About sound of wire and toptube
my frame is pinarello f10 and super record 12s mechanical.
after build at lbs, I found that the rear brake wire which go through the frame top tube get a sound touch the tube when brake.even when riding on uneven road.
so plz tell me how to do to avoid the problem?
a mechanic at other lbs told me that using inner lead wire to avoid that sound.
so could you guys tell me where to buy that wire used in the topbue?
sound video https://photos.app.goo.gl/uoCiAAr9XEzNhcXh7
so do you guys know that just only my pinarello f10 like that or it's a common? or just only with cp sr 12s?
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
Sometimes you can thread a small rubber O ring, a couple of them, to act as a buffer so you don't that annoying "tink" over every bump. can drive you crazy !
Mark Petry
Bainbridge Island, WA USA
Mark Petry
“He's all over his machine” - Phil Liggett
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
Your shop should be able to help you with this. If not, order these
https://www.ebay.com/itm/20-40pcs-Bi.../303238337631?
Undo the brake cable and thread these onto it between the cable stops. If you have an internally routed cable, which I think you might, it gets more complicated than I can help you with "virtually". Sorry
Mark Petry
Mark Petry
Mark Petry
Mark Petry
Mark Petry
Mark Petry
Quoted: 1438 Post(s)
Liked 1,092 Times
A length of soft tubing such as vinyl aquarium tubing can also be used to keep the wire from tapping the top tube, and might be easier to thread on than the linked items.
Likes For dsbrantjr:
