new chain; skips; cassette ok
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
Put a new chain on the Masi (along w/new tires, clean drivetrain, balance wheels, etc). Rode it, chain skips in the rear under heavy or even moderate pressure. Cassette is ok- no sharkfins; I keep my drivechains clean. This is the third chain for the cassette/chainrings. sup?
Quoted: 3395 Post(s)
Liked 5,580 Times
Cassette is toast.
I've worn out plenty of cassettes, and none of them was visibly worn out.
I've only had sharkfinning on chainrings.
Is it the same brand you usually use? My go to is Sram, I have tried KMC, and impossible not to make jump under load, no matter how much I toy with it.
Quoted: 7069 Post(s)
Liked 11,141 Times
Cassette wear is notoriously difficult to diagnose visually. Replace it.
Likes For Koyote:
Senior member
Quoted: 946 Post(s)
Liked 663 Times
The most reliable way to diagnose a worn cassette is to install a new chain and look for the symptoms as described in the OP. It has to be pretty far gone to be obvious visually in my experience.
Couldn't agree more. It's quite difficult to visually diagnose a worn cassette. What you usually find is that the chain will skip in the middle of the cassette on the gears that see the most use but, will still shift ok in the upper and lower gears.
Mother Nature's Son
Quoted: 855 Post(s)
Liked 1,447 Times
I have been through this and would have sworn the cassette was fine. Changed the cassette and the drivetrain magically started operating properly.
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times
Cassette - replaced mine under same circumstances - all is good.
Glenn
Glenn
Quoted: 6278 Post(s)
Liked 4,864 Times
Third chain in the life of that cassette? Or the third chain you've tried and they all exhibit this issue?
If three chains for one replacement period then I'd think you've spent the cost of a cassette. So try it.
If you've replaced two other chains at normal intervals and this it the third time, then that cassette is probably worn out along with the chain rings maybe.
We don't need to ask if you used the correct speed chain do we?
Likes For Iride01:
Quoted: 268 Post(s)
Liked 80 Times
FTR, I change chains about every 9 months/1500 miles or so.
The previous 2 chains worked fine.
My LBS always wants $ for new chainrings whenever the cassette is changed.
Quoted: 303 Post(s)
Liked 137 Times
My experience, starting with 5 spd FW and now with 11 spd cassettes is that once you have worn out two chains
the FW/cassette will object to the 3d chain and need to be changed. When the 3d chain wears out, chainwheels
get to be at or near EOL, more so with 2x than 3x. Unfortunately with SRAM/Shimano/FSA and some others
price of a pair of new chainwheels is such that it makes some sense to just get a new crankset for not much
more.
more.
Liked 5,580 Times
Third chain in the life of the cassette & no, you don't have to ask if I used the correct speed chain (9 speed).
Quoted: 550 Post(s)
Liked 325 Times
more.
more.
It also depends on how worn you let it get which depends on chain metallurgy. I run Campagnolo chains with front shift degradation from increased lateral flexibility as they reach 1/32" of elongation around 4500 miles. Wippermann chains reportedly grow slowly too.
Liked 4,864 Times
You have checked that it's not just that coincidentally the DR needs some adjustment? little more or less cable (barrel adjuster) or bent hangar?
In my experience, a chainrings last many times longer than a cassette. Symptom of a worn-out chainring will be "chainsuck" when a new chain is installed. i.e. instead of smoothly leaving the chainring on its return to the RD, it will "stick" to the bottom of the chainring. In a mild case, it makes a rattling noise as the RD tugs it off the chainring. In a severe case it remains stuck to the chainring and gets rammed into the underside of the FD.
Quoted: 114 Post(s)
Liked 119 Times
If you still have your old chain, measure it for "stretch". If the chain is 1/8" (or more) longer over 12", then the elongated probably reshaped the cogs such that a new chain won't mesh properly, causing the chain to skip/slip.
I agree its the cassette, but from experience Ive noticed the skipping may subside if you ride the new chain for a little while. No need to replace it right away unless the skipping is severe and dangerous.
Many years ago the third chain I installed on my 6500 cassette started skipping almost immediately upon installation. I think it may have been the 3rd or 4th gear but I can't remember for sure. I thought maybe I could ride it out into shape but that didn't work. So I changed the cassette and skipping continued. So I put on a new chain and all was well. I think I ruined the barely used third chain by running it out a worn out cassette. My rule of thumb after that was two chains for each cassette. I know there are people who post about getting extraordinary miles on their drive-train but I'm pretty skeptical. I ride in good conditions and have always been pretty fastidious about cleaning. Generally I change a chain between 2,000-2,500 miles (I've not noticed faster wear on my 10 and 11 speed bikes btw), so I do think that changing a chain at 1,500 miles as the poster did seems a little quick--but then again I don't know that conditions he riding in. It's a wear part(s) and I'm actually fairly happy I've been able to ride enough to need to replace them.
Liked 11,141 Times
Sure, but that would be because the chain is wearing prematurely.
Not from my experience. It may be in theory but I have done so in the past and not noticed anything unusual. That one cassette displayed a bit of skipping from the first to the second chain, but it quickly subsided. I did replace the second chain a bit sooner than the first one, that was very worn, but only to not have skipping on the third chain, that is on now. - not because it was faster wearing. At least not to a noticeable degree. YMMV. and all that.
Liked 11,141 Times
Quoted: 268 Post(s)
Liked 80 Times
Update: got new cassette- problem solved! (after slight adjustment)
ummm, my cassette has seen ... 4 previous chains, not 2 as I previously stated
This is my old cassette:
(ignore date)
ty for all replies/great conversation
(ignore date)
Likes For epnnf:
Quoted: 2953 Post(s)
Liked 3,106 Times
FWIW, I generally get about 3 chains per cassette before I have shifting issues or skips. So, sounds right to me.
