KMC or Shimano Chains? Which one you would choose?
Lula Mae = 15 lbs.
Bikes: 2011 Trek Madone 6.5 w/SRAM Red 22
KMC X10sl gold w/master link. I believe KMC makes Shimano's chains.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Kmc
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
this question is too easy.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Shimano. Even if it cost more. Much more reliable.
Master link is overrated. You don't need it, and it is weak point (my chain broke on it (and yes, it was perfectly connected), so is my friend's)). Never again.
Bikes: '98 Rhygin SS road,'99 Fat Chance Ti Fat, '95 Azonic Mtn bike, '88 Giant Sedona.
I've been using Wipperman Connex for years, with no problems. Just another option.
Quoted: 551 Post(s)
Liked 277 Times
KMC. Replace as needed.
I had 2 shimano's before trying the kmc, the kmc is noticeably quieter and seems to last just a little longer. I won't look back to shimano and will stick with kmc.
I'll use Shimano chains if the price is right for the same spec as the KMC. But I won't use the dinky little rivet; the master link always wins.
Quoted: 2952 Post(s)
Liked 3,106 Times
Cheaper, quieter, easier to install? No thanks, I'll keep using Shimano.
(Just kidding. I'm KMC all the way now.)
well hello there
Quoted: 503 Post(s)
Liked 336 Times
Used KMC for years. To me it seemed like they wore out faster.
Then I switched to shimano with a wipperman connex link. But I found that I was rarely removing the chain.
Recently I just switched back to your basic shimano chain.
Eh. Currently using HG73 chains I get off a big auction site for $17 a pop. They seem to last a while (5000 miles?) and are quiet. Going to try a X9.93 chain next, to see if shifting changes at all, but I'm perfectly happy with the HG73.
Definitely use a master link though. I've been using a Wipperman Connex link with my chain and no problems, also very easy to remove.
I replaced a chain on one of my previous bikes. There was no need for special dinky rivets or links. I bought a chain breaker tool for about $3, pressed out one of the pins, took off the old chain, put on the new chain and pressed in the new pin with my tool. So has anything changed? I'll need to replace my current chain in a year or two. Can I use the same simple procedure or has somebody made things complicated?
Bikes: S2, Wilier GTR (Arr), Giant VT, Myata 3-10
Quoted: 17 Post(s)
Liked 6 Times
Whipperman - quieter, wears better, superior quicklink
kmc - see t'other's posts, above
SRAM or Shimano - 3rd, way
Shimono - I'd go with a more well known fourth brand
una carrera contrarreloj
Shimono, or Chimpmono. Maybe even Shinmono, but it might leave a bruise.
