Front mudguard too high and too far back
Quoted: 2432 Post(s)
Liked 638 Times
It's a CX bike but I'll be using it for weekend touring. I have Handsome Cycles mudguards. The Easton fork has the top mounting hole on the rear of the crown. It doesn't go all the way through so I can't attach the bracket in the front, and there is no hole on the bottom. Only the rear. So as you can see from the picture, the whole thing is rotated back about 2 inches further than i would like, it looks kind of funky.
But the biggest issue is that it's too high and has a big gap. Is there some kind of bracket extension I can buy to lower it about an inch? I might be able to fab something but want to see if something I need actually exists first. I saw one from Problem Solvers but that's only for forks that have a hole on the bottom of the crown. And can someone think of a way I can get it bolted on the front of the crown? If there were some kind of U bracket that would run underneath that might work. I've searched and haven't found anything that would work yet.
Many cheap brake boosters have a center top mounting hole. That would put the mounting location in front of the brakes slightly.
https://www.ebay.com/itm/Anodized-Al...RKzRPhGrX4F2gw
https://www.ebay.com/itm/New-MTB-Bic...oAAOSwl0xeWpvs
Likes For wesmamyke:
Liked 638 Times
Quoted: 3461 Post(s)
Liked 1,466 Times
There are people out there that wish they could get their front fenders down lower to reduce water spray on their legs and feet. I know people that buy two sets of fenders, discard the front and use the second rear on the front to get it lower down like yours.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
Just make an L bracket with two 4mm bolts to the fender. Make an oval hole for the fork. Try to hammer it round to fit the fender better. Maybe use a tube piece to pad it. Tape the tab of the other mount.
I agree it is too low. I tried the same one time. It lasted one ride, until I pushed the bike off a curb where it klunked. NOT safe.
Then I cut up an old rubber boot and put it on to hang where your fender is now. Looks and works fabulously. Other stiff solutions are not good either.
I also put a rubber flap at the front of the rear fender, behind the BB, so it hangs a couple inches below the chain. This works even better to keep everything less dirty. Both bikes are IGH.
I don't see why you would need those brake arches.
Go to Lowes/LHS and get a steel pipe hanger for $1. Cut/bend/drill/file/paint to fabricate L bracket of suitable dimensions to achieve desired fender fit. Install and ride.
https://www.lowes.com/pd/HoldRite-1-...ron/1001095368
VO has a large assortment of good value, high quality fenders:
https://velo-orange.com/collections/fenders
Likes For seeker333:
Liked 638 Times
I have thought about getting an All City Nature Boy CX fork, they cost only $130. The durability would be a plus but I do like how light my Easton is. The whole bike is actually very light.
Although I did this kludge a few years back, I suspect I used the exact Lowes part previously linked for the ~2" drop fender mount pictured below. Apologies for the huge images. That is 3M Scotchlite reflective tape on VO aluminum fenders.
An alternative is the Problem Solvers Fender Flute, much prettier and much more $:
https://problemsolversbike.com/produ..._flute_-_32803
https://cdn.bike24.net/i/mb/79/30/67...1-c-128864.jpg
I don't understand why you want a new fork. I reread the OP and to me the fender does not look too bad, and in fact it likely keeps more water off your feet in this "low in back" position than if it were higher with the usual smallish mud flap.
if ya wanna lower the fender, consider an extendo thingy from the bottom opening of the fork.
imagine something like an expando plug you stick into a handlebar, like a mirror attachment.
short section of aluminum pipe, one end with slots cut, and an expanding wedgie to lock in place.
another option.........drive a star nut in the bottom of the fork for your fender mount.
assuming you assume you'll never need to drive the upper star nut out.
**ah, managed to open the link above. the flute thingy should work.
would be super easy to make one yourself.........
Quoted: 1182 Post(s)
Liked 833 Times
You might want to conside fenders with a "safety "quick disconnecr where it attaches to the fork's dropouts. Picking p a piece of debris that jams between you front wheel and fender can be exciting. Planet Bike and SKS both have fenders with this feature.
This was on a rear feender but the debris jamed between the wheel and the fender actual folded up my fender accordain style, jammed the wheel, and cut a big gash in the tire. I'm glad it was not on teh front wheel.
