Sheared this Regina freewheel. Now what do I do?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1087 Post(s)
Liked 1,825 Times
1971 large flange, Hub, Regina Oro free wheel that takes two prong removed tool
Yes, I did the trick where you use your quick release to hold the remover tool in proper place.
I shared that stuff right off.
I have it soaking in PB blaster overnight. Thinking I need to drill a couple holes, sacrificing the free wheel, thread, some bolts in there and torque on those unless somebody has a better idea.
"Leave the gun. Take the Colnagos."
Bikes: 3Rensho SuperRecord Export, Bridgestones MB1 RB1 XO2, Colnago Super, Medici GranTurismo, Schwinn Paramount, Olmo Competition, Raleigh Portage, Miyata 1000, Stumpjumper, Lotus Competition, Nishiki Maxima, Panasonic DX6000, Zeus Criterium
Quoted: 30 Post(s)
Liked 82 Times
Likes For brooklyn_bike:
Quoted: 1304 Post(s)
Liked 1,913 Times
The pin spanner might have a bit of a problem with the mangled body of the freewheel. If you can get Dremel with a cutter bit in the space to remove some of the burrs, and help with the removal of the lock ring. Good luck! Smiles, MH
Likes For Mad Honk:
Likes For bboy314:
Hit it with an upside can of spray duster followed by a drop of oil. The cone should come apart with a drift and hammer to the pin holes followed by the RJ pipe wrench method.
Likes For Nwvlvtnr:
Quoted: 175 Post(s)
Liked 452 Times
Easy, fellow.
1) In place of the skewer securing the tool, use a long panhead screw, and for the obverse a washer and nut. Tighten securely.
2) Air or electric impact wrench / socket to the freewheel tool.
They come off like butter. Threads on the hub are forgiving so make sure you run the impact lefty loosey.
PS. If you don't have access to a pneumatic or electric impact wrench, just get a cheapie from Harbor Fright or Amozone. If you don't want to spend even for this, take the entire assembly to car dealer / repair shop to this in under a minute, or use for free the loaner tool from one of the big chain auto parts stores.
Quoted: 3464 Post(s)
Liked 2,831 Times
Looks like a Suntour early two prong remover to me. The teeth are too deep for a stubborn Regina.
there are a few ways to attack the problem, most murder the body, you have to decide soon if you want to save the cogs before taking measures.
Likes For repechage:
Quoted: 175 Post(s)
Liked 452 Times
Even if the notches of FW body are boogered, use a mini rotary tool and cut new ones. Admit its tedious but the task goes quickly. You're not on shop time so enjoy the challenge. Good luck-
Likes For chain_whipped:
Quoted: 878 Post(s)
Liked 2,296 Times
I have a Regina removal tool that is pretty cool and works very well. The tool is threaded to accept the skewer which firmly secures the tool while loosening. I place the tool in a bench vise and turn the wheel, bingo! I learned the vise method from my local bike shop years ago . Mark hated to see two prong SunTour or Regina FW’s but never butchered them no matter how stubborn they were , he has finesse and patience. After years of having my wife or a friend hold the wheel while I struggled with a big wrench , I saw Mark loosen one with the vise method and now I don’t fear the FW!
I've had to use the "disassemble and use a pipe wrench" method once. Putting a rag between the freewheel ratchet and the pipe wrench minimized damages and I was able to reassemble a working freewheel again afterwards, though yours is already pretty torn up so there may not be any point.
Likes For daka:
Liked 1,825 Times
I have a spare body, and a box of various gears. I'm not opposed to decrying the freewheel.
After lunch, I'll see what happens.
Sigh.
Sigh.
Cantilever believer
Quoted: 538 Post(s)
Liked 1,846 Times
Regina Oh-no. Ouch.
Likes For RCMoeur:
I think the lock ring is a left-hand thread.
Likes For daka:
Liked 1,825 Times
After trying several methods. Including using fresh tips on a VAR tool and not succeeding.
it left me no choice.
Liked 1,825 Times
The freewheel is free. I was able to save 2 cogs.
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
Beer Time !
Likes For Manny66:
small ring
Quoted: 438 Post(s)
Liked 925 Times
real men don't have shields on their grinders
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Quoted: 1830 Post(s)
Liked 3,383 Times
It should be noted that it requires a somewhat unique thread on the skewer. I think this old Schwinn skewer might be French in origin?? A Campy skewer doesn't work.
The knurled portion that the skewer threads into is loosely swaged into the remover portion, and would be a bit of work to remove from the remover portion.
Steve in Peoria
Quoted: 878 Post(s)
Liked 2,296 Times
That sounds like the tool that I've got...
Steve in Peoria
Steve in Peoria
I’m not sure you can see the stamp on the knurled end , it is stamped BC
Likes For Kabuki12:
Quoted: 878 Post(s)
Liked 2,296 Times
Liked 3,383 Times
Using a thread pitch gauge, it looks like the Schwinn skewer that fits this tool has 0.9 thread pitch (threads per millimeter).
Checking a Campy skewer, it appears to use threads with a pitch of 0.8.
Did Campy just decide to use a proprietary thread, or is this a French thing? (assuming that the Schwinn skewers were made by Normandy or another of their French suppliers)
Steve in Peoria
(to whom it may concern: I'm not using this Regina tool anymore... please contact me if there is any interest)
Quoted: 878 Post(s)
Liked 2,296 Times
Steve, It’s funny you say that, all my bikes , except for one , have Campagnolo skewers . I will have to see if the tool I have will thread on to the other bike with Superbe / Sunshine skewer. Hmmm. This is my favorite FW tool though. I only have a couple of Regina FW’s , most are SunTour and take a different tool. Glad to see Rob got the stuck FW off the hub , but man , he had to work for it!
Quoted: 2364 Post(s)
Liked 1,751 Times
Neat idea. Leaves me wondering why no one ever came up with one for a two- or four-notch Suntour.
Likes For madpogue:
Liked 3,383 Times
As for why the idea wasn't more widely used... I don't see the benefit to it. The swaged-on threaded portion just replaces the QR nut that you probably already have in your hand when you pulled the QR out of the hub.
Steve in Peoria
feros ferio
Quoted: 1393 Post(s)
Liked 1,331 Times
What works well for me is to use a QR nut with a slightly conical outer end and to flip it around when using it with a SunTour remover. This restricts any tendency of the remover to squirm from side to side.
Likes For John E:
