Two Bolt Seatposts
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
Two Bolt Seatposts
Hiya Folks,
I've been tweaking the fitting of my 1961 Holdsworth Cyclone and while I've got the saddle fairly good it's always tricky to adjust the angle.
The seat tube is slightly oval so I'm using an 80's SR LaPrade 27.0mm which works fine but apparently the two bolt mechanism makes setting
the angle much easier (if you've got the right spanner).
Reading on here the original two bolt mechanism is the Campagnolo 1044, but there's also the Sugino Mighty.
There's also some Nitto seatposts but they seem to be only 27.2.
So can anybody suggest an adjustable seatpost (27mm) other than the above ?
Adjustable as in better than SR LaPrade, and bonus points for looking good.
Campy 1044: https://www.velobase.com/ViewCompone...7-29856a826f2c
Sugino Mighty: https://www.velobase.com/ViewCompone...bee02&Enum=105
If I was doing it again I would get the frameworks to put the seat tube back to 27.2, but hindsight is always perfect
Quoted: 4409 Post(s)
Liked 1,566 Times
American Classic seat posts are vintage, 2 bolt and very nice.
Likes For Kontact:
Quoted: 3814 Post(s)
Liked 3,345 Times
other replicas of the Campag include the ANPI and Zeus Criterium from Spain
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 164 Post(s)
Liked 102 Times
Jean-Paul Routens (JPR) made a 2-bolt seatpost that adjusts with allen wrenches from the bottom side. You can have your cake and eat it too: it's much easier to adjust than the Campagnolo-style posts, while being micro-adjustable and holding the saddle firmly in place. The JPR 3000 is from the mid-1970's I believe, and they also made a similar 3001 fluted model. I have one on my '75 Moto Grand Jubile and it is my favorite seatpost.
If you want something more period-correct, Ideale made an all-steel micro-adjusting clamp that mounts to a standard straight-tube seatpost. I have one on my ´62 Jack Taylor and it has worked very well: micro-adjustable, easy to adjust and no slippage.
Wheelman
Quoted: 298 Post(s)
Liked 676 Times
That JPR looks quite interesting, there are even 5 x 27.0mm ones on Ebay.
They're also relatively well priced.
JPR 3001 fluted: https://velobase.com/ViewComponent.a...m=105&AbsPos=3
On the other hand Hilary Stone has
Is there any difference between Campy 1044 and Sugino Mighty, other than Sugino is fluted and a lot lighter ?
£36 Campy 2 bolt record 27.0
£45 Sugino Mighty fluted 27.0
.£45 Sugino Mighty fluted 27.0
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
SR Royal, which came in several variations according to Velobase.
A quick internet search indicates that these came in 27.0, as an ornately-fluted one is listed for sale here (link).
Likes For CO_Hoya:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,605 Times
+1 on these. Cheaper versions are labelled 'CUSTOM". I find them regularly at jumble sales for little money and usually buy them. It's nice to have a stash in various sizes.
These two, a nicely satin-finished ROYAL and a CUSTOM, I picked up recently for a handful of euros:
Likes For non-fixie:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Hiya Folks,
I've been tweaking the fitting of my 1961 Holdsworth Cyclone and while I've got the saddle fairly good it's always tricky to adjust the angle. The seat tube is slightly oval so I'm using an 80's SR LaPrade 27.0mm which works fine but apparently the two bolt mechanism makes setting the angle much easier (if you've got the right spanner).
Adjusting the Campagnolo style two-bolt posts is easier if you have the right tool; a 10mm flex-head ratchet:
Likes For JohnDThompson:
Edumacator
Quoted: 2440 Post(s)
Liked 3,133 Times
I gotta get one of those...
Quoted: 175 Post(s)
Liked 452 Times
For a 60's era, I wouldn't rule out a steel Simplex. Also called Tige de Selle meaning saddle rod. The head clamp is different but allows a decent tilt range. Open end spanner grabs those nuts ;\
Slight variations available through the years and doubt the period correct police can denote them all. Diameter in 27.2 exist.
Likes For chain_whipped:
If you have a bike co-op nearby they almost certainly have an adjustable reamer. At my shop, when someone comes in with a 27.0 frame, 100% of the time I suggest we ream it to 27.2. It takes 15 minutes and opens up a much larger post selection.
Likes For fliplap:
Wheelman
Quoted: 298 Post(s)
Liked 676 Times
So far it's looking to me like
Best mechanism:
Most authentic
Best Alternative
Given I've already got a fluted SR LaPrade I should probably try the Sugino Mighty and see if the flex head ratchet works with a Selle Italia Sprint.
Going to be trying a Wrights Swallow in the summer so I probably need it for that.
Best mechanism:
JPR (fluted) - but fairly rare
5mm hex from below
.5mm hex from below
Most authentic
Campy 1044
needs the flex head ratchet
.needs the flex head ratchet
Best Alternative
Sugino Mighty fluted - 240g
Or any of the 1044 clones (but heavier)
.Or any of the 1044 clones (but heavier)
Quoted: 876 Post(s)
Liked 2,293 Times
Almost all of my bikes have the Campy 2 bolt posts . I have one bike with a fluted Zeus seat post and they are nearly identical. I find that adjusting the seat angle is a bit time consuming but worth it to get the comfort. I did not have the Campagnolo wrench so I took a 10mm box end (12 point) wrench and bent it. It works well even with the UniCanitor saddles which have even less room than a Brooks Pro!
Liked 3,345 Times
another Campag replica which came on topline model Japanese cycles of the boom era is the YFC/Fujita Hupel Rider
Likes For juvela:
Quoted: 4806 Post(s)
Liked 3,932 Times
Nitto makes several two bolt posts. The lugged steel post is 1) beautiful and would look different but in place on a bery old bike, 2) is not heavy despite sounding it and 3) is a joy to work with and adjust and 4) has lots of setback. Drawbacks - expensive and probably not in 27.0. I have it on my Mooney where it is a keeper. Uses an Allen wrench so that is easy. 5 or 6mm; one you are going to have on hand anyway. Currently made and easy for any shop to get.
Liked 3,932 Times
Good outcome. I won a Zeus seatpost! But it as 27.2 and my Fuji was a 26.8. Rode the State champs the next weekend on the untouched Hupel Rider. With that new tilt- painful! My mom got to watch me finish, ride straight for someones lawn, put on the brakes and simply fall over, still strapped in but off that seat! Exchanged the Zeus for a 26.8 (thank you Zeus!) and all was well; in fact a lot better, after that.
Quoted: 1609 Post(s)
Liked 2,216 Times
Access ease is sometimes a function of the saddle choice.
Likes For SJX426:
Quoted: 786 Post(s)
Liked 520 Times
I've got a 3ttt in 27.0 with a different 2-bolt configuration if that would be of interest:
https://www.velobase.com/ViewCompone...7-93113E14CF76
Liked 3,345 Times
"frost heave" - a new-to-me term
is this when frost riving has cracked the pavement and created a bump?
thanks for the story
Liked 3,932 Times
Yes. I don't know the exact mechanics of them but in snow and ice country, we all know them. That particular one was like a root under the pavement on a MUP only about 8" high. Sort of a guess. I didn't get a very long look and I wasn't stopping! Not sitting in 2nd place; leader up ahead out of sight and no one in sight behind.)
Quoted: 1829 Post(s)
Liked 3,376 Times
I've been using a 12 point combination wrench, and can't recall any large amount of effort or frustration.
Steve in Peoria
Likes For steelbikeguy:
Liked 2,216 Times
Applies to the ground in northern climates. When water is in the ground and a freeze occurs, the ground (dirt) will lift as the ice expands. Helps when seeding in the fall as the seeds will fall into and under the dirt when it thaws. Self planting.
Quoted: 2485 Post(s)
Liked 2,956 Times
You don't even need that long a wrench. Just grease the threads of both bolts and then use your fingers to turn the front bolt for tilt adjustment and the wrench on the rear bolt to secure the saddle in place.
Likes For Trakhak:
Shifting is fun!
Bikes: Yes, please.
Liked 4,605 Times
As currently on the stand. A very nice pillar indeed:
Old fart
Liked 3,401 Times
It also depends on the saddle. If you're using a plastic base saddle, most of those have enough clearance to reach the bolts with a combo wrench from the side. But if you're using a leather saddle with deep skirts, like the Brooks Professional or Idéale 90 or 92, you can only really reach those bolts from behind the saddle, between the rails, which makes using a combo wrench tedious.
