So, for a 43mm wide tire, you should use a rim with an inner width between 19mm and 25mm for optimal performance, although you can use a rim with as little as a 17mm inner width. Anything less, and the tire will get a severe lightbulb shape, and roll sideways when cornering.
Likes For TejanoTrackie:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Besides the rolling issue mentioned by @TejanoTrackie, running wide tires on narrow rims increases hoop stress on the rim sidewalls. The hoop stress increases with tire pressure and can be reduced by running the tires at lower pressure than you ordinarily would use.
Likes For JohnDThompson:
